Another Fan Motor Thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by birry, Aug 28, 2015.
  1. Sep 1, 2015 at 8:36 PM
    birry
    birry [OP] Well-Known Member
    Oklahoma City, OK
    2008 4x4 DCSB
    OME 885, Bilstein 5100's, Wheeler's (single) AAL
    So I've been reading through this thread https://www.tacomaworld.com/threads/fan-speed-switch-not-working.70275/ about the real problem with a lot of these things. I decided to order the updated parts and follow the instructions in the TSB to fix it. Looking at all these posts and photos of the connector, I know that's at least one of my problems. Rather than kick the can down the road, I'm just going to fix it right this time and hopefully be done with it. The fan motor doesn't seem to be my problem - rather, it is this stupid connector/resistor connection.
  2. Sep 1, 2015 at 8:44 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    I just took mine apart, blew it out good, grease the bearing end, and re seated the brushes real good. It took a half hour or so but its been years of trouble free service from then
    ready6delta likes this.
  3. Sep 2, 2015 at 1:42 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Yes. Repair the connector. As I see you have decided to do...:thumbsup:
    birry[QUOTED][OP] likes this.
  4. Sep 2, 2015 at 5:13 AM
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
    Can I use regular wire crimps to do the connector splice, and if so, what size do I need?
  5. Sep 2, 2015 at 4:19 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    You could, But I prefer to solder and heat shrink. Not sure about the size of crimp splices...
  6. Sep 2, 2015 at 5:08 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    Buy the 043 blower and be done with it.
    The squeak will always come back.
  7. Sep 2, 2015 at 5:31 PM
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
    I don't have a squeak. I have an intermittent fan that will occasionally only work on high. This is a classic symptom of the resistor/pigtail connector failure. Its a fairly cheap/easy fix, so I'm going to do that before going for a new fan. My fan made a clicking noise, but that went away after I took the cabin air filter out.
  8. Sep 8, 2015 at 10:32 AM
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
    I just received my parts today, and I'll post some pics and report the results when I get it all installed. Hopefully these are the correct parts...
  9. Sep 8, 2015 at 9:18 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I just spotted the source of the problem with these connectors!
    Look at the label: ACDelco PT1231 GM original...
    General Motors Crap!
  10. Sep 9, 2015 at 4:37 AM
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
    I thought this was the upgraded pigtail....?
  11. Sep 9, 2015 at 8:03 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Time will tell...
  12. Sep 10, 2015 at 5:33 PM
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
    I finished installing the new parts and have a couple comments/questions. Overall it wasn't too bad.
    Comments:
    My wire crimper/stripper tool sucks.
    I shouldn't have done a shoulder and arm workout just before this.
    That little screw on the back side of the resistor is a pain the BUTT to get back in there.
    Here's the old connector with the common burn pattern on one terminal.
    Then there's the side by side comparison of the resistors. And I agree with whoever said the old one looks like it was made by terrorists in a small village on the side of a mountain in Afghanistan. It says, "Made in Slovenia", but I don't buy it ;-) The thing was cracked, rusted, corroded...etc.... The new one looks like its straight out of Tron.
    Here's the entire process:
    I disconnected the negative terminal on the battery.
    Removed the connector, then unscrewed the two screws holding the resistor and it fell out easily.
    Installed the new resistor (back screw is a pain!)
    Took a photo of the wires going into the connector so I could match the correct wires within the splice.
    Stripped the wires on the new pigtail.
    Cut the wires of the old connector about an inch back from the connector interface.
    Stripped those wires.
    Connected it all up with the crimps provided with the pigtail.
    Plugged the connector into the new resistor.
    Easy as that.
    However, I connected the battery terminal, turned the key, and clicked over to the LOW fan setting and........NOTHING! I was pissed. I turned it to HIGH and the fan kicked on full blast. I took the connector out and re-connected it, then the fan speeds all worked normally.
    Here's my question - did anyone else find that the new connector would not click into place on the new resistor? That little green rubber thing at the end would not allow the connector to fit all the way into the resistor. I'll see over the next few days or weeks how it performs, but its currently working as it should. It just bothers me that I couldn't get the connector to click into place.
  13. Sep 10, 2015 at 9:55 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I don't see a little rubber thing that is green in your pictures...
    I assume it is a waterproof seal in the connector. If the connector is not plugging into the resistor pack completely you could have another heating issue with the connector due to a resistive connection ( heater ). Can you remove the rubber green thing and plug it in all the way?
  14. Sep 11, 2015 at 5:09 AM
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
    Not the best photo of it, but you can see it.
  15. Sep 11, 2015 at 5:18 AM
    #35
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
    Also, the rubber seal material seems like it may be glued on or something. It didn't just slide off easily when I tried to remove it.
  16. Sep 12, 2015 at 6:06 AM
    #36
    Jimmyh
    SC
    2012 Prerunner SR5
    Yes that is the seal I am talking about. It should just slide on ( made of soft silicone rubber ). At a minimum you should be able to get it latched in place.
  17. Sep 12, 2015 at 1:09 PM
    #37
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
    There is no way it will just slide on. It's too tight with the seal in there.
  18. Sep 12, 2015 at 4:35 PM
    #38
    Wile
    Wile Well-Known Member
    Tim
    New Mexico
    08 4x4 DC TRD Offroad
    Pioneer AVH-5600BHS, ScanGauge, Wet Okole Seat Covers, Allpro Aluminum front bumper, Allpro Aluminum IFS skid plate, Allpro APEX rocksliders, Warn 9500s winch
    Just replace my connector and resistor. Dear Toyota, no more parts from Slovenia please. Thank you.
    birry[OP] likes this.
  19. Sep 18, 2015 at 5:34 AM
    #39
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
    Crazy. Mine both looked identical (including burn marks), but my resistor was a little more rusty/dirty than yours.
  20. Sep 18, 2015 at 5:37 AM
    #40
    Wile
    Tim
    New Mexico
    Solid evidence that the design had a very specific flaw. Glad they redesigned the resistor. Fingers cross that the connector will be ok now.
