Amps for the 12v?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fightnfire, Jul 20, 2011.
  1. Jul 20, 2011 at 11:46 AM
    Fightnfire
    Fightnfire [OP] Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Anyone know how many amps the 12V stock power hook up in my 2009 Tacoma produces?
  2. Jul 20, 2011 at 2:09 PM
    azchris
    azchris Well-Known Member
    Gilbert, AZ
    2013 Magnetic Grey Dbl Cab 4x4 TRD OffRoad
    Click sig for build thread
    Are you talking about the power outlet under the stereo? I'm pretty sure 10A is standard for those.
  3. Jul 20, 2011 at 2:12 PM
    Fightnfire
    Marysville, WA
    Yes. I was "googling" and seeing a bunch of results but the range seems to be 10-15. A lot of products ie: compressors require 15. Just wondering what ours is..
  4. Jul 20, 2011 at 2:15 PM
    azchris
    Gilbert, AZ
    The inside of the cap on my 2011 says "120W Max", which would be 10A @ 12V. Unless the outlet isn't regulated to 12V, it could be a little less since the voltage could swing up to 13V. I haven't tested it with a multimeter.
    For compressors, I usually buy the kind that you can clamp right to your battery. It's a lot less of a hassle.
  5. Jul 20, 2011 at 2:32 PM
    Fightnfire
    Marysville, WA
    Agreed they're just getting hard to find. The Viair 90P is a decent one .. it comes with the alligator clamps to go straight to the battery.
  6. Aug 11, 2011 at 8:43 PM
    stretch85
    stretch85 Active Member
    Raleigh-Durham, NC
    2011 V6 4x4 TRD Sport
    The wiring diagram seems to indicate that the 12V accessory outlet is on a 15A fuse; however, it shares its circuit with the cigarette lighter as you might expect. My guess is that the 120W limit on the accessory plug cap takes into account the potential power draw of the cigarette lighter. So, if you can go a few minutes without a smoke it should be possible to draw up to 15A from the accessory outlet.
    That's my interpretation, anyway. Someone please call me out if I'm wrong. I'm not an electrician by any measure.
    And as for compressors with a direct battery connection, you can pick up an adapter like this one for cheap: http://www.amazon.com/Roadpro-Battery-Cigarette-Lighter-Adapter/dp/B00065L2D8/
  7. Aug 11, 2011 at 9:47 PM
    Fightnfire
    Marysville, WA
    Your first post is a wealth of information, thank you.
