Another LED Wiring question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTRD59, Jan 9, 2016.
  1. Jan 9, 2016 at 10:15 AM
    TacoTRD59
    TacoTRD59 [OP] Well-Known Member
    2012 Tacoma TRD
    Hey guys, I know this has probably been asked a million and a half times. I can't seem to find a solid answer. I am looking at wiring a 30" or 32" 150-180 watt light bar. Im having trouble finding a kit with a decent rocker switch instead of a ricer special toggle switch. I also need to know what amp is suitable for this application. I would appreciate any input from TW, Y'all have been inviting so far.
  2. Jan 9, 2016 at 11:08 AM
    EricU
    EricU Well-Known Member
    Englewood, CO
    if you run a relay any 3amp switch will work, if you just run a fused switch look for one with a 20-25amp rating.
    i used daystar switches on my last truck and had a 40 inch led bar going off just the switch with no issue.
    a lot of people like the otrattw switches (or whatever the abbriviation is)
  3. Jan 9, 2016 at 11:19 AM
    916TacoTruck
    916TacoTruck BallzDeep is how I go
    Sactown
    '13 Money Pit.
    If you go with just a switch and no relay, the switch needs to handle 15amps.
  4. Jan 9, 2016 at 11:55 AM
    TacoTRD59
    2012 Tacoma TRD
    So if I go overkill with a 20amp switch, I should be good to go. What's the difference between w/ or w/o the relay
  5. Jan 9, 2016 at 12:14 PM
    916TacoTruck
    Sactown
    '13 Money Pit.
    I have a 30amp relay that supplies the current for my LED light bar. My switch is a little 3amp switch. My switch wouldn't handle the current to the LED light bar without the relay. All the switch does is turn on the relay.
  6. Jan 9, 2016 at 12:23 PM
    pinoyesv6
    pinoyesv6 Member
    Washington, DC
    2015 Lexus GX460
    where is your power source?
    I usually use a relay. It makes wiring cheaper and "easier"
    using a relay, I can usually keep the distance from the power source (usually the battery) close to the relay and the lights. which means less power wire. to trigger wire that goes from the relay to the switch can then be super small since it doesn't take much power to trigger the relay. since that wire is super small, I can sneak it around the different opening in the firewall to get it into the cabin.
    If if you wire your lights directly from the switch, you would go from the power source (ie. the battery) into the cabin, back out of the cabin and to the lights. Depending on where the light bar is going, you might have to upgrade the size of your power wire just because of the distance. upgrading the size means thicker wire, thicker wire is not only more expensive, its harder to route around the car. If that was me, that would be dragging at least 12 gauge, probably 10 from the battery to the cabin and then back.
  7. Jan 9, 2016 at 5:39 PM
    TacoTRD59
    2012 Tacoma TRD
    Can you guys point me in the right direction? I would like an oem style push button switch.
  8. Jan 9, 2016 at 6:03 PM
    916TacoTruck
    Sactown
    '13 Money Pit.
  9. Jan 9, 2016 at 6:10 PM
    pinoyesv6
    pinoyesv6 Member
    Washington, DC
    2015 Lexus GX460
  10. Jan 9, 2016 at 6:34 PM
    TacoTRD59
    2012 Tacoma TRD
  11. Jan 9, 2016 at 6:59 PM
    pinoyesv6
    pinoyesv6 Member
    Washington, DC
    2015 Lexus GX460
    If its just a single light bar, you only need a single lead harness.
    I usually build my harnesses just because I get a cleaner install since all the wires are cut to the right length.
    But if I were to buy a prebuilt harness, I would probably get something like this
    http://www.amazon.com/OPT7-Offroad-...id=1452394416&sr=1-3&keywords=led+bar+harness
    It uses 12ga wire instead of the 16ga and 14ga wire that most kits you see use. Just make sure that the lengths are long enough for your application.
  12. Jan 9, 2016 at 7:12 PM
    TacoTRD59
    2012 Tacoma TRD
    I need a relay right?
  13. Jan 9, 2016 at 11:17 PM
    pinoyesv6
    pinoyesv6 Member
    Washington, DC
    2015 Lexus GX460
    I would get the 500w model. It comes with a 40a relay and with lights i tend not to skimp out when it comes to power.
  14. Jan 10, 2016 at 10:43 AM
    TacoTRD59
    2012 Tacoma TRD
    I see it has one, but it's 14g not 12
    Im only planning on a 30 inch bar for now. Are relays replaceable? its a blade style fuse inside of it right? so i could just up the fuse? its 14G wire, and in my trade 14g wire is usually only good for 15 amps
  15. Jan 10, 2016 at 11:11 AM
    metrick1215
    metrick1215 Pirate Medic
    Habersham GA..
    Black 2008 4x4 4door
  16. Jan 10, 2016 at 9:17 PM
    pinoyesv6
    pinoyesv6 Member
    Washington, DC
    2015 Lexus GX460
    that is why I recommend getting the kit with 12 ga wire. while 14 gauge will be sufficient with your desired setup, the 12ga wire would give you a little room for growth if you decide in the future to swap the bar for something with a little more power. its going to be easier to swap out a fuse than it is to swap out wiring.
    TacoTRD59[QUOTED][OP] likes this.
  17. Jan 20, 2016 at 7:19 PM
    TacoTRD59
    2012 Tacoma TRD
    Ok, so everything came in and I'm lost, lol. The harness came with a switch already, a circular rocker switch with an LED on it. I bought an oem switch to fit in one of the blank spots, it's also lighted. The new switch has 4 wires and the harness has 3 wires. W the fuck. I rang then out and fount the switch leg. I tried every combination and I can't get the switch to work. The lightbar is either constantly on with the LED on the switch as well. Or nothing the LED on the switch is on but it doesn't turn on the lightbar.
  18. Feb 21, 2016 at 11:17 PM
    thumper72
    thumper72 Well-Known Member
    Jon
    Ogden Utah
    2000 toyota tacoma prerunner v6 auto
    5100's, ome dakar leafs and ome coils, problem solver tie rods, eazycompany ditch light brackets and auxbeam osram 4" led pods, 2014 4runner wheels, 265/70/17 goodyear authority tires, soon to have 50" led bar on roof
    1 x Wiring Harness
    Full Wiring Kit for All Light Bars with LASER ROCKER SWITCH ON/ OFF switch for 7'';, 10'';, 13'';, 20'';, 30'';, 40''; 50''
    Installation:
    1. connect the the red+ wire from the fuse to battery +; connect the black wire from the reply to the battery ¨C;
    2. connect the wire for lights bar from the relay; (red/black correspond to the wire of lights bar)
    3. connect the white +/black- wire of the switch to battery or any place of your car system to get power for the switch
    4. turn on on/off button of switch to test the lights bar
    i dont know if this will help or not but i found it while searching for a light bar. towards bottom on description...
    http://www.amazon.com/mictuning-Wir...22614&sr=8-52&keywords=led+bar+wiring+harness
  19. Feb 22, 2016 at 2:13 AM
    TacoTRD59
    2012 Tacoma TRD
    The switch is lighted. It has 4 wires
  20. Jul 6, 2016 at 7:00 PM
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    I went with the OPT7 14 ga single wiring harness and am wiring up a Mictuning LED bar switch. I don't want the switch to light up or tap into the factory wiring. I know to cap off the middle wire on the Micturning harness, but do I also cap off and not use the blue wiring from the wiring harness? It only has 2 leads to the battery, but 3 to the switch. I would appreciate any input :)
