An odd light switch problem....
Discussion in 'Lighting' started by Cmatt1605, Apr 22, 2011.
  1. Apr 22, 2011 at 5:43 PM
    Cmatt1605
    Cmatt1605 [OP] Well-Known Member
    Cody
    Mount Pleasant, South Carolina
    Squeaky leaf fix
    On my hella lights, my relay is 14V 40AMP. it came with a 250v switch. I have tried to put a more appealing switch in that was a 12V switch. Why will a 12v switch not work? I tried 3 seperate switches so i know that it cant be a bad switch. I also tried it on the lights with no relay. Why will a 12v switch, comming from a 12v battery, not power auto lights, but a 250v one will??? :confused:
  2. Apr 23, 2011 at 6:55 AM
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    There's an explanation in my electrical basics thread (link in my signature).
    Basically, you have to determine if the voltage rating of the switch is in VAC (alternating current) or VDC (voltage direct current, e.g. your car battery). The switch rated for 250V is likely rated for 250VAC...this is NOT the same as 250VDC! When you run high current through a switch, if you attempt to instanteneously interrupt the current flow, you'll produce an arc across the switch contacts. This will eventually destroy the switch contacts and/or melt the switch possibly resulting in a fire. Also, if you have sensitive equipment running off the switch, such as a stereo, the arc can destroy the equipment because you're essentially shooting a lightning bolt down the line.
    To further explain, some switches are actually rated for VAC and VDC. For example, a switch may be rated for 250VAC or 12VDC. This is because VAC, unlike VDC, naturally crosses 0 volts (VAC is a sine wave), thereby naturally preventing an arc from forming. This is way the same switch can be higher rated for VAC than for VDC. If your switch is only rated for VAC, find one that is specifically rated for VDC. They can be found at most auto parts stores and online ordering sites (e.g. digikey and mouser). However, if you are running low current through the switch at 12VDC, then you can get away with using a switch rated for VAC.
    Lastly, I highly do NOT recommend wiring your lights through the switch itself, always use a relay!! You could be introducing an unsafe situation. You can avoid all of the issues I mentioned above by using a relay...then you can use just about any type of switch to safely operate the relay...the relay will handle the arcing (just make sure you get a relay rated for VDC and the current your lights will be pulling). More info in my basics thread, it's worth a read...
  3. Apr 23, 2011 at 7:00 AM
    Cmatt1605
    Cody
    Squeaky leaf fix
    Ok thanks a lot! That explained a ton just in your post but i will read your thread, electricity is like a different world to me
  4. Apr 23, 2011 at 7:09 AM
    larryde09
    Larry
    Rochester, NY
    Glad I could help. You are a perfect example why I put that basics thread together....just trying to help out others since I have the electrical expertise. I get a lot of mechanical info from the site, but I noticed a gap in electronics that I could help fill. Feel free to PM me if you ever have specific questions.
  5. Apr 23, 2011 at 7:21 AM
    MillerMan06
    MillerMan06 Well-Known Member
    Adam
    Raleigh
    06 PreRunner SR5
    K&N Cold Air Intake,Running boards,bed cover,windows tinted, MagLite seat mount (A big Thankyou to piercedtiger for that one got it off cheap/free mods) extra 4 outlets on the 12V plug 3 12V plug in's and a USB all one box with toggles,48LED dome light (blue), Tail gate theft mod,Exhaust flowmaster super 44 with tips!!!!
    WOW!!!!!!!!!!! i thought I would have been able to fig somthing out to help on this one! But nope i just got schooled big time and my pops used to work for the power company and he has taught me some on this matter but you got me beat!!!! Glad your around!!!!! for real
