Another lift question
Discussion in 'Suspension' started by wvtaco, Sep 28, 2008.
  1. Sep 28, 2008 at 2:52 PM
    wvtaco
    wvtaco [OP] Member
    wv
    2009 Access cab 4wd
    I have been reading the posts trying to gain some ideas about different lifts.
    My problem is now i am just more confused.
    This is my question:
    I have a 09 Access Cab, TRD Sport. 4WD
    I want to add a lift to level out the truck and allow me to install a larger set of tires.
    I was thinking 2.5 to 3.5"'s
    I want to improve or atleast keep the same ride.
    This truck will never be off road,
    thanks for any help you can give
  2. Sep 28, 2008 at 2:54 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Just add some 5100's bilstein shocks will give you 2.5" or go with toyotec lift and get a 3" lift.
  3. Sep 28, 2008 at 2:56 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    depending on the size tire you wanna run, a set of billy 5100's would work, but ride would be stiff as hell on the top setting. your best bet is probably to go with a good toytec 3 inch lift and aal rear, and then you can run 285/75/16 or the equivalent 17's and do minor trimming and mud flap removal.
  4. Sep 28, 2008 at 2:56 PM
    rick
    rick `
    how much do you want to spend?
  5. Sep 28, 2008 at 4:26 PM
    wvtaco
    wvtaco [OP] Member
    wv
    2009 Access cab 4wd
    Price is an issue, although not the most important. I want to preserve the way it drives, and the comfort of the suspension, most importantly.
