Anti-Static Strips
Discussion in 'Technical Chat' started by BillC2012, Oct 25, 2008.
  1. Oct 25, 2008 at 5:44 PM
    BillC2012
    BillC2012 [OP] Bill
    Toronto, Ohio
    Fully Loaded 4WD
    Roll-N-Lock M-Series, Cargo Manager
    Ah... The changing of the seasons. Autumn has returned to Ohio and with it the annual loss of ambient humidity My '09 Tacoma started handing me static shocks upon entry and exit a few days ago.
    Is there an effective method to ground the truck to prevent this? I had a pair of supposed conductive rubber anti-static strips hanging from my '05 4Runner with little or no relief.
  2. Oct 25, 2008 at 6:53 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2002 Tacoma Xcab
    :confused: rubber isnt conductive and wouldnt discharge any static you have built up...
    do like the guy above said and just touch your car to the sheet metal and youll discharge all the static build up
  3. Oct 25, 2008 at 6:59 PM
    hoosiertaco
    hoosiertaco Well-Known Member
    he may be refering to the steel impregnated static strips like what they use on boomlifts and forklifts that have solid rubber tires. I know they use these mounted to the frame and dragging the ground. This could be done if the static was bad enough, it would just look funny under the truck, not to mention everyone would stop you to tell you that something was falling off of your truck.
  4. Oct 25, 2008 at 7:36 PM
    lakewoodbilly
    lakewoodbilly Well-Known Member
    Bill
    Lakewood, CO
    White 08 DC V6 SR5 4WD TRD Sport
    Factory DRL's, Underhood Flood LED's, Underbody Multi-color LEDS, Red Line Tuning Elite Hood Struts, Anytime Fog Lights, PIAA 4100 Intense White, Luminics JDM Yellow H10 Fog Lights, OBX Sport Pedals, Sill Protectors, Bed Net, Front Bed Tie Downs, iPod and Aux Factory HU Interface, Sirius Sportster 5, Satellite Antenna through third brake light
    when living in colorado, which is a very dry state and you always have electro-static discharge concerns, I always made sure to touch my truck bed far away from the fuel fill door when I was re-fueling.
  5. Oct 25, 2008 at 9:31 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    I used to run the static stips when I worked in the plants. The work, but like stated above people will tell you that something is hanging.
