Annoying electrical issue with turn signal
Discussion in '1st Gen. Tacomas (1995-2004)' started by Trapperr, Jan 27, 2019.
  1. Jan 27, 2019 at 4:59 AM
    Trapperr
    Trapperr [OP] Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    So when I drive at night with my headlights on, my left turn signal stays illuminated. It doesn't flash and it won't go off until I turn the headlights off. It happens 3 out of 4 times I drive with my headlights on.
    Anyone have this before or have an idea where should start looking?
  2. Jan 27, 2019 at 5:01 AM
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
    2001 XtraCab Tacoma TRD 4x4/2004 SR5 V6 4Runner
    Tacoma: Badlands basher front bumper Trail gear rear bumper Trail gear sliders OME Dakar’s OME 883 Coils Bilstein 5100s front Bilstein 5125s rear SPC Upper Control Arms Wheeler’s Extended brake lines ProComp 51 Series 15x8 3.5” BS 32x11.50x15 BFG KO2’s Honda CR-V windshield washer nozzles Hella 500FF fog lights Energy Suspension power steering rack bushings 4Runner: Hankook DynaPro ATM RF10 265/70r17’s TPMS Bypass mod RCI Skid Plate CBI Ditch light brackets 1.25” Wheel Spacers 2” Front Leveling Kit
  3. Jan 27, 2019 at 5:05 AM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    I think there was thread on TW about this same issue, something to do with the trailer connection. good luck OP
  4. Jan 27, 2019 at 9:03 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Quite possible the headlights are grounding back through the left turn signal .
    When you use the left turn signal do all the lights blink??( head lights dash lights tail lights)
    Can`t hurt to check if you have a trailer converter box causing the problem
  5. Jan 27, 2019 at 9:28 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I had a similar problem that turned out to be a bad aftermarket trailer light wiring harness.
