Another Bilstein lift thread (6112 and 5160)
Discussion in 'Suspension' started by elytravis, Oct 17, 2015.
  1. Aug 9, 2017 at 11:14 AM
    #41
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    I'll post some more numbers in case it helps anybody...
    They've been on for over a year and a half. I had them at ring #3 and hub-fender measurement was 21 1/4".
    A few weeks ago I went up to ring #4 and hub-fender went up to 21 3/4" strong.
    A week after that I installed a US Offroad bumper and winch (roughly 130 lbs) and it didn't make any measurable difference.
    Ring #4 maybe rides a tad more stiff - but it's so close it also could have just been in my head.
    PreTaco170 likes this.
  2. Aug 9, 2017 at 2:39 PM
    #42
    PreTaco170
    PreTaco170 Well-Known Member
    Russ
    St. John’s County
    2009 PreRunner DCSB TRD OR
    Bilstein 6112/5160, Dakars, JBA UCAs, FN f(x) Pro 17x8, 285/70R17(C) BFG KO2, Wheeler's Off-Road Bumpstops/U-bolt flip kit, CMC, Marlin Crawler HD LCA Frame Brace Kit, TRD CAI, Flowmaster exhaust, Alpine iLX-407 CarPlay receiver
    I don't know if I'm not measuring accurately or what but I'm at 23 7/8" driver and 24 1/8" passenger center of hub to fender. This is way different than what you're reporting. I know you have a bumper and winch now but you said it didn't change much. And I know I'm a PreRunner but it still seems way off compared with your numbers. I'm on the 4th clip position as well with a 1/4" spacer on driver side.
    If you get a chance, can you measure ground to fender? As long as you have 265/70R17 tires then the numbers should be fairly accurate for me to compare with. My numbers are 38 1/4" driver and 38 1/2" passenger, ground to fender.
  3. Aug 9, 2017 at 3:59 PM
    #43
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
  4. Aug 9, 2017 at 5:17 PM
    #44
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    I have 34's, not to mention tire pressure differences..... hub-fender is really the only way to compare lifts.
    Don't know what to tell you, man. I use the flat edge of something (small box, etc.) and place that against the center of the hub, then I place the end of the tape measure on that, a few inches away from the hub. This is so I can measure straight up to the fender. But still, your numbers sound really high - assuming we're measuring the same way.
  5. Aug 9, 2017 at 5:43 PM
    #45
    PreTaco170
    Russ
    St. John’s County
    No worries, thanks. Your numbers were just way different than what I had and some others as well. But we're not exactly comparing apples to apples since you've got more weight up front with the bumper, winch, etc. Thanks for the response!
