Amp/ Subwoofer Combo
Discussion in '2nd Gen. Tacomas (2005-2015)' started by YungHaydo, Nov 14, 2019.
  1. Nov 14, 2019 at 2:21 PM
    YungHaydo
    YungHaydo [OP] Member
    Hayden
    2009 Tacoma TRD Sport
    lifted, 33’s
    I can’t decide which amp and pair of 10 inch subwoofers are best for my truck. Any suggestions??
  2. Nov 14, 2019 at 11:20 PM
    Vagrant
    Vagrant Well-Known Member
    Michael
    2015 Pyrite Mica TRD Offroad
    Subd because I'm also curious
  3. Nov 18, 2019 at 9:16 AM
    YungHaydo
    Hayden
    lifted, 33’s
    Haha it’s not looking too good for us so far.
  4. Nov 18, 2019 at 10:17 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    YungHaydo[OP] likes this.
  5. Nov 18, 2019 at 10:45 AM
    Philrab
    Philrab Curator of useless knowledge
    Phil
    New Orleans, Louisiana
    2015 Pyrite Mica Quad Cab Prerunner
    Bunch of Basic Taco mods.
    A. Why two 10’s?
    B. What’s your budget?
    C. How much bass are you looking for?
    D. Do you or someone near you have the ability to design and build a custom box, or are you stuck with a prefab box?
  6. Nov 18, 2019 at 11:22 AM
    chiefO
    chiefO Well-Known Member
    Fresno, CA
    2005 Tacoma 4x4 Double Cab SB
  7. Nov 18, 2019 at 11:47 AM
    YungHaydo
    Hayden
    lifted, 33’s
    Larzzzz[QUOTED] likes this.
  8. Nov 18, 2019 at 11:55 AM
    YungHaydo
    Hayden
    lifted, 33’s
    The box I have is made for two 10’s, so I thought I would stick with it. My uncle gave me a Quantum QXA1100M Mono QXA Amplifier and two MTX Audio Speakers. They are both pretty old and the amp overheated just about every time I played music. I don’t want to spend any more than $500 for the amp/subwoofers.
  9. Nov 18, 2019 at 11:56 AM
    YungHaydo
    Hayden
    lifted, 33’s
  10. Nov 18, 2019 at 12:00 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Does the box fit behind the seats though?
  11. Nov 18, 2019 at 12:39 PM
    Larzzzz
    Larry
    MA
    What caused the amp to overheat? Low voltage, running the amp with lower than rated speaker load.
    If the wire feeding the amp isn't big enough, you could be experiencing a voltage drop as you crank it up. And the ground wire, how is it attached to the truck? Clean metal to metal is best. Use a nut and bolt, not self drilling screws.
  12. Nov 18, 2019 at 6:03 PM
    Philrab
    Phil
    Optimally, assuming this is a sealed box, you should figure out how much airspace the box has and pick subs that are designed for that amount of airspace.
    Then select an amp with at least the amount of RMS power required to run both subs
    The amp will dictate your wiring/electrical needs. Big 3 is recommended in any install.
    Also recommend you learn, or find someone that knows how to properly set up an amp. I don’t mean fiddle with the knobs “till it’s loud”. More installs have sounded like ass because someone treated the Gain knob like a volume knob.
    If you’re not willing to learn the proper way to do all of this, I recommend hiring the install out. Otherwise, find your local car audio community and make some friends.
    I’ll answer whatever I can, just don’t know your level of knowledge and interest. I did my first install twenty years ago and learned a lot from others along the way.
    MolonLabeTaco likes this.
  13. Nov 20, 2019 at 5:29 AM
    YungHaydo
    Hayden
    lifted, 33’s
    Yes.
  14. Nov 20, 2019 at 5:32 AM
    YungHaydo
    Hayden
    lifted, 33’s
    I think the speakers were causing it to overheat. We changed the ground wire, so I don’t think it’s the problem. A few people I’ve talked to in the past few weeks said the speakers are the problem.
  15. Nov 20, 2019 at 6:18 AM
    TVH475
    TVH475 Well-Known Member
    Montrose CO
    I'm running Memphis shallow mounts and a Massive audio digital amp off of a pioneer deck
  16. Nov 20, 2019 at 6:40 AM
    Larzzzz
    Larry
    MA
    What is the impedance of those speakers? Have you measured the resistance of those voice coils? They should be close to the rated impedance. You do not want to load an amp with a lower than it's minimum rated impedance. Not only will it overheat, you stand a good chance of burning up output transistors.
  17. Nov 20, 2019 at 10:59 AM
    YungHaydo
    Hayden
    lifted, 33’s
    Installation won’t be a problem. I have some time out of school here soon so I can take the speakers out and measure the space inside the box. The biggest thing for me is determining how much power I need to power two 10’s. I understand it varies based on the subwoofers.
  18. Nov 20, 2019 at 4:58 PM
    Philrab
    Phil
    Power requirements are simple. Find the RMS rating of your subs. You need at least that much power from your amp. Some subs will take a bit more, depends on the sub. Too small of an amp won’t run them at full potential. Too much will shorten the life of the subs.
    Improper gain adjustment and clipping will kill them quickly.
    LAMCKMA007 likes this.
  19. Nov 20, 2019 at 5:00 PM
    Philrab
    Phil
