Another Blend Door Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by sikora8, Nov 2, 2019.
  1. Nov 2, 2019 at 5:32 AM
    sikora8
    sikora8 [OP] Active Member
    04' SR5
    Does anyone have a clue why my blend door actuator motor seems to cycle all over the place? I just replaced the motor with an aftermarket from RockAuto and it is still doing the same thing. I turn the dial and the motor seems to cycle from hot to cold to back to hot??! Any ideas? Thanks
    GQ7227 likes this.
  2. Nov 2, 2019 at 9:18 AM
    bspang
    bspang Member
    Washington/Oregon
    01 3.4L V6 Manual 4wd xtra
    GQ7227 likes this.
  3. Nov 4, 2019 at 4:30 AM
    sikora8
    04' SR5
    I replaced the actual blend door last year. And the cable seems to be functioning just fine. As I am driving, I can hear the actuator moving erratically under the dash. I have the cable unhooked currently. If I didn’t, then my temperature would be all over the place
  4. Nov 4, 2019 at 10:07 AM
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
  5. Nov 4, 2019 at 11:30 AM
    sikora8
    04' SR5
  6. Nov 4, 2019 at 5:39 PM
    D60
    D60 Well-Known Member
