Another clunk/rattle thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NotUrTaco, May 4, 2019.
  1. May 4, 2019 at 5:00 PM
    NotUrTaco
    NotUrTaco [OP] Well-Known Member
    Richmond, VA
    2008 Silver 4x4 Access Cab
    Here's the rundown: 2008 AC TRD Sport, AT, 116K, BFG A/T's, otherwise pretty much stock.
    Odd rattling/clunking/light thudding coming from the passenger side front wheel well when traveling over a series of small bumps(small potholes, not big enough to swallow the entire wheel, etc.).
    I've checked out everything I know to check:
    -Front bumper is snug
    -wheel bearings dont seem to have any play when that side of the vehicle is jacked up
    -brake pads have the spring and are snug in the caliper.
    -radiator bushings seem fine
    -cab bushings flex very little when I prybar in between the cab & frame tab where they mount.
    -no odd creaks/squeaks/clicks that would lead me to think it might be control arm bushings.
    -nothing seemingly loose in he engine bay.
    -plastic splash guard in front of the wheel(wheel well) is pretty snug...also doesn't weigh enough to have the depth of sound I'm hearing.
    -no noticeable slop in ball joint
    My Diagnosis: I just need new shocks(mine are OEM), then go from there.
    Anyone who's got anything to add, at all, I'm all ears(eyes).
  2. May 4, 2019 at 5:09 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Check the cat heat shield under the drivers seat area
  3. May 4, 2019 at 5:12 PM
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    Do you have a sway bar? How are the end links ?
  4. May 4, 2019 at 5:22 PM
    NotUrTaco
    Richmond, VA
    It's not the cat heat shield, good call, though. That's more of a "sheetmetal rattle" sound.
    I do have a swaybar, I pulled on the bolts with a combo wrench yesterday and they are tight. I'm debating removing the swaybar and taking it for a test drive.
    Dirtridercrf250 likes this.
  5. May 4, 2019 at 5:33 PM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    I know you listed them already, but I had a similar clunking over braking bumps, but only below 40 degrees outside air temp. Ended up being cab mounts. This was when my '05 was still less than a year old. Haven't heard it since they were replaced.
    Everything on the exhaust tight/not hitting anything?
  6. May 4, 2019 at 5:36 PM
    NotUrTaco
    Richmond, VA
    I hear ya, those are definitely on the list of things to replace "just because." Maybe I will loosen the nut on that busing and take it for a drive. If it's related, it should have some effect on the sound.
  7. May 4, 2019 at 7:03 PM
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    I would suggest you have someone drive the truck in a bumpy parking lot that will repeatably produce the sound. You stand outside to the side and listen as the truck slowly passes by. You will hear the side and the source of the rattle. We just went through this on a VW and found the aftermarket brake pad ears were very loose in the caliper. It sounded like the front end was falling out. We replaced the pads with VW oem pads verified by vin number. All rattles completely gone.
    If you lightly apply the brakes and the noise stops you have verified the source.
  8. Dec 7, 2020 at 4:16 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
