Another 5100/lift Question
Discussion in 'Suspension' started by yote38, Feb 13, 2009.
  1. Feb 13, 2009 at 6:48 AM
    yote38
    yote38 [OP] Member
    New Mexico
    09 DC 4X4 TRD Off Road
    None
    I have a 2009 double cab TRD Off-Road 4.0 4X4 and want to level out the front and run 265/75/16's. I want to lift the front 1 1/2 inches to be level. If I go with the 5100's, what should I set them at? I have read that the ride will be better with these shocks but nobody really describes what "better" really means. Are they stiffer? Is the ride more cushiony? In what way is it better? Will I need UCA's with just this much lift? Can I get the alignment in spec without new UCA's? I have read here that many peoply are experiencing vibrations after lifting their trucks. Has anybody experienced problems with just a 1.5" lift? I don't want to have to spend $2000 just to have a 1.5" lift. Thanks for your help.
  2. Feb 13, 2009 at 6:56 AM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    If you're just taking the front up 1.5", then set the billys at .85". You won't need new UCAs with that little bit of lift.
    And I don't think you'll have trouble with vibrations.
  3. Feb 13, 2009 at 7:00 AM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    Mine is set at 2.5. the ride is stiffer at 2.5 you can get away without ucas but the alignment shop told me mine were maxed out. my truck leaks slightly to the right. I will eventually get ucas. I got about 3 inches out of the lift (2.5 for the billys and the going to the larger tire) i had the crap 245 dunnys on before. If you are going to go only 1.5 you my not experience the same things. I will also probably get some springs in the future.
  4. Feb 15, 2009 at 12:27 AM
    Bolo
    Bolo Well-Known Member
    San Diego
    2007 TRD Offroad
    Billet grill, nerf bars, TSB, Bilstein 5100s, Pioneer deck, Access Literider, shorty antenna
    This may be off topic, but I'm going to get the 5100s as well but not sure if I should get front only our all four. My goal is to level out my truck, so I'm wondering what benefit would there be to replace the rear shocks? Would changing out the rears make a tangible difference?
  5. Feb 15, 2009 at 1:32 AM
    yote38
    yote38 [OP] Member
    New Mexico
    None
    Changing out the rear shocks would not change the ride height.
  6. Feb 15, 2009 at 8:40 AM
    LonghornTaco
    Minnesota
    Correct. The rears don't change the ride height, but a lot of people say the ride is A LOT better than the stock shocks. I didn't notice a difference, but I don't haul anything either...
