annoying rattle in dashboard
Discussion in '1st Gen. Tacomas (1995-2004)' started by mjmsms69, Jul 16, 2008.
  1. Jul 16, 2008 at 2:29 PM
    mjmsms69
    mjmsms69 [OP] Member
    02 tacoma double cab
    custom wheels tonneau cover bed liner nerf bars
    I have an 02 double cab Tacoma that has a rattle in the dash on the passenger side, on top where the airbag is. Has anyone had this problem? If the airbag unit is loose, how do I get up in there to tighten it? The rattle seems to be coming from the top of the dash above the glovebox.
  2. Jul 16, 2008 at 2:32 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    maybe some stuff dropped into the defrost vents.
  3. Sep 6, 2008 at 5:54 PM
    Dustin03
    Dustin03 The Cooler King
    Arizona
    Expeditionary vehicle in training.
    Old Man Emu 2.5" lift, brush guard (about to be changed), grey-wire mod, custom bed mounts for 4 jerrycans, custom survival box, maglite mount, KC Dayliters.
    I have an 03 xtra cab that makes the same noise. Haven't been able to figure out the issue but I'm fairly certain you have a good diagnosis. When the dash starts to rattle I can get it to stop by holding my hand to the airbag cover and applying a bit of constant pressure. If anyone knows how to get that cover off without the bag blowing up in my face, I'm pretty sure I can get the rest figured out. Anyone?
  4. Sep 6, 2008 at 8:00 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    mine rattles
    im pretty sure this is a recurring problem in the 01-04 tacomas...
    my fix is to roll the windows down and turn the music up
  5. Sep 6, 2008 at 10:08 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    Mine rattles like a baby on crank. I can stop it with one fingers pressure right in the center of the dash, about 6 inches back from the dash edge.
    My daughter also noticed pushing on the passenger airbag will stop it.
    Planning on pulling the console out tomorrow (oops today) and seeing if I can finger it out.
  6. Sep 7, 2008 at 9:14 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    My 2000 did it from day one until the day I traded her in on the '08. I never could stop that stupid rattle. :(
    -Dan
  7. Sep 7, 2008 at 9:33 AM
    TheOriginalTXTACO
    TheOriginalTXTACO Active Member
    San Antonio, TX
    Unfortunately No More
    3" lift, Extreme LineX, Extang Toolbox Tonnoe, UWS Box, MB Wheels, BFG AT's.
    Pushing in a piece of black foam weatherstripping between the glass and the dash has helped, I first used a piece of door weatherstripping but it did not stay in place as well. with the black you don't see it and it quite's it all down.
  8. Sep 7, 2008 at 10:11 AM
    RealSouthernPride
    RealSouthernPride Well-Known Member
  9. Sep 7, 2008 at 1:53 PM
    tdm156
    tdm156 Well-Known Member
    San Antonio, TX
    2009 DC 4x4 SR5**Sold
    I have one of those coming from the passenger side dash when on a rough road. I also have this buzzing noise coming from that side of the truck as well. I hae 2500 miles on my 09 and had it in for the buzzing noise once but didnt have time to leave it with them to figure it out. So they will get to figure that one out along with the loud rattle in the dash. :(
  10. Sep 7, 2008 at 1:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  11. Sep 7, 2008 at 2:07 PM
    JimBeam
    JB
    2015 Tundra
    aha! thanks chris...i knew i had seen something on it over there at CT...just hadnt had time to find it for these folks
    again...my solution seems to have worked...as i didnt hear it at all today
    ive also got a bunch of other rattles associated with other things ive done to or in my truck...they seem to have made the dash rattle rather unnoticeable :eek:
  12. Sep 7, 2008 at 2:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I find the same thing happening to/in my truck. My Wife is starting to assign them names.:eek: For example, small "thumping" sound when I hit sharp bumps she has named "Steve", while a higher pitched rattle comming from the rear is named "Leo". SHould I be worried about her?
  13. Sep 7, 2008 at 2:16 PM
    JimBeam
    JB
    2015 Tundra
    everything seems to stem from my tires being both out of balance and misaligned
    it makes everything rattle...but occasionally gets the front end to rattle enough that the bumper and front drivers fender make contact...oooh what a noise
  14. Sep 7, 2008 at 2:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    lmao!!!!
  15. Sep 7, 2008 at 2:22 PM
    JimBeam
    JB
    2015 Tundra
    you laugh...but its seriously BAD
    i cant wait till these bfgs get here tomorrow and i can go get them put on my new rims and get those bad boys on...once the tires are in balance and aligned and i no longer have cupped front tires...that should eliminate a good bit of rattle and let me find out where the rest of it really is
    on top of the rattling...my suspension squeaks like theres no tomorrow
  16. Sep 7, 2008 at 2:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Might sond strange, but the best thing I have found to cure suspension squeeks is break fluid. Just dont get it on your paint. :D
  17. Sep 7, 2008 at 2:27 PM
    JimBeam
    JB
    2015 Tundra
    ive heard that before...i just dont have any...but i do have 3 cans of wd-40
    i know HOW to fix it...i just dont have the time/energy/motivation/$$ to do so
    the source of the squeak is the lower bushing on the front coils...
  18. Sep 7, 2008 at 2:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im tellin ya, Buddy, a small squirt of break fluid and you wont hear from it again! My squeaks just laugh at WD-40, but they are silenced with a liberal squirt from the B F. :)
  19. Sep 7, 2008 at 2:33 PM
    JimBeam
    JB
    2015 Tundra
    i guess i just need to head up to vatozone and buy some brake fluid then
  20. Sep 7, 2008 at 4:58 PM
    HerNameIsLucy
    RIP Lucy.
    Ok, my kid got this one right. I yanked the radio bezel out, since I could stop the rattle with just one finger about six inches from the front of the dash, dead center.
    First thing I found was the center air duct was rattling. There's a metal mounting bracket at the bend in the duct, adjusting that fixed the rattle I could stop with my finger.
    But it still buzzed. Sure enough, loosening and re-tightening the airbag assembly stopped it.
    It appears the previous owners (or some poor service tech somewhere) was driven nuts with this rattle. There was a piece of rope gasket, and a piece of a pencil, and a bunch of foam tape all over the place behind the radio bezel.
    Buzz free, for now. We'll see when the temp is below 90 tomorrow morning if I got all of them. Looking at the TSB chris4x4 posted it appears there's a bunch of places in there causing problems.
    Also painted my calipers today, red to match the truck, looks sweet!
