Angled winch connector
Discussion in '1st Gen. Tacomas (1995-2004)' started by AKsavanaman, Dec 8, 2017.
  1. Dec 8, 2017 at 11:41 AM
    AKsavanaman
    AKsavanaman [OP] Well-Known Member
    Lower 48 :( U.P MI
    01' Xtra Cab TRD, Kings, JBAs, Dakars and 295's on F5
    Kings, JBA's, Dakars, Prinsu Rack, ARB, Trail gear sliders... and rust
    I've exhausted my vocabulary and searched to no avail...
    I'm looking for a 90° angled winch controller/connector, space is tight up between my lights and control box and I can't connect my standard controller. I've got a hard wired switch in the cab, but for some tasks... Like respooling the winch myself... I want to be able to connect my standard one. Any products out there I'm too dumb to search for? It's a 5 pin btw
  2. Dec 8, 2017 at 11:56 AM
    Finch1018
    Finch1018 Well-Known Member
    Hampton Roads VA
    2015 DCSB TRDOR
    Build Thread: https://www.tacomaworld.com/threads/finch1018s-15-dcsb-build-thread.489528/
  3. Dec 8, 2017 at 11:59 AM
    jbrandt
    jbrandt ......LOADING
    Justin
    Sacramento, CA
    '04 TRD Tacoma 4x4 DC
  4. Dec 8, 2017 at 12:01 PM
    AKsavanaman
    Lower 48 :( U.P MI
    Didn't think about wireless, def an option... I bought a similar angled adapter for my cb coax cable I figured something existed for winch controllers
  5. Dec 8, 2017 at 12:04 PM
    AKsavanaman
    Lower 48 :( U.P MI
    When I took my solenoid box apart to wire my cab switch, I only had three wires going to the connection point, figured they just use a 5 pin as a standard connection
  6. Dec 8, 2017 at 12:10 PM
    Finch1018
    Hampton Roads VA
    2015 DCSB TRDOR
    Agreed, I have a 5 pin as well, haven’t looked in the solenoid box yet. Now I’m considering this...$$:facepalm:
  7. Dec 8, 2017 at 12:24 PM
    Dirty Pool
    Dirty Pool I WAS DRIVING THAT MODEL A
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    I have a wireless fob and the cable pendant as a back up. Space was a little tight with the under hood mounted control box.
    A razor knife, some self vulcanizing tape and a zip tie did the trick. Careful with the razor, a heat gun might have also done the trick.
    AKsavanaman [OP] likes this.
  8. Dec 8, 2017 at 9:28 PM
    AKsavanaman
    Lower 48 :( U.P MI
    Well thanks @Dirty Pool for giving me the idea, and the mod cost me 0$!!!!
    You can see there ain't much room!
    The original connector
    I cut the metal sleeve with a dremel and kept the rubber grommet.
    Now I bent the wires, pulled the grommet up and started globbing liquid tape over it...
    And here she is all dry, I'll prob add some electrical tape to reinforce, but I'll only be using this every once in while, I think she'll suit my needs perfectly!
    lukester78 likes this.
  9. Dec 9, 2017 at 4:44 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I think my approach would have to just run a pigtail out of the winch .
    Making your connection some place easier to access with more room
    Doing things like this for work all the time it was my first thought
    Arctic Taco likes this.
  10. Dec 9, 2017 at 9:09 AM
    Dirty Pool
    99 XCAB V6 MT TRD
  11. Dec 9, 2017 at 9:23 AM
    AKsavanaman
    Lower 48 :( U.P MI
    That was some nice work! My original plan was to relocate the box into the engine bay, but I was too lazy to build a new harness:rolleyes:. I was also playing around with locations and couldn't come up with a good spot... Since I've got plans for a GP31 in the original spot, a 34 on the pax side and my air compressor stuffed somewhere that's currently under the back seat.
    Dirty Pool likes this.
  12. Dec 9, 2017 at 1:21 PM
    Indy
    Indy Master of all I survey.
    I would just move the solenoid box over an inch and called it a day.
  13. Dec 10, 2017 at 11:05 AM
    AKsavanaman
    Lower 48 :( U.P MI
    I already had to modify the mount and box to make it work in it's current location.... This was easier l, trust me
