Amp power problem
Discussion in 'Audio & Video' started by LonghornTaco, Dec 31, 2008.
  1. Dec 31, 2008 at 2:29 PM
    LonghornTaco
    LonghornTaco [OP] Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    I'm wiring up my amps and I'm using a dual amp wiring kit from Rockford Fosgate. It's got a 4G power wire coming from the battery splitting to two 8G power wires to the amps. Everything's wired up, but they aren't getting power. I've checked the ground and I believe it's good. However, the fuse holder doesn't look like it has a fuse - or even a place for any kind of fuse I've seen...
    Help?
  2. Dec 31, 2008 at 3:27 PM
    atsaubrey
    atsaubrey Dealer/Sales Rep for Sundown Audio.
    california
    blue 2007 double cab
    Sundown Audio 100.4 and 1500D, Pioneer 880PRS, Zapco Refernece 6.5" comps, 2 10" Image Dynamics IDQ, 200ft of Second Skin deadener, Kicker wire
    That fuse holder is for mini anl fuses.
  3. Dec 31, 2008 at 3:32 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    x2... an audio shop should have them if yours is missing -- seems like that's something that should have been included... hmm....
  4. Dec 31, 2008 at 4:06 PM
    808trdsport
    808trdsport Well-Known Member
    Honolulu
    08 Tacoma TRD Sport Prerunner
    6000k HIDS, double tint in the back and tint front side windows, CGS cat back exhaust, AFE Pro Dry filter
  5. Dec 31, 2008 at 4:10 PM
    CK91
    CK91 Member
    have you run a remote turn on wire? It should be a small blue wire running from harness that connects to your head unit. Just a random guess. I have that same amp kit and i did not have to do anything to fuse
  6. Dec 31, 2008 at 7:13 PM
    LonghornTaco
    Minnesota
    Found out that it's a MAXI fuse. The kit is supposed to come with a 100A fuse, but that wasn't the only thing it was missing. That's the LAST time I order anything from HookedOnTronics.com!
    Anyway, found a audio shop that told me that it was a MAXI fuse (they didn't sell them) but Pep Boys did. However, they only had a 60A. I got a few of those for now (until I can get a 100A). So, I have power, but my subs are coming on. Gonna do more troubleshooting tomorrow.
    Thanks for the input though!
  7. Dec 31, 2008 at 8:23 PM
    atsaubrey
    california
    I am still having trouble figuring our how that is for a MAXI fuse from the pic. Is the MAXI fuse working? Then again thinking about it I am not sure how you'd even get a Mini ANL fuse to work. Pull the other end so I can see both ends.....this is now bugging me....lot easy to see in person. Seeing in person would tak me 5 seconds to tell you :frusty:
  8. Jan 1, 2009 at 6:53 AM
    sooner07
    sooner07 1/2 man 1/2 amazing
    A A Ron
    DFW, Texas
    Debadged 2008 Rugged Trail
    Toytec ultimate lift kit, light racing UCAs, ARB bumper and full skid plates underneath. Looking into redoing the suspension and maybe repainting the ol' Taco.
    I don't see how it can be a maxi fuse holder either. Despite it not looking like a maxi fuse would fit, I don't know anyone that uses them for power distrobution. Main power is typically fused with ANL or mini ANL now and older systems and distro blocks typically use AGU fuses.
  9. Jan 1, 2009 at 7:29 AM
    atsaubrey
    california
    agreed. Lets wait for the OP to explain some more and hopefully more pics.
  10. Jan 1, 2009 at 7:57 AM
    LonghornTaco
    Minnesota
    It is a maxi fuse holder and is working with a 60a fuse. I'll take a pic when I get back to my truck.
  11. Jan 1, 2009 at 1:29 PM
    LonghornTaco
    Minnesota
    Here's a picture of the fuse holder with the maxi fuse in it. Looks ghetto to me, but that's apparently what I've got! :)
    Thanks for the help guys!
  12. Jan 2, 2009 at 9:02 AM
    it's in coma
    it's in coma Well-Known Member
    in the desert
    06 trd off road
    intake and exhaust
    where did you run the wire thru the firewall? how did you do it?
  13. Jan 2, 2009 at 9:20 AM
    betz.steven
    betz.steven Well-Known Member
    Southern NJ
    2011 TE 4Runner
    i ran 4 gauge for my amps as well, i ran it through the rubber boot that is used for the factory wiring. i cut a small slit on one side and with a little elbow grease was able to push it through. ill take a pic in a few
  14. Jan 2, 2009 at 1:50 PM
    81shark
    81shark Well-Known Member
    there is also a plug behind the brake booster that you can remove and use.
