Amp installation questions
Discussion in 'Audio & Video' started by 80 atoyot, May 8, 2008.
  1. May 8, 2008 at 8:40 AM
    80 atoyot
    80 atoyot [OP] Well-Known Member
    Bahstan Mass
    08 Access Cab-SR5-Boat Tower....We are both getting old !!!
    Double DIN JVC Head unit with Ipod and Bluetooth, Plays video even while driving Shhhhh...Speaker replacement, 200 W Alpine Amp. Glove box twin 12V power outlets
    I just installed a JVC DD head unit and pioneer 6.5" speakers all around.
    http://www.tacomaworld.com/forum/audio-video/7829-head-unit-installed-thanks-tw.html
    But I am not blown away by the sound quality. SO.....
    I ordered an Alpine F-300 amp. THey suggested I mount it under the seat and it looks like it will fit under there just fine. Questions though.....
    1) What do I mount it to?
    2) Can I run the wires up the miccle console?
    3) Do I have to remove the seat?
    Any help or suggestions is appreciated.
  2. May 8, 2008 at 8:49 AM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    1. screw it straight down make sure you dont hit any wires
    2. dont run wires through middle console run from the side molding in your door, the door panel removes easy.
    3. i had my seat removed you want to put the amp in a good spot the drill it down securely.
  3. May 8, 2008 at 9:10 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    You should remove the seat. It's easy and will save you a lot of time in the long run.
