amp turns on then immediately off
Discussion in 'Audio & Video' started by JoshLV, Feb 3, 2011.
  1. Feb 5, 2011 at 6:32 AM
    Brandon###
    Brandon### Well-Known Member
    I had a problem similar to this before. I connected the remote wire to the power antenna wire (which is blue or blue/white). It would power up for a second then go off. Connect the remote wire to a good 12v power source and try/check it.
  2. Feb 5, 2011 at 2:45 PM
    JoshLV
    JoshLV [OP] Well-Known Member
    Josh
    Hanford, CA
    2007 Tacoma SR5
    Found the problem. inside the sub box where the speaker wire connects to the box terminals, the shitty clamp that slides onto the terminal fell off. So now I just have the wire spliced onto the terminal. Now its kickin :) thanks for all the help.
