Annoying "chirp" After starting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mquinnan, May 3, 2012.
  1. May 3, 2012 at 9:01 AM
    mquinnan
    mquinnan [OP] Member
    Michigan
    06 Tacoma
    I have a 2006 Tacoma TRD that makes an annoying "chirp" sound shortly after the truck is started, and, only after I put it in gear and drive either in reverse or forward for appx. 20 feet. It makes this sound only once, and does not occur again unless I turn the ignition off and then restart, and move a short distance. It happens everytime I start the truck and roll. Any Ideas?....ABS possibly? Please advise.
  2. May 3, 2012 at 9:09 AM
    mquinnan
    Michigan
    06 Tacoma
    Absolutely a "chirp" or a "doink" sound. A little unnerving!
  3. May 3, 2012 at 9:17 AM
    mquinnan
    Michigan
    06 Tacoma
    No, it happens w/heater, AC, on or off the same
  4. May 3, 2012 at 9:22 AM
    nfs257
    nfs257 Well-Known Member
    Menifee, Ca -> Tucson, Az -- April
    09 DCLB PreRunner MGM SR5 Debadged
    Trac Performance built Prerunner
    Video of the sound?
  5. May 3, 2012 at 9:57 AM
    mquinnan
    Michigan
    06 Tacoma
    will try again in an hour or so. On first attempt, had camera mounted over motor....to much motornoise. Second and third try noise was barely audible on trac(noise also was quieter, but still there on subsequent tries). will let it rest and try again in an hour or so, hopefully it will be more discernable then. Please hang in there.
  6. May 3, 2012 at 11:12 AM
    2011Streaker
    2011Streaker Well-Known Member
    Maine
    2012 DCSB TRD Sport
    Abs self test, it's normal
  7. May 3, 2012 at 12:07 PM
    mquinnan
    Michigan
    06 Tacoma
    Could you give me a brief explanation about what that is? I have a Prius and it doesn't do it.
  8. May 3, 2012 at 2:18 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    i was pleasantly surprised to find that the owner's manual mentions it. they call it "a noise". my 06, humms..like an old man whispering, "humm". i've gotten used to it, and i LIKE it. my wife and i can time it perfectly and we all "humm" in unison. retarded, yes..but fun..and much better than obsessing about it.
  9. May 3, 2012 at 2:56 PM
    Tac 2009
    Tac 2009 Well-Known Member
    black 09 SR5
    ^your talking about the fan switch at the start right?
  10. May 3, 2012 at 4:05 PM
    mquinnan
    Michigan
    06 Tacoma
    no. not the fan. a distinct doink or chirp noise. It happens only after i start, put it into gear and then move appx 20 feet. never thereafter if it continues running. If i shut down and move the truck, it happens again.
