Another BIG Brake Kit Option BBK OMG!
Discussion in 'Automotive Group Buys' started by jamesepoop, Jun 5, 2019.
  1. Aug 31, 2023 at 2:47 PM
    #101
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    How do you like the set up?
    KeezfB likes this.
  2. Aug 31, 2023 at 2:56 PM
    #102
    TegoTaco
    Ontario, Canada
    Can you still use the Tacoma backing plate with some cutting of course?
  3. Aug 31, 2023 at 3:56 PM
    #103
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    The wilwoods were nice. they are a 4runner caliper if you go with the rr racing kit. Since your a sport you can upgrade the master. I did not have that option but overall it was nice. but not creazy since I'm so heavy. you can also get the willwood kit direct that's setup for a tacoma and comes with 2 piece rotors.
  4. Aug 31, 2023 at 4:04 PM
    #104
    TegoTaco
    Ontario, Canada
    So for the money, you weren’t impressed? I’m about 5000-5100lbs not including me in it.
  5. Aug 31, 2023 at 5:04 PM
    #105
    nudavinci64
    Robert
    No I liked it. I am sitting closer to 7k lbs fully loaded so way different scenario. I have since swapped all of my brakes to Stoptech front and rear (mainly since I had the stoptech rear and selected a Tacoma spec piston since I do not have any options to upgrade master).
    The front only combo and the willwood with rear stoptechs was nice.
  6. Sep 1, 2023 at 2:39 AM
    #106
    TegoTaco
    Ontario, Canada
    Would you say it’s worth it for my situation and big improvement? I’m debating these WILWOODS or the ALCON 14” BBK.
  7. Sep 1, 2023 at 3:17 AM
    #107
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Definitely look into upgrading to the Tundra master and booster. Big brake setup alone will still be squishy.
  8. Sep 1, 2023 at 4:43 AM
    #108
    TegoTaco
    Ontario, Canada
    I’m not worried about the squishy pedal but will keep in mind the Tundra master/booster, direct bolt on?
  9. Sep 1, 2023 at 6:04 AM
    #109
    AllTacosFloat
    Boston ish
    You’ll need new lines made or make them yourself… I’ll find the link and hit you up later
  10. Sep 1, 2023 at 7:02 AM
    #110
    TegoTaco
    Ontario, Canada
    As long as I can get away without the master/booster and see a dramatic difference…I’ll be happy in the mean time.
  11. Sep 23, 2023 at 2:30 PM
    #111
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    I presume this brake kit is complete bolt on replacement? Do we need the brake line extenders?
  12. Sep 24, 2023 at 2:24 AM
    #112
    jamesepoop
    jamesepoop [OP] Well-Known Member
    California
    2007 Fj Cruiser
    It's completely bolt on. By brake line extenders do you mean a longer brake line? If you don't already have stainless braided lines, I'd swap for those. And if you already have SS lines, you don't have to upgrade.
  13. Nov 6, 2023 at 4:21 PM
    #113
    tbraumb11
    tbraumb11 Well-Known Member
    nanaimo
    2015 tacoma double cab magnetic grey
    what are those?
    I would be interested in this kit if another group buy were to happen.
  14. Nov 7, 2023 at 5:30 PM
    #114
    jamesepoop
    California
    2007 Fj Cruiser
    They usually have holiday sales. Reach out to them and ask as well. Doesn't hurt.
    AY_ARONTRD likes this.
  15. Nov 7, 2023 at 6:26 PM
    #115
    tbraumb11
    nanaimo
    what are those?
    Yea I joined the mailing list and will be watching sales....this black friday its only expensive items left for my build so it will be based on who has best discounts on what.
  16. Nov 7, 2023 at 11:11 PM
    #116
    nudavinci64
    Robert
    Check out willwood direct their BBK kit isn’t. Too bad. SOS also will have a sale for sure. This kit on this thread is only calipers so once you buy rotors you’re close to alot of the other kits on sale. This is also t4r spec not Tacoma. I still liked it but the pistons are a tad bigger than the taco wants
  17. Nov 8, 2023 at 4:42 PM
    #117
    tbraumb11
    nanaimo
    what are those?
    The kit online adds rotors too tho if you want? I'm going to 35's soon n just want something better n this seems a bit cheaper than others for qood quality...I'll check out wildwood direct
  18. Nov 9, 2023 at 11:36 AM
    #118
    nudavinci64
    Robert
    Yes you can add Rotors but adds up. RR kit is nice. the big difference are they are T4R spec and the higher end Aero 6 calipers vs the superlite which you will see in the Tacoma Kit. The willwood Tacoma kit also comes with 2 piece rotors vs solid rotors.
    If you do go with the RR kit def go with the DBA rotors. That is what I planned to add to my truck before swapping them out. Black Friday is here so def great option for any of the kits from any vendor.
  19. Nov 19, 2023 at 8:55 PM
    #119
    tbraumb11
    nanaimo
    what are those?
    Do I need the master cylinder upgrade if just doing front big brake kit right now? I guess better question, will it add performance?
    Looking at the sos kit it says for rear disc conversion does it work without it?
    I have a 2015 trd sport.
    Sorry for spamming group but you always seem willing to share knowledge
  20. Nov 19, 2023 at 11:36 PM
    #120
    nudavinci64
    Robert
    Do you need it? No
    Will it be nicer? Yes.
