annoyin as hell
Discussion in '2nd Gen. Tacomas (2005-2015)' started by johnw, Oct 20, 2009.
  1. Oct 27, 2009 at 1:48 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Here's a tip I have seen on a car related tv show and on the internet. I'm not sure how well it works but It's worth a shot.
    You will need some 1.) grease or packing grease, some 2.) Duct tape, 3.) black chassis paint, and 4.) jack stands/car lift etc.
    Jack the truck up and put the stands under the rear part of the frame so the rear of the car is lifted up, so the leaf springs are not compressed.
    Then clean off the leaf springs with water and dry with an old rag. Then you will start to pack the leaf springs with grease on both sides. And then you will need to lightly (not too tight) wrap the leaf springs with the Duct tape.
    After that you want to drive around for a week or two on the streets, but don't do any off-roading or go around corners real fast. This will allow the grease to pack itself into the leaf springs.
    And finally you want to take off the Duct tape, then wipe off any excess grease. Then spray the leaf springs with the black spray paint, so It's harder for dirt and grime to come back in.
    It's worth a shot, but I have not done this so I don't know how good it will work, good luck.
  2. Oct 28, 2009 at 12:04 PM
    jgreen205
    jgreen205 Member
    Houston
    06 PreRunner
    Double Pinstripes Black Westin Side Steps Color Keyed Door Molding Weather Tech Floor Mats 35% Tint Toyota Fog Lights Chrome Grille
  3. Oct 28, 2009 at 12:08 PM
    jgreen205
    jgreen205 Member
    Houston
    06 PreRunner
  4. Oct 31, 2009 at 7:46 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
  5. Oct 31, 2009 at 8:52 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    use chain lube for atv,it last a longtime.:d
  6. Aug 6, 2011 at 1:26 AM
    completenirvana
    completenirvana Well-Known Member
    Clarkston, WA
    07 Tacoma SR5 V6 Offroad DBL Cab
    K&N Cold Air Filter
    Good posts. Mine just started to squeak but it's covered in mud right now so hopefully washing it will get rid of that annoying sound. I feel like I'm driving around an old chevy when it squeaks like that.
