Another tire size question.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dsmooth87, May 2, 2013.
  1. May 2, 2013 at 4:21 PM
    Dsmooth87
    Dsmooth87 [OP] Well-Known Member
    11' doublecab 6spd 4x4 trd offroad
    Satoshi Grille. 245/75r16 hercules terra trac a/t. Afe pro dry s. ome 884s toytec 1.5 AAL for TSB. Twm shift knob
    245/75r16 -265/70r16 or 265/75r16. Is there any performance reason why 245/75r16 wouldnt be the better choice of tire size with mpg, traction, and power considered. Looking for answers that dont end with because they look better. Thanks. Also I have the 6 speed an was wondering if smaller tires increases rpm?
  2. May 2, 2013 at 5:01 PM
    white08gt
    white08gt Well-Known Member
    Al
    Tn
    05 dbl cab 4x4 sr5
    toytec lift, fj rims, a.r.e topper
    yes, you will turn more rpm's with a smaller tire. P265/75/16 is good size for looks and performance. they ride a little better with a taller sidewall, and as long as you stay with P metric and stay away from LT series your mileage will be about the same. you did not state whether 2wd or 4wd, only way to get more ground clearance is to get taller tires. with the bigger tires your rpm's will be lower for the same speed than 245/75/16 and your truck will handle a lot better.
  3. May 2, 2013 at 5:43 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    245s are stock and are tall enough. a 265 width tire will slightly decrease mileage, 265/75 is a bit taller, and 265/70 I believe is about stock height. 265/75 being the tallest, only yields a 3% change in rpm vs actual speed.
    to me, it is worth it to run 265/75 not only for the increased off-road traction and curb climbing ability, but it is a factory chevy size so there are a plethora of choices available.
  4. May 3, 2013 at 4:35 AM
    Dsmooth87
    Thanks for you replies
