An idea i tried out today!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by myname150, Feb 2, 2011.
  1. Feb 2, 2011 at 1:10 PM
    myname150
    myname150 [OP] Well-Known Member
    So on the way to school, i saw a patch of ice on the road. I decided to try out one of my ideas at a low speed. (Don't worry, it was on a back road, and no one was on the road at the time) Excuse my crude drawings in GIMP :).
    I have a 08 PreRunner, so no Diff Lock, and no ALSD.
    1.) I noticed that if i drive like i normally would, my rear passenger side tire would just spin. I was still able to move, but very slowly. Like in the picture below, the blue bits is the ice.
    2.) So, the idea i had thought of a long time ago, i finally could test. I turned around and went back over the ice. This time though, i had the parking brake on, just enough to grab so the truck can very slowly move forward with out pushing the gas. As i started to put my foot down on the pedal, when i hit the small patch of ice, the wheel still spun a little bit, but i was able to get through alot smoother, with much less spin.
    From this i concluded that having the parking brake on just slightly, could simulate a locked diff, or limited slip. Imo, the only downside to doing this is that it could damage the rear drums, but i am not sure of that.
    I'd like yalls input!
  2. Feb 2, 2011 at 1:17 PM
    Pope953
    Pope953 That's a fact Jack!
    Wesley
    Asheville, NC
    SR5 Pickup
    35% up front, 20% in the back window tint, 15" Mickey Thompson bullet hole wheels, with 31x10.5 Firestone Destination A/T tires. Glass Pack, High Flow Cat, S&B CAI, Custom Light Bar with 4 fog lights. 2 10" Rockford Fosgate P2 subs with 1000 watt Rockford Fosgate Amp, CB.
    hmmm....i dunno. depends on how long you drove with the break on...
  3. Feb 2, 2011 at 1:19 PM
    myname150
    It was a small patch, so less then 30 seconds.
  4. Feb 2, 2011 at 1:20 PM
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    You don't want to know...
    I tried that without much luck one time when I had the rear wheel almost off the ground, but that trying to climb.
    I could see how that might work on ice though. Its basically simulating auto-lsd. You are helping transfer some power to the wheel that has traction.
    I wouldn't think it would really hurt anything seeing as thats exactly what the 09+ with auto-lsd do, they hit the brakes on each wheel individually.
    I do see it causing wear on the pads quicker though, which is what I don't like about auto-lsd.
  5. Feb 2, 2011 at 1:24 PM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    i think that is along the lines of atrac, except atrac is a little more complex than the parking brake haha
  6. Feb 2, 2011 at 1:27 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    known as a "poor man's locker"
  7. Feb 2, 2011 at 1:31 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Add another parking brake so you have one for each
    wheel!! :spy:
  8. Feb 2, 2011 at 2:33 PM
    JKD
    JKD Well-Known Member
    Yep, old school trick. You re-discovered it!
  9. Feb 2, 2011 at 2:57 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    Ya the "Poor Mans Locker" on the Tacoma usually works best using 2 clicks on the e brake pedal.
  10. Feb 2, 2011 at 3:03 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    ive used this method before on trails, works well enough
  11. Feb 2, 2011 at 6:45 PM
    SmokeEater
    SmokeEater Member
    JOHNNY
    Potomac Falls, VA
    2011 TACOMA
    K&N Drop-in Painted grill New TRD center caps & other little things here and there......
    I never had much luck using the poor mans locker... guess I have a heavy food! Good one to remember, though!
    btw - tell your kids, nice job on the pictures!! :D
  12. Feb 2, 2011 at 6:52 PM
    HomeGrown
    HomeGrown Well-Known Member
    Bill
    South Bend, IN
    2014 Reg Cab 4WD
    myname150, my guess is that in Houston you don't run across many ice patches very often. ;)
  13. Feb 2, 2011 at 6:59 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    This. I've been doing this for years- Not to try and get across ice...but offroad pretty regularly.
  14. Feb 2, 2011 at 7:08 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig...
    yeah, it's an old trick, but can work well depending on conditions.
    here's a video someone took of my at out off road meet two weeks ago. I have the factory limmited slip. specifically from 50 seconds to 1 minute in the video, you'll see my rear tire spinn and stop. that was me working the break. each time, the truck moves a little bit until it actually makes it....so it does indeed get the job done...sometimes
    http://www.youtube.com/watch?v=A2EhLK0w7_0
  15. Feb 2, 2011 at 7:12 PM
    tsab916
    tsab916 Well-Known Member
    Sacramento
    02 DC 4x4
    Learned something new today...thanks op for posting this up...might be a old trick but still new to some people
  16. Feb 2, 2011 at 7:27 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    colin, you need some tires man!!!!
    +1 though, I sometimes use it when I have a wheel off the ground to help the posi out.
  17. Feb 2, 2011 at 7:29 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    Was that Ocala?
  18. Feb 2, 2011 at 7:29 PM
    myname150
    haha nooo, i've only been driving since i was 15 (hitting 18 next month woo! :D) not once have i ever encountered ice on the road.
    Yeah, yall i tried this a while back with no success when i got stuck, but then again i probably was doing it wrong haha. It seems like this trick works sometimes...
  19. Feb 2, 2011 at 7:30 PM
    myname150
    No problem! lol, it was semi-new to me. Tried it a while back, didnt work. Tried it today, pretty aweeesome!
  20. Feb 2, 2011 at 7:31 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    they actually dig nicely 265/70/17 terra grapplers with 10/32 tread depth currently. i was the only one to make it up that section. i didn't have any traction problems the entire trip.
    however, my next tires will more than likely be a 285.
