Andrew @ TRS 2014 Retrofit
Discussion in 'Lighting' started by TRSAndrew, Feb 7, 2014.
  1. Mar 10, 2014 at 12:43 PM
    #101
    TRSAndrew
    TRSAndrew [OP] Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    Got it! Replying now. :)
  2. Mar 10, 2014 at 12:45 PM
    #102
    jimmybee1108
    jimmybee1108 Well-Known Member
    JM
    San Antono
    2012 blk DC sr5 v6 prerunner
    bilstein 5100s, wheelers AALs, amazon dual 10 sub box, with two jlw1s cheap HIDs
    So now you got me looking at at least getting the ls460 ( not r )
    Projectors.
    My mini d2s keeps getting stuck in bright. So. Might as well.
    All is really need is new projectors right?
  3. Mar 10, 2014 at 1:15 PM
    #103
    TRSAndrew
    ATL
    You're going to have a very difficult time with anything other than the "R" version of the LS460, honestly. It is almost a perfect fit in this housing with the modifications, but without, it would be a nightmare.
  4. Mar 10, 2014 at 2:04 PM
    #104
    jimmybee1108
    JM
    San Antono
    So the extra dough is worth it huh
  5. Mar 10, 2014 at 2:16 PM
    #105
    TRSAndrew
    ATL
    Oh yes. It's the best of the best and it's also much more able to fit in odd places: my Subaru, 4Runners, FJ Cruisers, now a Crown Vic!
  6. Mar 10, 2014 at 2:19 PM
    #106
    jimmybee1108
    JM
    San Antono
    Wow! Sounds worth it.
    What would you say comes in second place??
  7. Mar 10, 2014 at 2:29 PM
    #107
    TRSAndrew
    ATL
    From there... probably a tuned RX350
  8. Mar 10, 2014 at 4:03 PM
    #108
    jimmybee1108
    JM
    San Antono
  9. Mar 10, 2014 at 9:11 PM
    #109
    Jwheeler
    Jwheeler Active Member
    Josh
    Washington
    trd off-road sr5 leveled
    Leveled with 33's
    I'm really wanting to do the ls460 but I am a little nervous to spend all that dough on the lights and projectors and screw some thing up on the retrofit. How difficult is this retrofit to do.
  10. Mar 11, 2014 at 3:13 AM
    #110
    TRSAndrew
    ATL
    It's not much worse than an FX-R, honestly.
  11. Mar 11, 2014 at 8:36 AM
    #111
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    And if I can do it, anyone can. Take the headlight out, bake it, I use 250*F for 10 min, and pry the lens off after removing the 3 Torx screws on the outside edge of the light. Unscrew the bucket from the adjusters, this takes time, as the adjusters are long. Use an 8mm socket if you can. Test fit the projectors, to see where you need to cut. I used a 2" hole saw on the opening, and cut down with a dremel where the motor for the highbeam controller goes. You can use JBWeld to hold the projector in place, and four long bolts with jam nuts to secure for a shake free fitting. Let everything set up, including however you're going to mount the shrouds to the projector, I used JBWeld, and it's held quite well. Bake the lights again for 10 min, and use clear silicone sealant as well. Squeeze the lights back together, and put the 3 Torx screws back in. All in all, to get this done right, it takes a day to do, but the payoff is worth it.
    That was for FX-R projectors, and I'm really happy with my results. Much better than stock lights. Don't forget to aim them when you get it all back together, or you may be blinding oncoming traffic.
  12. Mar 11, 2014 at 9:28 AM
    #112
    Jwheeler
    Josh
    Washington
    Leveled with 33's
    Ok thank you for the detailed directions sounds like its do able just need to order every thing and do it. Do tacoma world members get a discount on TRS by chance
  13. Mar 11, 2014 at 10:16 AM
    #113
    ZMan2k2
    Richard
    Under a tinfoil hat
  14. Mar 11, 2014 at 10:43 AM
    #114
    TRSAndrew
    ATL
    Not for LS460R parts, unfortunately. Only Stage III kits.
  15. Mar 11, 2014 at 6:20 PM
    #115
    rcscoot2539
    rcscoot2539 Member
    scott
    pitts pa
    So its been a while since i've been on here, getting ready for stage 2 of the build and I want these headlamps. Can I order them already installed? Thanks Scott
  16. Mar 12, 2014 at 2:36 AM
    #116
    Jinseiganai
    Jinseiganai Well-Known Member
    hawaii
    ???? BSP XR
    Whats better, ls430 or ls460? What has the best beams? I know the 460 is Bi where 430 is a LBO
  17. Mar 12, 2014 at 3:24 AM
    #117
    TRSAndrew
    ATL
    Yes absolutely. In fact, the picture at the top of the page is for a second pair I'm making for a customer along-side mine. Please email directly at andrew@theretrofitsource.com and I'm glad to provide pricing.
    LS430 is probably slightly better because of the reflector on the bottom, but I'm just a fan of how the LS460 looks in the housing--nothing like it!
  18. Mar 12, 2014 at 5:11 AM
    #118
    Jinseiganai
    hawaii
    ???? BSP XR
    I couldnt agree MORE! I wanted the best Beam so I have the LS430s, but there are times I wish I got the LS460 just for the peace of mind of having High Beam, (even though I probably will HARDLY EVER use it) and also I have the philips 85122+ is it worth paying a extra $200 to get the CBI's or is it too slight of a difference to upgrade(bang for your buck i guess is what Im trying to ask) ?
  19. Mar 12, 2014 at 5:42 AM
    #119
    TRSAndrew
    ATL
    I personally think so, yes. We all run them here as well!
  20. Mar 12, 2014 at 6:20 AM
    #120
    InSight Retrofits
    InSight Retrofits Closed
    Don't forget about the pictures Andrew :D:D:D:D
