amp mounting locations
Discussion in 'Audio & Video' started by zero niner, Aug 22, 2008.
  1. Aug 22, 2008 at 12:25 PM
    zero niner
    zero niner [OP] romeo oscar bravo
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    All Pro front plate bumper, 5100 1.75" Bilstein up front, 1" block and TSB in rear, UWS lowpro tool box, Toyota Side Steps
    Hello,
    Still waiting on delivery of my new Prerunner so I thought I'd ask some questions to prep me for my stereo install. Where is everyone mounting their amps? Is there enough room under the seats? Is there enough room behind the seat behind the drivers seat? Can enough air get back there to vent it? Just wondering as I've got a pair of amps I'm looking at installing and I've heard it's kinda small under the front seats in the Tacos. Thanks in advance!
    Rob
    Oops, I may have posted in the wrong forum, I just remembered there is an AV section, if this needs to be moved, could a Mod please do so, sorry and thanks.
  2. Aug 22, 2008 at 12:28 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    I've got an Alpine 4 channel amp mounted under the drivers seat of my 08 Ex. cab. It sticks out the back a little, so the carpet kind of sits on top of the end of it. The back seats still fold down with no issues. There is less room under the passenger seat due to some sort of cross brace. I have had no overheating problems at all. Hope this helps out.
  3. Aug 22, 2008 at 2:58 PM
    Addicted
    Addicted Well-Known Member
    Greenville, SC
    07 DC 4x4 - TRD Off Road - Black
    I"ve got an Alpine 4.150 under the passanger seat of mine w/ no room issues. It even sits before the floor vents so hopefully there won't be any heat issues even in winter.
  4. Aug 26, 2008 at 9:52 AM
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    Completely depends on the amp and what you are looking to do. I have some beastly sized amps that are requiring a custom amp rack, sitting horizontal behind driver's side back wall (plastic trim stuff removed).
    If you haven't bought amps yet, look into stuff like the Alpine PDX amps or something. There's a few companies that have this line of stuff, and the space saving is quite nice.
  5. Aug 26, 2008 at 9:58 AM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    i have the rockford fosgate 300-1 amp under my drivers seat fits like a glove if your amps are big the back they shall go, like everyone else said depends on the amp to where you are going to put it.
  6. Aug 26, 2008 at 10:12 AM
    shonuff505
    shonuff505 Member
    Albuquerque
    05 4x4 SR5 Blue Beast
    Billet Grill
    if its a 4 door, and if your lgoing for "looks" i say mount it behind the rear seats. There are plenty of room behind there, and i have even seen custom boxes with amp mount plates. Just depends on you and the system you trying to hook up.
  7. Aug 26, 2008 at 1:58 PM
    Chickenmunga
    Keizer, Oregon
    Depends on how much of a headache you want to give yourself ;). There's enough room to make a lot of things doable, but it isn't a car trunk. Look at some of the guys with dual 10" subs and you will see what I mean.
    I say post up some sizing specs on the A/V section, let people know what else is going in (one sub, two subs, etc.), and see what people have to say.
  8. Aug 26, 2008 at 2:10 PM
    zero niner
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    Thanks for the replies, I had a JL Audio 500/1 and 300/4 in my Tundra that I took out before I sold it so I was looking to install it in my DC Tacoma, turns out that under the passenger seat is no good. Perhaps I'll see about mounting it behind the drivers side rear seat where there is space, I'm also assuming that I'll need to vent it as does not have enough air circulation. Thanks for the help guys!
    Rob
  9. Aug 26, 2008 at 6:40 PM
    TorenApart
    TorenApart Well-Known Member
    06 Double Cab SR5 TRD Sport
    Toytec Ultimate Lift Kit, OME Nitrocharger shocks and Dakar leafs, Total Chaos UCA's, 18'' Black XD Monster, 285/60R18 Cooper Zeon LTZ, Leer shell, OEM Skid Plate, Weather Tech Floor Mats, Lund Tonneau, Custom 2-tone gray leather, Aero Turbine 2525 muffler with AR25 resonator, Aero Turbine Exhaust Tip, Mr. Marv subwoofer enclosure w/ 2 JL 10W3v2's, AFE Pro Dry S, Eclipse AVN-6620, Pioneer PRS-D2100T, Hybrid Audio Clarus 6.5'' Front Components, Black Headlight Mod, Tinted tail lights, PL5300 with Eclipse BEC-109
    Did you try mounting under drivers side? Somebody mentioned a difference in space available under seats between passenger and driver's side.
    I am looking at the same amp actually to power my components and am wondering about that same thing.
  10. Aug 26, 2008 at 10:05 PM
    Chickenmunga
    Keizer, Oregon
    Taken directly from the user manual:
    If you still want under the seat, there's a guy on here who removed the underseat electronics and reversed the stability bar for added space. I don't know if I'd recommend that, as that messes with the airbag sensor and I wonder if you can feel the bar when you go over a bump... Also things are just harder to adjust, it's more susceptible to dirt, people kick it or want to shove clothing/blankets down there...
    all you need is an amp rack behind the rear seats. You should be able to mount them vertically with the heat sink pointing up (leave some space between the two for adjustment and heat dissipation). Mr. Marv, our resident expert (he'll blush and deny it, but that's what he is) is currently building me a box and rack that will mount the following stuff:
    JL 10w3v2 sub, sealed box
    Memphis 16-MCA3004 (18.5" long)
    Memphis 16-MCD1000 (15.8" long)
    so if he can make that work for me, I'm sure you can get your things in as well.
