Another frame question??
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomanTurd, Apr 15, 2019.
  1. Apr 16, 2019 at 7:10 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    :confused: it would stop it if it completely seals off all oxygen from getting to it?
    did you get yours back yet?
  2. Apr 16, 2019 at 7:20 AM
    BLACK04TRD
    BLACK04TRD Well-Known Member
    Bethesda, MD
    2004 Tacoma TRD, 3.4L, 5spd -- SOLD
    Stock AF
    Nah not yet, dealer said it will likely be 3 months. Most of the wait is getting the new frame/parts in. Once they have it it'll only take a couple days.
    Undercoatings don't seal up the frame airtight. I think the issue is that even with an undercoating water/road salt are able to get into the frame and then are unable to drain. Fluid Film at least creates an oily barrier that the water repels from.
    GQ7227[QUOTED] likes this.
  3. Apr 16, 2019 at 8:33 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Well yeah, the point is that for the frame replacement to still be possible, the frame needed to at least be in good enough condition and steps taken to protect it. So, if you didn't even have Toyota coat and protect the frame at all in the last 15 years, they aren't going to replace the frame for you, and you're SOL.
    GQ7227 likes this.
  4. Apr 16, 2019 at 8:33 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Bedliner will behave the same as this stuff.
  5. Apr 16, 2019 at 8:35 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Thankfully thats not the case for 2nd gens. My dads wasnt done, and I poked a hole in it last week.
  6. Apr 16, 2019 at 8:39 AM
    jbrandt
    Justin
    Yes, IF...
    Remember, the frames rust essentially from the inside out. Can you coat the inside of your frame with this stuff? Probably not.
    The only way to do that would be to dip the frame.
  7. Apr 16, 2019 at 8:41 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i did not get exact deets, but I would think they would spray the inside with the LineX material, but they can't?
  8. Apr 16, 2019 at 8:41 AM
    jbrandt
    Justin
    It's a boxed frame, so no, not really.
  9. Apr 16, 2019 at 8:48 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    that is a scary video! ziebart krap
    is krown treatment similar?
    is this the stuff that ToyotaMotorCorp would apply to frames that passed inspections?
    so many questions :(
    Blue92[QUOTED] likes this.
  10. Apr 16, 2019 at 9:57 AM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    The frame issue was /never/ a recall. It was an extended warranty. While your link might provide information about other recalls on the truck it will provide no information about frame rust.
  11. Apr 16, 2019 at 10:04 AM
    jbrandt
    Justin
    No, it's not Line-X type stuff that Toyota applied. It was some type of under coating, probably the same crap they'd try and charge you another $1000 when you're negotiating for a new car.
  12. Apr 16, 2019 at 10:11 AM
    jbrandt
    Justin
    This is important.
    I've seen more than a few threads over the years of people saying they called Toyota and they said their frame doesn't have any recalls so that must mean their frames are fine.
    It's very important that when you call or talk face to face with Toyota, you specify you're asking about the extended warranty on the frame. The monkeys at the reception desk would otherwise just look for "recalls" and tell you you're fine.
    GQ7227 likes this.
  13. Apr 16, 2019 at 10:51 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
  14. Apr 16, 2019 at 11:03 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    Probably used the same crap they have been spraying 2nd gens with, which is to my understanding a special requested formulation of thinned out economy grade Noxudol, which Toyota likes to confusingly call “CRC”. They don’t mean the actual brand named CRC.
  15. Apr 16, 2019 at 1:11 PM
    #35
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    What they put on mine, back in 2010 was very similar to paraffin wax (the stuff that comes out of an old time oil well around the pump, not the refined blocks you see), very sticky and a bit oily. Mine still rusted from the inside out. Exterior looked great until I popped my thumb through along the bottom of the frame.
    GQ7227 likes this.
  16. Apr 16, 2019 at 1:14 PM
    #36
    chrispchicken9
    chrispchicken9 Well-Known Member
    '04 3.4 tacoma, '16 4.0 4runner
    my '04 frame warranty is good through October of this year.
    they stopped producing 2004's in July or August I think???
    Plus it's 15 years after the truck sold off the lot.
    Definitely look into getting a new frame.
    GQ7227 likes this.
  17. Apr 16, 2019 at 1:14 PM
    #37
    chrispchicken9
    There are still plenty of '04s out there still covered under this warranty including mine
    GQ7227 likes this.
  18. Apr 16, 2019 at 1:19 PM
    #38
    GQ7227
    GQ7227 mw survivor
    J A Y
    darnit :(
    that don't sound good
  19. Apr 16, 2019 at 5:48 PM
    #39
    Indy
    Indy Master of all I survey.
    which is why you can check it still. The days are definitely numbered.
  20. Apr 21, 2019 at 11:26 AM
    #40
    DrewCfromSC2
    DrewCfromSC2 Member
    Drew
    new here and looking for my first Tacoma. I live in South Carolina and most all vehicles are rust free here. Should I be concerned if a potential Tacoma has not had the frame replaced if the original looks pretty good and the tapping with a hammer sounds good too? Thank you for your replies.
