Amsoil gear oil 75-110, anyone using it?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WV_Tacoma, Dec 26, 2010.
  1. Dec 26, 2010 at 7:38 PM
    WV_Tacoma
    WV_Tacoma [OP] Well-Known Member
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    I was looking up some gear oils and ran across this Amsoil SEVERE GEAR® Synthetic Extreme Pressure (EP) Lubricant 75W-110
    I tow 5k # trailer, what do you think?
    thanks
  2. Dec 27, 2010 at 5:16 PM
    06TXED
    06TXED Well-Known Member
    Tony
    Kirkland WA
    2013 DCSB MGM TRD OR 4x4
    ADS RR 2.5 c/o, Camburg UCA, OME Dakar, ADS 2.5. LED interior light kit, Baja Designs LED fogs, LED headlights, Baja designs ditch lights w/ rago fab brackets, 20” armored LED light bar, Falken AT tires, KMC wheels, diff breather mod, All AMSOIL syn fluids, ARE shell linexed’ w/ FSR RTT, full debagged, shortened OEM antenna mod, Wet okle seatcovers, bird dog ind. mirror riser W/ RAM mount phone holder, and fog light any time mod.
  3. Dec 27, 2010 at 9:22 PM
    WV_Tacoma
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    my basic prerunner 4.o does not have the LS......:-(
    My personal mechanic said to use the Amsoil 110 SAE, which amsoil recommends for towing and stuff.....I think it has some LS stuff in it as well......
    I will be transfussioning my trany tomorrow, flushing with 15 qts and flushing the rear before I put the am to it.....
  4. Dec 28, 2010 at 9:22 PM
    WV_Tacoma
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    to get the record correct......
    LS means basically posi locking rearend....because my rear has a limit slipping wheel on the weak grip side....???????
