Antenna Connector Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kb1jop, Mar 5, 2012.
  1. Mar 5, 2012 at 1:36 PM
    kb1jop
    kb1jop [OP] kb1jop
    Rick
    Webster, MA
    2020 Magnetic Gray Metallic SR5 Double Cab
    Factory Towing Package OEM Bed Mat Hard Tonneau Tacoma All-Weather Floor Mats
    [and yes I searched but found nothing]
    Is the antenna connector to the back of the OEM radio a standard Motorola type plug?
    And is it possible to get to the back of the radio to unplug it without removing the radio or otherwise disassembling a lot of stuff?
    I appreciate any help.
  2. Mar 6, 2012 at 7:10 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Yes, standard plug. I don't think it's possible to get to it without removing the radio. Well, probably possible, but not without less work then removing the radio. The radio is pretty easy to remove. Toughest part is prying the HVAC panel off without scratching the soft plastic panels.
  3. Mar 6, 2012 at 1:17 PM
    kb1jop
    kb1jop [OP] kb1jop
    Rick
    Webster, MA
    I'm thinking what I wanted to do is not worth taking it all apart. I was hoping I could just reach it from behind. Thanks for the help.
  4. Mar 6, 2012 at 1:20 PM
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    you're gonna have to take the radio out of the console, but its not hard, if you really wanted a how to, i could take a video of me doing it if theres not already one
  5. Mar 6, 2012 at 1:41 PM
    kb1jop
    kb1jop [OP] kb1jop
    Rick
    Webster, MA
    Thanks but no thanks. I have a splitter that you plug the antenna into and then one cable goes to the radio with a Motorola plug and the other to a BNC connector for a scanner so you can use the vehicle antenna for that too. It's just not that important enough for me to take the radio out etc. On my previous vehicle I was able to just reach behind, unplug it, and re-plug everything in with no disassembly.
    P.S. If anyone would like to have this, I'd be willing to give it away. But please, only if you are really going to use it.
  6. Mar 6, 2012 at 3:32 PM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    FOX 2 1/2" CO's STOCK UCA's - They used to be Icons! Icons suck!!! TSB Rear w/Bilstein 5100's - Air Lift System - Leer 550 Bedcover - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    Remove the passenger side "oh sh*t" handle and you will find the connector for the antenna.
  7. Mar 7, 2012 at 5:51 AM
    kb1jop
    kb1jop [OP] kb1jop
    Rick
    Webster, MA
    Isn't that way over on the windshield pillar? Not exactly the location for this connector. :notsure:
  8. Mar 7, 2012 at 9:39 AM
    bb609
    bb609 O.F.
    NH
    Have a look. The antenna wire runs through the fender and then up to the pillar where the connector is located. A separate wire runs over to the radio.
