Anthony's 2010 banworthy access cab mostly BS not much of a build thread
Discussion in '2nd Gen. Builds (2005-2015)' started by 6 gearT444E, Jul 20, 2014.
  1. Mar 28, 2016 at 8:56 PM
    #841
    planters15
    planters15 Well-Known Member
    Q (irfan)
    Pa - Spring City
    2010 Double Cab SR5 6spd
    Stuff to make go more off road
    Sucks.
  2. Mar 28, 2016 at 9:55 PM
    #842
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    Yeah that's what I get for ordering it through a different company, I may order the part directly through toyota and re-use my old snap rings and bearings. Cost is about $40 more but the parts would also be brand new.
    Blackout14 likes this.
  3. Mar 29, 2016 at 2:29 AM
    #843
    PSU Taco85
    optional
    The press brake was finished about 2 weeks ago, here was a quick demo I did. Seems like it should work pretty good :cool:
    https://youtu.be/irgtdlvyma8
    HomerTaco, Blackout14 and ajohnson like this.
  4. Mar 29, 2016 at 6:01 AM
    #844
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    That's neat. :cool:
  5. Mar 29, 2016 at 6:50 AM
    #845
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    It even neater doing a sheet of 1/4" for skids, bending is nice, eliminates extra welds
  6. Mar 29, 2016 at 6:58 AM
    #846
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    I was checking out the new one that Brandon @avid built. It uses 2 hydraulic jacks and is about twice the size. Even with that size its not easy to make a skid plates at all from what I can tell. Nothing compared to some of these more expensive machines that can rip them out in minuites like 4x innovations
  7. Mar 29, 2016 at 7:07 AM
    #847
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    For the average joe in the garage, these pressbrakes can save a ton of time. If you do it right you can even bend up plate bumpers in sections on a small pressbrake. No one's getting a brake like Adams got in their garage.
  8. Mar 29, 2016 at 7:15 AM
    #848
    2ndGenJonny
    Jon
    Gilbert, AZ
    I understand that this break can do a ton with patience im just saying that building a 1/4 skid wont be an easy task in a small break. Just moving that giant hunk of metal around is a PITA.
    I commend anyone willing to take on that task. It will have great reward once finished for sure. Notbto mention be significantly less expensive.
  9. Mar 29, 2016 at 7:43 AM
    #849
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Not if you bought the press to make one skid plate
  10. Mar 29, 2016 at 8:14 AM
    #850
    2ndGenJonny
    Jon
    Gilbert, AZ
    So hes not going to start a line of bondage toys?
  11. Mar 29, 2016 at 10:09 AM
    #851
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    As long as they're double ended, I'll buy one
  12. Mar 29, 2016 at 10:13 AM
    #852
    2ndGenJonny
    Jon
    Gilbert, AZ
  13. Mar 29, 2016 at 11:53 AM
    #853
    PSU Taco85
    optional
    Haha well this thread went downhill quick :p
    I mainly bought the press to be able to make brackets and other smaller stuff, and eventually I'll upgrade the Jack to an air over hydraulic so it would be much easier and faster. But yes that little 20" press brake doesn't stand a chance against some of the ones the pros use.
  14. Mar 29, 2016 at 11:57 AM
    #854
    2ndGenJonny
    Jon
    Gilbert, AZ
    Its not the size that matters tho..... Right?
    Thats what my GF says at least
    HomerTaco and PSU Taco85[QUOTED] like this.
  15. Mar 29, 2016 at 11:59 AM
    #855
    PSU Taco85
    optional
    The angle of the dangle plays some factors in there as well
  16. Mar 29, 2016 at 12:02 PM
    #856
    2ndGenJonny
    Jon
    Gilbert, AZ
    Some of us arent meant to hit the bottom but bang the hell out of the sides....
  17. Mar 29, 2016 at 12:12 PM
    #857
    PSU Taco85
    optional
    :rofl: :rofl: :rofl:
  18. Mar 30, 2016 at 5:05 AM
    #858
    cynicalrider
    cynicalrider #NFG
    Jersey
  19. Mar 30, 2016 at 6:07 AM
    #859
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    That drop-in on J makes me pucker just watching a vid.
    Video alone doesn't do it justice...
  20. Mar 30, 2016 at 6:36 AM
    #860
    cynicalrider
    cynicalrider #NFG
    Jersey
    Truth. J always has been a pucker trail but I think that's why I like it so much. I usually always just hug the rock and use it as a pivot point but the vids I got of Q and Ant make me confident knowing I don't need to. Also you can see in the vid exactly when Ant dropped off the rock on Yellow Jacket and how his wedged wheel caused so much damage to the front diff.
