Amplifier problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by Caleb george, Nov 19, 2019.
How do I property wire my amplifier?
  1. How to locate the correct wire
    1 vote(s)
    100.0%
  2. Tell me what I'm doing wrong
    1 vote(s)
    100.0%
Multiple votes are allowed.
  1. Nov 19, 2019 at 10:08 PM
    Caleb george
    Caleb george [OP] New Member
    Caleb
    2000 toyota tacoma
    Hey guys I just purchased a power bass amplifier for my 2000 toyota tacoma, the issue I am having is when I turn my truck off the amplifier stays on. I have the remote wire hooked up to what a thought was a accessory wire (12v blue wire) just in the door by the circuit board and I'm wondering if any of you would know what I am doing wrong.
    I tried hooking it up by my head unit but i think the remote wire is faulty because it doesnt read anything when i test it and the amp doesnt turn on when i hook it up by my deck.
  2. Nov 19, 2019 at 10:24 PM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    Ive never wired an amp before, but I imagine you would want to tap into an ignition wire so that it only has power when the Truck is on. You can fuse tap into the ignition fuse in the cab if thats the case
    welcome to TW btw :thumbsup:
    Caleb george[OP] likes this.
  3. Nov 19, 2019 at 10:24 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Your aftermarket head units stereo has a blue wire just for this (remote turn on), have you tried using this?
    Other amplifiers are signal sensing, could try changing the settings or even the input from RCA to the speaker level inputs.
    Last alternative would be tapping into the ignition wire which is the 7.5A fused tap in the interior fuse box.
    Wulf and Prayn4surf like this.
  4. Nov 20, 2019 at 4:29 AM
    J $
    J $ Active Member
    Jared
    04 Silver Taco 4x4, 3.4L V6, TRD Extracab
    I recently added a powered bass to my truck also and had to get an adapter that plugs in where the main head unit plugs in. The original head unit plugs into the back of that plug. This added a "signal" wire for the bass unit.
    Do you have a stock head unit? If so, you must have an adapter to add the signal wire.
    If not, is there a setting to change that toggles the signal on or off?
    Tapping into a blue wire that doesn't have power when your truck is off is not the same as connecting to the signal wire of the head unit. It is probably a specific voltage that is needed to turn your bass unit on, not just 12v on the signal wire.
  5. Nov 20, 2019 at 4:37 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    As others said. You have it wired into a always hot wire.
  6. Nov 20, 2019 at 6:30 AM
    J $
    J $ Active Member
    Jared
    Mine is wired directly to the battery but only comes in when the truck is on because of the signal sent through the wire from the head unit.
    Here is the adapter I used for my 04 Tacoma:
    https://www.ebay.com/itm/Toyota-Lex...lug-Play-Harness/142797579095?epid=1211820841
    The blue wire on the right side of the plug is the on/off signal wire.
  7. Nov 20, 2019 at 9:12 AM
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    Since you are going through this anyway, you might want to consider mounting a toggle switch on the blue wire to the amp so you can switch off your amp to save your battery for starting if camping or parked for a few hours etc. I always do this when adding an amp these days.
  8. Nov 20, 2019 at 10:26 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Find the power wire that the deck uses to power on, and splice into that. Doesn't really matter which one, but you just need one that gets 12v when you turn the key to "accessory" (i.e. the radio turns on).
    The primary power for the amp should come direct from a fused link to your battery.
  9. Nov 20, 2019 at 10:58 AM
    Caleb george
    Caleb
    2000 toyota tacoma
    Yes I have tried the blue one up by my head unit and it didnt work I'll play around with it more later and I'll let you know if I figure it out, thank you for your suggestions.
  10. Nov 20, 2019 at 10:59 AM
    Caleb george
    Caleb
    2000 toyota tacoma
    Awsome I'll give that a try, thanks
