Another reason to use synthetic
Discussion in 'Technical Chat' started by Flymaker, Sep 14, 2013.
  1. Sep 14, 2013 at 7:42 PM
    Flymaker
    Flymaker [OP] Well-Known Member
    Ohio
    SR5 Double Cab
    Bone Stock
    I recently switched my vehicles over to synthetic oil.....and I am now a believer that its worth the money and actually puts you ahead in the long run.......I drove my wife car to Buffalo NY in June and got 33-34 MPG .....I filled up with BP gas before I left and made 1 fuel stop on the trip again BP gas ....Oil in the car at that time was 5-20 conventional......I again drove my wifes car to Buffalo NY last wk....same route same desination....same average speed yada ...yada ...only difference was this time the car had Mobil 1 .... 5-20 full synthetic in it.....I got 35-36 miles per gallon.......so at this rate I figure I can save at least $ 40.00 on fuel during the life of the oil per change ....then you need to think instead of changing at 3k ...I can change @ 5-6k and still be fine......and of course there are the lubrication benefits ..etc of synthetic fluid...........My taco runs on all synthetic fluids 2012 ....4.0 ......4dr cab .....4x4...and I got 20.5 mpg with it on another trip to buffalo.......in august..
  2. Sep 14, 2013 at 7:48 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Worst paragraph ever.
  3. Sep 14, 2013 at 7:50 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  4. Sep 14, 2013 at 7:52 PM
    Sigi
    Sigi Well-Known Member
    Sigi
    Sfv ca
    06 tacoma 4x4 trd offroad
    That's good to know man . I always use synthetic . :)
  5. Sep 14, 2013 at 7:53 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    2mpg is statistically insignificant unless repeatable over time. Two trips (in different weather) is not a valid test.
    I've ALWAYS run Mobil-1 in my Taco... follow the Fuelly link in my signature to see my variances from tank to tank... yet I drive the same places every day.
  6. Sep 14, 2013 at 7:55 PM
    HBtaco02
    HBtaco02 Well-Known Member
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    ARB Front Locker grey wire mod Camburg UCA's Extended Kings All-Pro expo's 10" Bilstien Brute Force Hybrid front bumper Smitty XRC8
    I put a lightning bolt on the side of my truck and it now goes twice as fast. I am a believer in lightning bolts for ever now :eek:
  7. Sep 14, 2013 at 8:18 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Yep, a couple tanks doesn't prove anything.
    I've used Motorcraft 5W-20 for most of 8 years, with a few changes to Mobile 1 5w-20 and found no significant difference.
    2 mpg improvement is not realistic, and 3k oil changes are way obsolete.
  8. Sep 14, 2013 at 8:21 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Umm I get 20-22mpg on the highway all day long and I don't have synthetic oil
  9. Sep 14, 2013 at 8:24 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Just think, you might get 28!
  10. Sep 14, 2013 at 8:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Ambient temp, elevation, and such, can give an increase or decrease of 2 mpg.
  11. Sep 14, 2013 at 8:45 PM
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
    I want pancakes now!
  12. Sep 14, 2013 at 8:49 PM
    Spoonman
    Jamie
    Alberta
    Wow this guy got shot down hard.
    Fact is, on such a small engine, and drivetrain, synthetic oils makes zero difference in fuel mileage.
  13. Sep 14, 2013 at 8:52 PM
    zoopla
    zoopla Well-Known Member
    Calgary,Canada
    2011 tacoma trd dbl cab
    K&N cold air intake FXR retrofit/Vleds Avid front bar/side steps 3" Eibach lift
    well, i run full synthetic oil and i noticed a bit better millage but the main reason is to protect my engine in the long run. if i was living in florida i would probably careless but here in the winter when i start it cold at -45 degre, it starts much easier and cope with the engine temperature much better and is also more durable due to the fact that it doesn't break down as quick then regular oil with the temps change.
  14. Sep 14, 2013 at 8:54 PM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    He did make a good point about the distance between oil changes. I do think there is valuable pros to the synthetic.
    But there's a thread for that.;)
  15. Sep 16, 2013 at 6:47 PM
    Flymaker
    Ohio
    SR5 Double Cab
    Bone Stock
    What ever !
  16. Sep 17, 2013 at 7:07 PM
    BradyT88
    BradyT88 Well-Known Member
  17. Sep 19, 2013 at 7:32 PM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    Solid defense.
    Two tanks doesn't mean a damn thing. Hell I lose about 2mpg when we switch to winter blend gas. Are you insinuating that synthetic oil with the same weight and viscosity as conventional oil will allow the engine's components to move more freely?
  18. Sep 19, 2013 at 7:46 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    That is an old myth constantly promoted by Amsoil salesmen.
  19. Sep 20, 2013 at 5:18 AM
    InSight Retrofits
    InSight Retrofits Closed
    I use Synthetic oil religiously.
    You can get synthetic oil change specials all day long for $29.99 with a premium filter mobil 1/ K&N/ Bosch Distance Plus etc
    Where a regular oil change special will run $19-21.
    So for 1.5 times the price, you can do double the mileage, and change your oil half as often.
    But I will say, any NEW oil will get you better MPG than you were getting with your old sludge. Synthetic or not.
  20. Sep 20, 2013 at 5:32 AM
    Fever
    Fever Well-Known Member
    Portland, Maine
    TRD OFF RD
    TRD exhaust,remote starter, heated seats, Westin Bull Bar,TRD CAI, Weathertechs
    How much HP does the lightening bolt mod add?
