Amazing what a 3 degree shim can do
Discussion in 'Suspension' started by mattmxracer454, Jan 4, 2015.
  1. May 31, 2018 at 9:20 AM
    #41
    ZrowGz
    ZrowGz I'm a n00b.
    SLC, UT
    97 4x4 LT/Cantilever
    Resurrection, because I use search!
    So, I got my vehicle aligned after doing LCA bushings, but I’m still getting rather intense vibrations from my driveshaft not having the correct angles. My frame was bent slightly, bowed like it towed something too heavy. So, I’ll be doing a frame swap soon. I’m the mean time, I had to go for a long drive this week, even though it’s vibrating.
    Questions:
    - will the vibrations damage the driveshafts or u-joints?
    - the amount of play on the bearing/bushing that supports the center of the driveshaft between the two segments has been increasing. How does one go about changing that? Would putting a new one on before I can correct the angles with a frame swap cause any increased harm to the driveshaft by forcing the accelerations to put more pressure on the joints?
  2. Oct 8, 2018 at 3:01 PM
    #42
    Jbg1884
    Jbg1884 Member
    Bo
    2019 4x4 Sport
    3/2 leveling kit
    New to the game. I’ve got a rough country 4 inch lift with the blocks on the rear. What kind of leaf shim would work with this lift kit?
  3. Feb 19, 2019 at 6:37 PM
    #43
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    Thread revival. Can I add a shim if I already have a 1” block?
  4. Feb 19, 2019 at 6:52 PM
    #44
    Jaw6fl
    Jaw6fl Member
    Tacoma SR5
    2” lift 3”spacers
    Great video! Many thanks!
  5. Mar 8, 2019 at 2:32 PM
    #45
    Cog
    Cog Well-Known Member
    Reno, NV
    You ever figure this out?? I need to shim mine but I have a block also
  6. Mar 8, 2019 at 3:37 PM
    #46
    El Tano
    Pasadena. CA
    10 Tacoma TRD sport
    No yet, I have an appointment with the dealership next week before the recall or tab expires for the shaft propeller expires at the end of the month. Then I’ll install the shims.ill keep you posted.
  7. Jan 14, 2021 at 10:43 PM
    #47
    tedusmc1345
    tedusmc1345 Well-Known Member
    ted
    2018 Tacoma Sport 4x4
    Follow up?
  8. Mar 8, 2021 at 11:33 AM
    #48
    Csaw
    Csaw Active Member
    2011 White Tacoma
    Follow up? Same question/concern. Thanks!
