Amping components with internal crossovers ?
Discussion in 'Audio & Video' started by BluTaco08, Oct 11, 2009.
  1. Oct 11, 2009 at 10:58 AM
    BluTaco08
    BluTaco08 [OP] I LiKe TaCos
    I'm trying to amp my front speakers just to see the difference before buying amps and doing the full install, however I can't figure out where to run the wires from the amplifier to the speaker.
    I'm running these:
    Alpine Type-S SPS-600C - Car speaker - 80 Watt - 2-way - componenthttp://www.amazon.com/Alpine-SPS-600C-Component-Speaker-System/dp/B001447Z8Q
    All four posts on the back of the speaker are being used, two for the tweeter positive/negative and two for the speaker positive/negative.
    Now, there are two wires that were capped off that I'm thinking is where the wires fo the amp should go to power the speakers. It looks like this:
    It's the blue and green wires. They had caps, but I cut them off to see what I was working with.
    Here's a few more:
    Are those the right wires, or do I need to splice and solder into something else ? Thanks!
  2. Oct 11, 2009 at 1:37 PM
    BluTaco08
    Problem solved. No input needed.
