Angelina Jolie Double Mastectomy
Discussion in 'Off-Topic Discussion' started by Krazie Sj, May 14, 2013.
  1. May 15, 2013 at 9:19 PM
    denali climber
    denali climber Well-Known Member
  2. May 15, 2013 at 9:23 PM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Because most people who are tested have presented with symptoms that indicate cancer.
  3. May 15, 2013 at 9:27 PM
    joes06tacoma
    Joe
    Central Coast, CA
    This.
    I know someone who went through the same choice and procedure. Her sister is ten years older and had cancer. She had the genetic test and chose to take them off. From what I hear, the recovery isn't easy. It may well have extended her life and saved her from chemo.
  4. May 15, 2013 at 9:40 PM
    denali climber
    either way, the numbers jolie referenced dont appear to be scientifically sound.
  5. May 15, 2013 at 10:02 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    I personally think the numbers surrounding cancer are difficult in the same vein that each cancer diagnosis is different than the last or the next. Which is to say any discussion of numbers in the general context has to be well qualified.
    Sure, you might have pancreatic cancer but why do some live only a short while after diagnosis while others live well past the 95th percentile (even when the tumor size/location/etc are similar)? Why do some tumors respond to different treatments differently? This is why I say well qualified.
    I'm sure that Jolie and her physician discussed the numbers based on whatever testing was done (at least I hope so). And I hope she was given the proper context of those numbers.
    Hope that makes sense.
