Anti Lean?
Discussion in 'Suspension' started by nobigbro, Sep 6, 2011.
  1. Sep 6, 2011 at 10:20 AM
    nobigbro
    nobigbro [OP] Member
    Colorado and Texas
    2000 4WD V6
    Before I install my new suspension I thought I should measure my 2000 Taco as it sits now. Instead of a lean or it being level, I find out the DS is higher than the pax side. Left rear is almost .75" higher... empty bed, almost full tank. Front DS is .25"+ higher. So this is OPPOSITE the normal lean, right? Guess I don't need to worry about the spacer...
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  2. Sep 6, 2011 at 2:21 PM
    nobigbro
    Colorado and Texas
    2000 4WD V6
    so is this weird? or common?
  3. Sep 6, 2011 at 2:23 PM
    jberry813
    jberry813 Making TW Great Again Moderator
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Where is your starting point of reference? It looks like you are measuring from the ground -> up. You should be measuring from the center of the hub (as opposed to the ground). Measuring from the ground does not take into account discrepencies of tire wear.
  4. Sep 6, 2011 at 3:16 PM
    nobigbro
    Colorado and Texas
    2000 4WD V6
    yep... from the ground up. I'll remeasure, but doubt it will change .25-.75"
  5. Sep 6, 2011 at 3:20 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    And I think it goes without saying, but also measure on flat, level ground. If one measured parallel parked on the street (for example), that would certainly account for a higher driver side than passenger.
  6. Sep 6, 2011 at 3:24 PM
    nobigbro
    Colorado and Texas
    2000 4WD V6
    same results... from the hub center using a level and a straight edge... the DS is .375" higher than the right side in the front and .5625" higher in the rear.
    Anyone?
  7. Sep 6, 2011 at 3:25 PM
    nobigbro
    Colorado and Texas
    2000 4WD V6
    Good thought, but it's in my garage... pretty much flat and level.
  8. Sep 6, 2011 at 3:31 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Are you the original owner?
    If not did the previous owner have a morbidly obese wife that sat shotgun?
    I'm trolling at this point. Not sure what to suggest. Install your lift and call it a day. :notsure:
  9. Sep 6, 2011 at 3:38 PM
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    You can always throw the spacer on the pass. side.
  10. Sep 6, 2011 at 3:39 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I say lift it and leave it. Chances are after the new suspension settles he'll be dead on flat.
  11. Sep 6, 2011 at 3:42 PM
    horwitzs
    Seth
    Dayton, WA
    TX Pro
    Good point, I guess we don't really know if it's just due to worn parts on the right side.
  12. Sep 6, 2011 at 3:43 PM
    nobigbro
    Colorado and Texas
    2000 4WD V6
    I'll bet you're right. In fact, with my 195lbs in the thing, it's probably dead on right now.
    It's just weird because as far as I can tell, I'm the only guy with it leaning the other way.
  13. Sep 6, 2011 at 3:44 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Definitely get a no fat chicks sticker to prevent further reverse taco lean problems.
  14. Sep 6, 2011 at 3:56 PM
    nobigbro
    Colorado and Texas
    2000 4WD V6
    :rofl::rofl:
    Doubt it's that tho. My pax, if any, is my wife. She's 5'5" and a buck twenty.... the mystery deepens...
  15. Sep 6, 2011 at 3:57 PM
    nobigbro
    Colorado and Texas
    2000 4WD V6
    another good thought.... bound to be what it is.
