Another 4X4 problem!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaFishRig, Mar 12, 2014.
  1. Mar 12, 2014 at 7:54 PM
    TacomaFishRig
    TacomaFishRig [OP] Member
    Idaho
    '08 SR5 Double 4x4 Auto
    Stock 265/70/R16
    Hey everyone! I am new to the forum and new to my 2008 Tacoma SR5 Double Cab V6 Auto and Hope to have 4x4 again! This is my first Toyota and have been a Ranger Owner since 2002. My last ranger which I have up for sale had 255,000 miles on it and still is one of the best truck on the road. I needed more room in the cab and I have been drooling over Tacomas for years. I do 95% of my own work on my truck and just want a reliable truck. I love my new tacoma!
    Now the the question.... ANOTHER 4x4 problem... I have searched and searched and searched and I can not find any thing that sounds like what I have have going on.
    Everything drives great and no warning lights of any kind. I switch the dial to 4hi and the light starts to blink and I can hear the rear actuator engage and when I am driving I can hear and feel a slight clunk but the light still blinks. Following all the proper steps and try to go to 4low the beeping starts. As soon as I flip back to 2hi the lights and sounds are gone.
    I have tried going forward and back straight and turning the wheels and also try turning the 4hi while the truck is of and nothing changes. I crawled under the truck and I could feel and hear the rear actuator move and the front diff actuator beeped while the 4hi was trying to engaged !?! but there was not any movement or vibrations that tell me it moved.
    Thanks for any Ideals?
    Anyone have to mess with the two switches on the rear actuator?
    Thanks
    TacomaFishRig
  2. Mar 12, 2014 at 8:31 PM
    Alexfiggy
    Alexfiggy Well-Known Member
    Alex
    Miami
    Trd off road
    In 2 hi stop the truck put in neutral then engage 4 hi put back into drive . See if that works.
  3. Mar 12, 2014 at 8:39 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    this pertains to the diff actuator.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/263525-how-trouble-shoot-4x4-actuator.html
    I hope it is not your issue, but it very well could be. sometimes the front actuator can be troublesome. try it at varying speed, throttle on/off, turning, stopped, etc. I have found that if you try for 4lo without first having 4hi, it just results in trouble. not the best 4wd system ever, I miss my j-pattern and manual hubs
  4. Mar 13, 2014 at 6:57 AM
    TacomaFishRig
    Idaho
    Stock 265/70/R16
    I tried the Neutral thing and nothing different. I am going to take the cover of the front diff actuator tonight and see what I can gain from that! I have read the front diff actuator post and it sound like that if the light always blinks even when in 2hi that it is the front actuator that has the problem. My does not blink unless I switch to 4hi. Maybe I am just missing something.
    Thanks
    TacomaFishRig
  5. Mar 13, 2014 at 7:04 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    did you buy from private party or dealer?
    if dealer have them fix it for free since the 4wd "function" is not operational :)
  6. Mar 13, 2014 at 8:18 AM
    TacomaFishRig
    Idaho
    Stock 265/70/R16
  7. Mar 15, 2014 at 11:19 AM
    TacomaFishRig
    Idaho
    Stock 265/70/R16
    So I just got done removing and soldering and reinstalling the front diff actuator. The inside of it was perfect! No sign of anything that should not be there. This was not that hard of a job. I used a 10" 3/8" extension and stepped that down to and 1/8" knuckle and then the socket and I got all four bolts out pretty easy and quick.
    Topped up diff Fluid.
    Bad News.... This did not fix my problem! Now the light on the dash blinks all the time!
    If I take the actuator out again can I test the little motor but running leads to the main truck battery?
    Any Thoughts?
    Thanks
  8. Mar 15, 2014 at 11:30 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    The ADD (Automatic disconnecting differential) is likely not working (vacuum line bad?). The ADD is what changes the free wheeling front hubs to being locked to the front driveshaft when you engage the transfer case. ADD replaced Automatic Locking Hubs, which required driving in reverse to unlock. The 4WD light goes from flashing to solid once you really are in 4WD. The same is true of the rear locker... flashing to solid when locked.
    Normally, H2 to H4 is shift-on-the-fly up to 60 mph-ish.
    Only going into and out of L4 requires stopping and shifting into NEUTRAL (not Park).
  9. Mar 15, 2014 at 11:52 AM
    TacomaFishRig
    Idaho
    Stock 265/70/R16
    Isn't the ADD and the Actuator on the front diff the same thing?
  10. Mar 15, 2014 at 2:49 PM
    Supramacy
    Supramacy Well-Known Member
    The actuator is a part of the A.D.D system. But I would guess that the A.D.D system is acting up, There is a procedure for checking the movement of the actuator with a battery and a relay which will determine if the actuator is defect or not. You have to use a relay when checking the actuator because direct voltage applied will damage the unit. I'll try and find the procedure online for you and post it up.
  11. Mar 15, 2014 at 4:03 PM
    joes06tacoma
    Joe
    Central Coast, CA
    When you request (funny how we have to ask for everything these days:mad:) 4WD, the computer first shifts the transfercase, then the ADD actuator.
    You should be able to determine if the driveshaft is locked in at the transfercase just as you normally would if dealing with an all manual system.
    Checking the actuator motors with a battery would be one thing to try, I'd imagine they don't like to be left on for a long period of time, so be careful.
    There are electric motors in both actuators, and several sets of contacts serving as limit switches. The computer must be able to shift the transfercase, verify the shift actually took place, then shift the ADD, verify that the ADD engaged, only then will you be in 4WD with a steady green light. Any bad switch contact or a bad motor will cause a problem. If you stared at a wiring diagram long enough you could likely figure out how to test each limit switch contact, as well as the actual motors.
    I don't know if a Toyota dealer would be able to use their scantool to pinpoint what is actually going on in there or not. Not sure if the 4WD computer communicates with the PCM/OBDII port. A standard code reader isn't going to help.
    No vacuum going to the front diff on this truck, all electric.
  12. Mar 15, 2014 at 4:20 PM
    TacomaFishRig
    Idaho
    Stock 265/70/R16
    Thanks for the additional info. I talked to a Toyota dealer today on the phone and he told me that it will probably one of the two switched on the rear t-case actuator. He also told me that if you test them with and ohm meter that they should not test over 1 ohm. If they do test higher then there bad. So I am not anything close to an electrician but I tried testing them and I the ohm meter jumps when I touch the prongs and then settles to back to 0. I am lost on this.
    He also told me that you can jump the switches. I jumped them both and the read did nothing but then I jumped the front one the 4x4 light stayed solid and the 4low blinked.
    With everything back together I can switch the truck to 4 hi when it is off and then start the truck and the rear t-case motor will lock in(I can't turn the front drive shaft with my hand) but to get it to disengage I have to turn the truck of and snitch the switch on the dash back to 2hi.
    Still lost
  13. Mar 15, 2014 at 5:00 PM
    David K
    4 Lo will blink if you don't put the tranny in NEUTRAL before turning the dial to L4. Not P Park, but N Neutral.
  14. Mar 15, 2014 at 7:37 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Well, you know the actuator motor on the t-case is working now.
    Since the 4wd light is supposed to only go solid once the transfer and ADD have both shifted, it sounds like the transfercase actuator switches are bad. When you bypassed the switch and the light went solid, maybe the computer saw the transfercase engaged and shifted the ADD? Not sure about the 4LO light in that situation, but if you were jumping more than one switch at the same time, the computer could get confused.
    If it were me in that situation, I would probably go with the voice of experience and change the transfercase actuator. OR, possibly try to take it apart and clean it? Not sure if that's even possible. I have never dug that deep into my Tacoma.
  15. Mar 15, 2014 at 7:43 PM
    TacomaFishRig
    Idaho
    Stock 265/70/R16
    Joes06! You make a good point and until I read it, it wasn't apparent to me. If the light was solid then it shifted! GOOD NEWS. I am going to order the front transfer case switch on monday ($90 Dealer) I have not found these aftermarket.
    Lets get 4 Hi and go for low later!
    TacomaFishRig
  16. Mar 15, 2014 at 11:22 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Good luck! Good troubleshooting too!
  17. Mar 17, 2014 at 4:06 PM
    TacomaFishRig
    Idaho
    Stock 265/70/R16
    Good News! So the light on my 4x4 was still flashing today and after work I drove for about 45 mins and I noticed that it had STOPPED!! So I click the switch to 4hi and it WORKED!! So I stopped on gravel and put it into neutral and switched to 4lo and it also WORKED!
    Not sure why! I was thinking that maybe when I was messing with the switches and ADD that I set a code in the computer that finally reset with a certain amount of miles!
    Hope it stays working!
    Thanks for the help
    TacomaFishRig
  18. Mar 18, 2014 at 12:14 PM
    92dlxman
    Kevin
    Visalia, CA
    glad it worked out for you! keep us posted if anything comes up again
  19. Mar 18, 2014 at 4:19 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    $90 is crazy for little ball on the stick. Not long ago those were $5. I should have bought a case and hold on to them. Better investemnt than stocks.
