Another tire size question
Discussion in 'Wheels & Tires' started by Travesty, Aug 29, 2014.
  1. Aug 29, 2014 at 6:35 AM
    Travesty
    Travesty [OP] Well-Known Member
    North Carolina
    2011 Tacoma DCSB TX TRD
    Alright here's the breakdown. I have a 2011 TX TRD Tacoma. I am running 2.5 inch of lift in the front and 1 inch in the rear. I have the 16 inch TRD beadlock wheels. Currently I am running 265/70/16 Michelin Ltx A/T2 (They are looking small with the lift). I will not do much off-roading. Only light trails, however I do a good amount of snow driving during the winter for ski trips.
    Heres what I would like to know:
    1) What's the biggest tire size will I be able to run with no trimming and no rubbing?
    2)What tire should I run?
    I have used the search function but couldn't find anything with a similar set-up and usage needs. Thanks in advance guys.
  2. Aug 29, 2014 at 6:38 AM
    ArcherTaco
    ArcherTaco Well-Known Member
    Riley
    Greeley/Windsor, CO
    '13 DCLB TRD Sport
    Toy-Tec Kit, Tool box fit to bed, Dipped badges, cab lights, running boards, Flowmaster exhaust
    I love my TOYO MT's. Great all around tire. A little louder than some of the other options on the road but give a great look to your tire set up. Do you plan on changing wheels? or adding spacers? you can fit I believe a 285/75/16 if you run spacers
  3. Aug 29, 2014 at 6:42 AM
    Travesty
    North Carolina
    ArcherTaco: Well, I like my wheels but was contemplating a 17 inch wheel instead. Probably leaning towards keeping my current ones right now. I have seen quite a few people running the TOYO MT's so I am definitely looking at those. Will I need spacers for 285/75/16 just so I wont rub the UCA's?
  4. Aug 29, 2014 at 6:43 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    1) http://www.tacomaworld.com/forum/2nd-gen-tacomas/130569-show-your-2-5-lift-tire-size.html
    Run either 265/75/16, or if you want 33s 255/85/16.
    2) Tires, that's all your preference/need/budget
    http://www.tacomaworld.com/forum/wheels-tires/150771-show-your-rims-tires.html
    http://www.tacomaworld.com/forum/wheels-tires/38333-tires-tires-tires-tires.html
  5. Aug 29, 2014 at 6:45 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Stock or aftermarket UCA's?
  6. Aug 29, 2014 at 6:45 AM
    Travesty
    North Carolina
    Greeneggsnspam: Will the 255/85/16 still preform well in snow? I wasn't sure just because it is a more narrow tire.
  7. Aug 29, 2014 at 6:46 AM
    Travesty
    North Carolina
    Stock UCA's
  8. Aug 29, 2014 at 6:46 AM
    ArcherTaco
    Riley
    Greeley/Windsor, CO
    '13 DCLB TRD Sport
    Exactly. you may rub a little at the cab mount but I don't think you will rub if you take the flaps off the front. I run 285/70/17 and don't rub unless I beat on it and that should be really close to the 285/75/16.
  9. Aug 29, 2014 at 6:52 AM
    Travesty
    North Carolina
    Any suggestions on type or size of spacer's?
  10. Aug 29, 2014 at 7:15 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    I run 285/75/16 KM2's with 2.5" up front and 1.5" in the rear with no issues. I did rub every once in a while on the front air dam when in reverse, although your '11 has different inner fenders and may have other issues.
    This^^^
  11. Aug 29, 2014 at 7:24 AM
    Travesty
    North Carolina
    I am up in Boone for a few days, would like to see your Taco on 285's. I leave on Sunday.
  12. Aug 29, 2014 at 7:28 AM
    Boone
    Boone, NC
    Airbags deployed
    I'll be around. Let me know what works for you and we'll go from there.
  13. Aug 29, 2014 at 1:12 PM
    Travesty
    North Carolina
    Do you think I would rub the UCA's with 265/75/16 's and no spacers?
  14. Aug 29, 2014 at 1:28 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    no, maybe in major flex situations if ur swaybar is removed at full lock in reverse but even then just barely
  15. Aug 29, 2014 at 1:32 PM
    shore990
    shore990 Well-Known Member
    Colorado
    2014 TRD Off Road
    I have 265/75/16s at stock height. I removed the front flaps. No rubbing except offroad if I really stuff the tire.
  16. Aug 30, 2014 at 8:50 PM
    Frankie Santoro
    Frankie Santoro Color matched master
    Frankie
    Wilmington NC
    Livin Life
    Rims tires 4 inch lift hids roof racks radio color matched bumper, , fenders, 5% tint straight pipe color matched everything
    285 75 16
    Bfg all terrain or mud terrain
    Nitto trail grappler
    Toyo mud terrain
    :cool::)
  17. Aug 31, 2014 at 11:04 PM
    Travesty
    North Carolina
    Alright well now im trying to decide between 255/85/16 and 265/75/16.....decisions decisions. I know the 265 will fit with no rubbing but dont know about the 255.
  18. Sep 1, 2014 at 6:51 AM
    yota243
    E.J.
    north Alabama
    The only issue i see with 255's is the lightest tire ive found is d rated (about 50#) where u can still get 265 in c rated or p rated
  19. Sep 1, 2014 at 6:39 PM
    Travesty
    North Carolina
    Alright last question. Right now the rear is sitting almost exactly 1 in lower than the front. I am trying to decide if I would like to lift the rear 1 or 2 inches. 1 in would be dead level and 2 in would be 1 in high in the rear. I am only going to run 265/75/16 so I don't want the tires to look too small. Just thought I would get opinions.
