AMSOil Bypass Filtration
Discussion in 'Technical Chat' started by High-Order, Oct 13, 2009.
  1. Oct 13, 2009 at 5:45 AM
    High-Order
    High-Order [OP] Active Member
    Stafford, VA.
    Silver Double Cab Off-road 4x4
    All-Pro Bumper, Icon Stage 4 kit, 16x8 Konig Countersteer's, 285/75/16 BFG A/T's
    I searched my ass off on here and couldn't find anything, so is anybody running an amsoil bypass filter set-up on there 05+? If so, what set-up are you using and how do you like it.
    Thanks!
  2. Oct 13, 2009 at 6:21 AM
    MassTaco
    MassTaco Well-Known Member
    Massachusetts
    V6 4x4 SR5 DC AT5
    Most people wouldn't bother with the bypass filtration set-up. It would only really be necessary if you were running 20-25k OCI's with a really high quality synthetic (such as amsoil). There are really only two reasons to do this:
    1) you really hate changing oil and want to do it as infrequently as possible.
    2) you drive 50k or more miles a year and can't spare the time to do monthly oil changes.
    Toyota engines will last 300k+ miles with 5-10k OIC's on mineral based or off-the-shelf sythetic oil and off-the-shelf filters so why go through the hassle and cost of the bypass system?
  3. Oct 13, 2009 at 6:49 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Added...
  4. Feb 11, 2010 at 7:33 PM
    def4pos8
    def4pos8 Well-Known Member
    Ohio
    White Tacoma AC 2.7L/5spd SR5
    undercoat, running boards
    I'm doing a bypass installation for Reason #1 and Reason #3.
    Reason #4 is that I want to make a best effort at providing my engine with the cleanest, coolest supply of lubricant possible.
    I just posted an introductory thread: "Ultimate in Oil Filtration?" here in Technical Chat. I'll do a follow-up once I install all that stuff.
  5. Feb 15, 2010 at 2:48 PM
    Boomtacoma01
    Boomtacoma01 Well-Known Member
    Houston
    09 BSP SR5 DC 4x4
    285/70/17 Dynapro MTs, Shrockworks front bumper, Armortech rear bumper
  6. Feb 16, 2010 at 8:23 AM
    def4pos8
    Ohio
    Thank you for the link.
    Sadly, my '10 has a pile of ABS plumbing where the engine bay install was done.
    Something on the radiator bulkhead may be possible but, again, I have an A/C condenser and additional shrouds compared to that particular 4Runner.
    The good news about these kits is that with sufficient oil lines, the filter block can be mounted almost anywhere.
  7. Feb 20, 2010 at 4:13 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    Adding complexity to the lubrication system on these trucks invites a problem, without solving any problem. The engine will last as long as the vehicle. In my opinion this type of mod is a bad idea. Now if the truck had a known issue, that would be a different story. IMO
