Anthony's 2010 banworthy access cab mostly BS not much of a build thread
Discussion in '2nd Gen. Builds (2005-2015)' started by 6 gearT444E, Jul 20, 2014.
  1. Jul 20, 2014 at 6:36 PM
    6 gearT444E
    6 gearT444E [OP] Certified Electron Pusher
    Deep South
    Herculiner Hootus
    Couple of pics of about current state
    4B5AB62A-667E-4F69-AFA2-31D70E0B926C_zps_31345a2e5deb5b0be5508b6a734c9dcfb546c43e.jpg
    0C520F46-96E8-4660-8D82-CC82A7DE3CF2_zps_d17c1a1ec4093b33b547a8e8e8d1a829f3746dc1.jpg
    Truck Specs
    2010 Speedway Blue
    Access Cab, TRD Offroad, 4x4
    6 Speed Manual 4.0L V6
    Drivetrain
    4.56 Nitro gears w/ARB RD121
    4.56 Nitro gears 29 spline pinion e-locker
    Marlin Crawler Tacobox w/4.7 gears
    FJ Cruiser twin stick t-case clocked at 15*
    Front Suspension
    Icon 2.5" Extended Travel CO ICON-5-8735 w/ 14" 700# springs ICON 158508
    Total Chaos UCAs TC-96504
    Total Chaos LCA cam tab gussets - TC-59860
    Wheelers Superbump bumpstops
    Custom Cab Mount Chop
    Total Chaos Spindle gussets - 59698-SB
    Total Chaos Coil bucket gussets - 59653
    Rear Suspension
    King 2.0 RR Smooth body shocks mounted inboard / \ - PR2012-SS
    OME Dakar CS047 rear leafs
    OME AAL D29XL
    Allpro Ubolt flip
    Toytec 3* Axle shims TT-RS-846
    OME Carrier Bearing Drop FK29
    Custom TOR shackle flip
    Misc stuff
    Weathertech digi fits
    Locker Anytime Mod
    Inverter 400W Anytime Mod
    Rear diff Breather Relocate
    T-case Breather Relocate
    URD Short Shifter
    Seat belt chime disabled
    Blacked out badges
    Allpro Front/Rear SS Extended brake lines
    HomerTaco Raptoroshi grill
    Wet Okole Seat Covers
    Maglite mounted in the cab
    Redline Hood Struts
    1" 4crawler body lift
    ARB 47L Fridge/Freezer
    Homebrew bedrack
    Cascadia Vehicle Tents Mt. Bachelor RTT
    Electrical
    Fog Light Anytime Mod
    BHLM
    LED interior lights and License plate lights.
    Blue Seas 120A breaker
    Blue Seas 12 circuit fuse block
    OTRATTW 6 switch bank
    In cab winch control
    Aux reverse lights
    Aux rear turn signals
    Blitzpro Hawk 21S LED bar
    ATO Dual Battery Setup w/ Optima D34s
    Blue Sea 7622 Battery Isolator
    Flyzeye Interior LED
    BeeRad Hood lighting kit
    Kicks
    16x8 Mickey Thompson Classic Locks Black
    36x12.5 Super Swamper TSL
    Full size spare
    Gorilla E/T lugnuts - 68138L
    Gorilla E/T wheel locks - 68631N
    Exhaust/Intake
    Doug Thorley Long Tube Headers w/ O2 sims - THY-515-LS-C
    Custom Y pipe routing w/ flowmaster 40 dumped behind the axle
    ARB Safari Snorkel - SS135MOD, plumbed to stock intake
    Recovery Gear
    Warn 9.5 xp-s with Spydura synthetic rope
    ARB Snatch Strap ARB705US
    ARB Tree Trunk protector ARB730
    ARB Winch Extension Strap ARB725
    60" Hi-lift
    Hi-lift ORB
    Hi-lift Fix-it-kit
    Hi-lift off-road kit
    ATO Hi-lift bed mounts
    Shovel mounted via quickfist in the bed
    ARB CKMTA12 twin air compressor
    ARB Tire Inflation kit
    Masterpull SBO30000 Snatch Block
    Van Beest 3/4" shackles
    Armor
    ATO IFS, Tranny, T-case (custom extended), gas tank skids -
    Tranny and t-case skids custom reinforced with 3/16" angle iron
    CBI bolt on D.O.M. sliders w/ kickout
    Total Chaos LCA Skidplates TC-86006
    Boztec rear differential skidplate w/E-locker protection
    Relentless front & rear bumper
    4x Innovations tube doors
    Comms
    Cobra 25 WX NW ST
    Co-phased 4' Firestik FS
    Para Dynamics PDC1 SWR/RF Meter
    PA radio
    Spare parts:
    3rd member and E-locker actuator
    rear driveshaft
    front driveshaft
    5 OEM CVs
    Inner and outer TREs
    Shifter
    gusseted spindles
    OEM LCAs
    Bought my truck back in 2010 and here is one of the only shots I have of it stock, doing some work early on in life.
    My first TW meet. From left to right (John - StandingCow, Colin - Motoxerc0, Craig - HomerTaco, Me, Boyd aka DYOB aka sKip - XXXX)
    My first mod was DT long tube headers
    Then came the front suspension
    Sawzall taken to the truck for the first but certainly not last time
    along with Dakars for the rear
    Here she is lifted at 3"
    Added SS brake lines
    Plasti dip the chrome front grille along with some SWB angry eyes, front end v1
    Also plasti dipped the rear bumper and all the badges
    Then I got some new wheels and tires
    I installed some 6k HID cheapos and removed them after realizing they blind the hell out of people, also installed some andres devil horns, front end v2
    The firestone DBs bent my alignment tabs so I got the TC gussets put on to fix that up
    Around that time I got the ATO full set of skids installed (thanks to JLink bringing them up from VA for me!)
    Added some inverter outlets to the back of the center console
    219162_10101087283936164_9311444_8160262_1c4357b1f6658dd8485b2dd2605b7ecd8c2a0997.jpg
    Installed some CBI bolt on sliders as well, these things are great can't speak enough of the work those guys do!
    Mawl Crawling on HomerTaco's turf :laugh:
    Front end v3, some SWB devil horns and a color matched grill along with the BHLM
    Safari snorkel also added
    Busted out my rear window wheeling with sKip one weekend :(
    Those new windows are expensive and not too fun to install
    Then it was time for a regear, 4.56s F/R from ECGS
    Added an ARB dual compresssor in the engine bay
    Wired up a 6 switch bank from OTRATTW to the sunglasses holder, lots of wires jammed up there!
    After a long wait, Relentless front bumper and warn winch installed
    Relocated the solenoid to under the hood
    Relentless HC bumper installed, thanks to HomerTaco and XXXX
    Electrical upgrades added with a fuse box and breaker from blue sea
    Added a 1" bodylift in there
    Then drove down to NC to visit EL TACOROJO and wrmathis to install my crawlbox. Big shout out to Burry and Mrs. Burry for the hospitality and assistance in installing this junk! And thanks to Mathis for being a jerk :p
    C5D77012-BC81-4FE3-9575-E1DBF3D2827A-863_03721f9c87115cefb8338d98dcfc867eadd4b3aa.jpg
    [E007F779-5019-457C-870A-E454586FC4C6-645_57f83403a5153982c8b1c690eadbb4358300dc9e.jpg
    45ED76E7-7183-48E7-AAE2-448EBC624FB4-863_4a2c261403107c6f6c726f2608e4d33e0543e3b4.jpg
    A1814E33-8C87-4ED8-9CA8-AA58FA2C2B43-695_41c49f484ac6b780d30b06dc789be4990abf298e.jpg
    3FCC2695-B699-434B-B334-2CBCC19351B4-487_59a0eda8850bd05c9ba9de7986e7fb49026d5bc1.jpg
    EB69C01D-61E8-4C04-A89F-15DF66C25FE5-695_b6775d1c740bd4bf51c114e722256997f51b81a1.jpg
    Added dual batteries and the control switch into the lower part of the center console
    0702FE1E-F012-4C43-BA2E-AD8D8D90A332-953_2140247134575e1ebc38ed0dd4dab9cf2a06ba9c.jpg
    70C2AA73-036D-433E-B162-9C6A2488FC08-953_678084ee7ce8287466d9b678861057a72f5dda70.jpg
    Made up my ADD switch for the 4wd since swapping to the FJ tcase
    19D9E7F2-08C0-48DE-ABCA-935A7353E046-142_891f965811ab06dd802fa971f8447e81f36b1dc3.jpg
    E94BF28D-908F-4614-95D1-B3B2F30A15A5-234_cd59f818ccd5dc42a72a0f438f2748b925a0849b.jpg
    Made a bed rack
    Made a small stand for my ARB fridge in the back seat
    Reinforced my skid plates to keep from bending
    Installed a shackle flip
    At some point I got the HomerTaco Raptor grill
    C082CD8E-1A29-4E69-9D8A-F094DBE1A93F_zps_1b7c0574c8a1481210704ad2e3d361b7bdc0e27d.jpg
    Rebuilt the entire front end (coil bucket gussets, LCA bushings, UCA uniballs, spindle gussets)
    Got a CVT Mt. Bachelor for the bed rack
    7DF4B220-9A13-41E2-9FB1-2FCA76D450EE_zps_888316c9dbf60328ff18c23a9878fcd35cdee10c.jpg
    Swamped it and have had plenty of adventures along the way
    3575CD81-197D-43A2-ABC2-F9135337596F_zps_15fd2c46a117f4212d3201bb262b0fc563e8b3c0.jpg
    Installed some ATO tube doors, these things are great!
    C2A87AE9-8D9E-479F-8225-95420D92DA10_zps_d783ba2049422b099245a83eebe101271302892b.jpg
    Relocated my shocks inside the frame rails with some 12" stroke kings
    B6FECBEF-4AB8-4804-AF73-0579D33B210F_zps_9bc1fac3d011b3e4ff06f575df5dbb89c4631e86.jpg
    Got some 36" super swamper TSLs
    F67EE615-5184-408F-9921-761455DDD051_zps_b6d9c11382c9ae578e99b07a5d3ca5dc40a3a71a.jpg
    Added the Flyzeye interior lighting kit I won at Big Dogs offroad raffle
    B228B2D8-F37C-48B7-8D1E-DCA1461BE57E_zps_7218a1155abab297d8bd7a487b49fd8b5ddf27ed.jpg
    Installed BeeRad hood lighting kit, thing is damn sweet
    BB08FE78-543C-42E3-A09C-185E07AB2CF2_zps_16ebe80f4c9a79fa4ef93c45eed36bee2c34c7b6.jpg
    PA radio stuffed under the hood mounted to the power steering resi
    06AFBE06-D4A0-4048-A3C8-8D2AC0B6E00C_zps_1ca81e77c0fd937cca3caad33ac9b5d634e0c59f.jpg
    That's all I got for now, stay tuned for more adventures :D
  2. Jul 20, 2014 at 6:37 PM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    Current projects:
    chopping fenders for new tires
    Casper66 likes this.
  3. Jul 20, 2014 at 6:40 PM
    PSU Taco85
    optional
    One more for the hell of it
  4. Jul 20, 2014 at 6:40 PM
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    In before the der... Wait nevermind. :cool:
  5. Jul 20, 2014 at 6:40 PM
    avw4x4
    avw4x4 Well-Hung Member
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    :thumbsup: good luck uploading all the pics!
  6. Jul 20, 2014 at 6:52 PM
    PSU Taco85
    optional
    Forgot to mention derp free. BS ≠ DERP
    Thanks! :laugh:
  7. Jul 20, 2014 at 6:57 PM
    drunktaco
    drunktaco Well-Known Member
    Sage
    Southwest Va
    Icon ext travel C/O's, Total Chaos UCA's, King R/R shocks, All-Pro leaf pack, lights, RCI skid, Brute Force sliders, ect.
    I was wondering when you would start one
  8. Jul 20, 2014 at 7:02 PM
    Bogg
    Bogg Well-Known Member
    Surrey, Canada
    07 TRD Sport 4x4
    Good looking truck Op
  9. Jul 20, 2014 at 7:02 PM
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Sub'd
  10. Jul 20, 2014 at 7:14 PM
    StealthTaco
    StealthTaco www.ecgfabrication.com
    Alec
    NC
    05 Black Tacoma TRD Sport 6-speed
  11. Jul 20, 2014 at 7:16 PM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Looking good Anthony
  12. Jul 20, 2014 at 7:18 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    and this truck still sucks
  13. Jul 20, 2014 at 7:23 PM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    +1
  14. Jul 20, 2014 at 7:40 PM
    PSU Taco85
    optional
    Once I had some free time from work to search through hundreds of pictures lol
    Thanks!
    :eek:
    :spy: :spy:
    Thanks Matt!
    Yep see nothing has changed here :D
    Ignored
  15. Jul 20, 2014 at 8:17 PM
    wrmathis
    Bonaire, GA
    parts and stuff
    best comment in thread
  16. Jul 20, 2014 at 8:29 PM
    PSU Taco85
    optional
    Here is what I worked on this past weekend. Found my bumper was kind of loose so I just figured the bolts had worked their way out a bit. I haven't had the bumper off since the initial install over 2 years ago. I removed the front bumper to regrease the winch and found that the mounts were cracked and my front bumper was probably ready to fall off pretty soon :eek:
    13F0E217-DF99-446E-9B99-04236882B88D_zps_713ce1c50d2b284a406019227f35d5826c797a23.jpg
    14739A95-0EA3-4B3C-8C66-A8588EFD380C_zps_a22faa6619ef36795b190bbc1565ab8e1e84067c.jpg
    I am not sure if they cracked from the vibrations or some heavy winching but I wasn't going to remount the bumper before they were right.
    Ditched the crappy Toyota studs they supply
    9BFCC7EF-68DB-40D5-BB5A-E711F0D60E78_zps_9d821661c98377070645de006822402785e9e2aa.jpg
    Repaired the cracked welds and cleaned the mounts up
    577B5679-BFFE-49E3-B878-C06A74F25BF3_zps_eede0ececb158d158885b5dde7ca5db18561e149.jpg
    Drilled out the holes to accept 1/2" grade 8 hardware, added a 1/4 plate in front.
    A313DA64-A7FC-4182-AE39-B84466F3BC0D_zps_78a52bad53c197b15eae526e059557b83406b805.jpg
    On the back side I added 1/4" angle iron drilled out to the template of the outer frame mounts, had to cut the front body mount a little bit, it gets tied back in once I'm finished
    2BAF8C3D-B8A4-4670-83D5-A9F6431E4D1F_zps_9841ee984084df8ffbc8ea6569dd40d22d0c9339.jpg
    The inner frame mounts get 1/4" angle iron as well bolting through an exiting hole in the frame
    94431219-7819-45AA-B008-BB82F587C7F1_zps_4073bfbd8ce6208e3705a384d9e86f1523c56bf3.jpg
    I drilled two new holes in the bumper right where the winch area sits
    9C1E1AD8-429D-4D77-BC88-153D3482A5F4_zps_fb2629fd95b1f82cd473b26e5d1fc47bf59cd1e2.jpg
    Mocking up a new crossmember
    97F6F083-250D-4979-B831-7F09B29C0EB3_zps_36c8194523e1066e7b0d66f56decf0c9047cfd0e.jpg
    EF0BE62F-1380-400C-986B-A7EBB9897062_zps_7b9425141efa045b22caf356facaaf6aaa6df1e0.jpg
    Gussets added to the mounts
    DACEE39D-1E15-4CF5-B464-77CDFDBB3571_zps_56888756358a56faa4f22ff4cb94969b8c0d88d8.jpg
    Burned into the frame
    F5B55BCA-15BA-45BF-9F33-D876C14F386D_zps_9caafbe61c9ad2eab60844f71d4f8dd0cb38e2e0.jpg
    071DCB0E-18E9-4833-B2FB-23A834D326F2_zps_60981a30018786bc92b0d07791a9fb644fbd1f72.jpg
    Front plate tied into the frame and front body mount
    3D75032D-CDEE-46D6-914B-1CA1BBC0E671_zps_4130e1ef0c8d2a729fc93b6b3a46b29d7040cc31.jpg
    Cut this body mount a bit too high so I added a peice of plate back in :eek:
    153E45B5-5B25-4574-AFDE-2D263B97D55E_zps_64613bf1f94f528775a4ad34fd2cd5098c3f9d69.jpg
    Painted up
    A1004FFB-87BF-4183-8618-44CA080B3E3B_zps_ba7a9ee6cf8a8209c5aed02028abc7af7c5822af.jpg
    Inner frame rail gusset painted up
    F36FBDF5-2DC8-4975-9457-6FBD4DEEB267_zps_5d782a7d5e4e1e5c6bde2d4807bf54e79655de0d.jpg
    3C3B2F54-B49C-46C3-A947-030EBD4AE418_zps_cf289fde41d4b01595337a07b3c5aaf8cd46f671.jpg
    Outer reinforcement burned in and painted
    3B718D96-C738-4A17-85EE-5A3765215ACD_zps_e4f972c29918c12c2a2d4ac6ee0a29bb42149468.jpg
    The bumper feels 1000x sturdier than before and I added 4 additional mounting points for a total of 14 and the front mounting points on the frame are now 1/2" thick instead of the 12 gauge steel they provide from the factory. Should be good to go now :D
  17. Jul 20, 2014 at 8:49 PM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    That is petty beef.
  18. Jul 21, 2014 at 7:34 AM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    :popcorn: nice work beefing dem mounts.
  19. Jul 21, 2014 at 7:35 AM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    That will last about... Oh wait \/\/\/\/\/\/
    :smack:
    ^^^this
    No shit! :rofl:
    ^^^^THIS!
  20. Jul 21, 2014 at 7:47 AM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Those new mounts look beastly
