another possible keyless entry beep option
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Idok, Apr 28, 2008.
  1. Apr 28, 2008 at 4:14 PM
    Idok
    Idok [OP] needs a chaperone
    so, growing ever annoyed with the lack of a sound when you lock the truck I have been thinking about this for awhile..
    Electronics scare me and Im not that good with meters and such....Well, went out to lunch with my dad..we took his 99 Tahoe
    I drove..we got to the restaurant, got out and I locked it. It beeped., but not like a toyota beep..but rather the HORN beeped
    why not splice or relay a wire from the light that flashes when you lock the truck right to the horn?
    I dont see any reason why it wouldnt work :confused:
  2. Apr 28, 2008 at 4:24 PM
    zmtnbik
    zmtnbik FMLYHM
    4x4 Trd Off-road
    Donahoe (Icon) C/O, TC UCA's, Dakar leafs, BilStein 5125's, 285/70/17 BFG MT KM2's, Raceline Renegade 17x9's, u-bolt flip kit, debadged, TRD CAI, TRD exhaust, URD MAF controller, 20% front window tint, 3M clear bra on bumper, cam locks in all storage compartments, fog light mod, Alpine X100 deck, Co
    You could, but then every time you turned on your lights, you would hear your horn. I do agree there has to be a way to do it....hopefully PB can chime in and offer up his advice.
  3. Apr 28, 2008 at 5:42 PM
    camsbored
    camsbored Well-Known Member
    Raleigh, NC
    08 PreRunner DC/Sport/LB
    Kenwood DNX8120, Homelink mirror, Valentine One hardwire
    If you connected the horn to the flashers and the door locks that would work even better... that way the horn would beep only when the lights flash at the same time as the doors locking. A transistors and a diode would do the trick.
    Transistors are like electronic valves... there's an in, and out, and a control connection. Connect the flasher light to the horn like you said, but put the transistor in between them and the transistor's control connection connected to door lock circuit so it only allows current to flow from the flashers to the horn if the locks are engaged. There is a separate lock and unlock circuit so this wouldn't even go off when you unlock! Perfect.
    Now to find a wire under the hood for the lock circuit... :bananadance:
  4. Apr 28, 2008 at 5:48 PM
    MurphMan
    MurphMan Senility Rocks!
    Murph
    Maine
    '08 Tacoma TRD Sport
    * AFE Stage 2 XP CAI System * Westin Platinum Series Black Step Bars * TruXedo Lo Pro QT Soft Roll-Up Tonneau * Dee Zee Heavyweight Truck Bed Mat * WeatherTech Extreme-Duty Floor Liners * WeatherTech In-Channel Window Visors * Sony Xplod CDX-GT81UW Receiver * Sony Xplod 2-way speakers * Boss Audio BASS600 Amplified Subwoofer * Billet Grille Mod
    Other than the it beeping when the lights are lit, I'd be concerned that the lighting circuit wouldn't have enough extra power to kick the horn. Might be fine, but it'd be safer to design the circuit to handle almost anything. Here's a circuit I've been designing to get back the beep. All the parts I got at Radio Shack. When I build it I'll list the parts I used. Attached is the schematic in case you want to take a stab at it. I added a switch to let the service guys kill it and the ign line disables the whole thing while the engine is running.
  5. May 3, 2008 at 4:16 AM
    ORVA
    ORVA Member
    2021 Army Green OR TRD
    That's a fine drawing. Do you have a suggested parts list to go with it?
    Like Radio Shack part numbers you would use and then let folks go on their own if they want to substitute? I only ask that because although there are thousands of products that technically would work. You probably had something in mind that would be good for the truck, ie for mounting and controlling. Thanks.
  6. May 3, 2008 at 6:05 AM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Did you guys check out the cheap/free mod thread? Someone already makes and sells a box that does that for around $20. Beeps when the turn signals flash when the key is off (so no beeping turning corners on the street), and has a switch to kill it if you have the engine off and hazard lights on. Simple 3 wire install.
  7. May 3, 2008 at 6:26 AM
    MurphMan
    Murph
    Maine
    Thanks. I will add in the part numbers once I finish and test. I thought about using the horn but decided it didn't need to be so loud.
  8. Aug 3, 2011 at 10:34 AM
    AceRock
    AceRock Member
    Los Angeles California
    2011 DoubleCab PreRunner Longbed SR5 V6
    Does anyone know if I could install an actual horn in place of the piezo alarm and have it work? Its just a plug in connector and I can always change the plug to fit the horn. I like a conventional horn for locking the doors instead of that toyota piezo beep
  9. Dec 4, 2011 at 5:26 PM
    AceRock
    AceRock Member
    Just wondering if anyone has tried this?? I was thinking of trying the same idea but wasn't sure if there will be enough current to run the horn. I'm pretty sure that little piezo barely draws current so the wires leading to it are probably on a low amp circuit.
