Antenna Replacement Help Needed...
Discussion in '1st Gen. Tacomas (1995-2004)' started by 747, May 22, 2011.
  1. May 22, 2011 at 10:19 AM
    747 [OP] function > form
    1st Gen.
    My antanna snapped off above the threads; thus, the threaded portion is still "in".
    I've considered replacing the entire assembly (below the fender and up), but really I just want to pull the thread portion out to save some coin.
    I've attempted to drill out the threaded portion, but it just spins around in there when I get the drill on it. Further, I can't pull it out with a magnet.:mad:
    I'm out of ideas (other than replacing the entire assembly); anyone else addressed this issue? All constructive suggestions appreciated.;)
  2. May 22, 2011 at 11:48 AM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    The broken off portion is just spinning down inside where the threads reside?
    Maybe, without looking at it of course there is a nut on the backside? Might need to drop the splash guard out of the wheel housing and shin a light in there.
