Antifreeze / Coolant - Red, Pink, Green ???
Discussion in '1st Gen. Tacomas (1995-2004)' started by Old Soul 76, Oct 10, 2012.
  1. Oct 10, 2012 at 6:13 PM
    Old Soul 76
    Old Soul 76 [OP] Active Member
    Kansas
    '99 Tacoma TRD SR5 3.4L V6
    I've been looking for a thread that simply states the differences, and couldn't find one
    I want to know...
    What is the difference between red, pink, and green antifreeze (collant, radiator fluid, etc.)?
    Red -
    Pink-
    Green-
    AND
    Which should be used in a 1st gen tacoma?
    (specifically a '99)
  2. Oct 10, 2012 at 6:57 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    I would use good 'ol green. Orange is GM, red goes in tranmission, and nothing pink is going near my truck other than the the wifes guns.:D
  3. Oct 10, 2012 at 6:58 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    oem is pink if i recall correctly
  4. Oct 10, 2012 at 7:25 PM
    MtnDon
    MtnDon Member
    06 TRD Off Road
    More than you asked for.... :)
    In recent years, there have been many changes, given the new developments in the area of engine coolant. Several manufacturers are specifying their own type of antifreeze, and it can be confusing to the consumer as to which color or formulation of coolant is acceptable for their car. Some European coolants are based on a different pH scale from those made for American cars, because of the differences in plain water between the two continents. This adds to the consumer's confusion.
    All antifreeze falls under one of three basic types.
    Inorganic Acid Technology (IAT) This is the common green stuff original equipment manufacturers have used for over 70 years. Ethylene glycol is its base chemical, and there are silicate and phosphate additives that make it compatible with copper, brass, cast-iron and aluminum cooling system components. Manufacturers recommended that you change the green IAT antifreeze every 36,000 miles or three years. IAT coolant was used in GM vehicles until 1994. Chrysler used green IAT fluid until 2001, as did Ford (with the exception of some 1999 models that used OAT blue coolant which must be purchased from Ford).
    Organic Acid Technology (OAT) Commonly referred in GM vehicles by the brand name, Dex-Cool or to other manufacturers as propylene glycol. GM introduced Dex-Cool in 1995 as an "extended life" coolant, though most GM car owners and repair shops are finding that Dex-Cool is good for only about three to five years before it needs to be replaced. But because of the additives in the Dex-Cool orange antifreeze, you do not want to substitute the old reliable green coolant. Usually (but not always) dyed orange or yellow so you could tell the difference between OAT and IAT, this coolant has similar corrosion protection to the green stuff; however, it is designed to be slower acting, hence the extended-life moniker. It is made from a propylene glycol base, which makes it less poisonous than conventional IAT for children and pets. OAT, when spilled or lost due to a boil-over, is much less harmful to the environment. In addition to its use in 1996 model year and newer GM cars and trucks, OAT is also used in 1996 to 2001 Audi, Land Rover, Nissan, Mazda, Toyota, Honda, Kia, VW, Jaguar, Saab and Porsche. Manufacturers are now recommending your OAT coolant be changed every five years. OAT coolants are currently readily available from most auto parts stores.
    Hybrid Organic Acid Technology
    (HOAT)
    This coolant is usually dyed yellow but comes in other colors like green, pink, blue, red and orange, which leads to a lot of confusion. One way to know for sure if you are getting HOAT will be by the packaging. Manufacturers often refer to this antifreeze as "global" and will indicate on the bottle that it meets or exceeds the specification "G-05" for most European cars and G-11 or G-12 for Volkswagen and Audi. Hybrid antifreeze has added silicates for aluminum protection and is advertised as having a five-year change interval. Normally, HOAT coolants are specified for vehicles newer than 2002, specifically Mercedes, Volvo, Ford, VW, Audi, Chrysler, BMW and Saab.
    The use of OAT and HOAT coolants can extend the life of rubber coolant hoses, because they conduct less electrochemical degradation or ECD than the conventional green antifreeze. ECD is the process by which the motion of coolant and water through your engine creates an electrical charge similar to a galvanic battery. This electrical charge degrades both rubber and metal parts in the cooling system from the inside out. ECD can be attributed as the cause of many premature coolant system failures. Volkswagen, Audi and other European vehicles use antifreeze that can be blue, pink or red in color. Most of these are available under the brand name Pentosin in 1.5-liter bottles. The pink and red are specifically designed for alloy engines and both meet the required G-12 coolant specification. The blue is also for alloy-based engines, but with a different pH level, and is equivalent to the G-11 rating.
    You will find other types of antifreeze available for heavy-duty trucks. Both pink antifreeze (no, not the same stuff as used in the toilet in your camper at the lake house) and red are sold for truck use. These should not be confused with the pink or red HOAT coolants used on imported vehicles because they are designed specifically for trucks. These coolants will usually say "low-silicate" and "final charge" or "fleet charge" on them. They will do you no good in your passenger car because the lubrication and metal protection additives are separate in large truck cooling systems.
    So what should you use?
    Manufacturers will tell you to stick with what is in there. You can have the cooling system cleaned with a coolant filtration system. This is a very popular tool in repair shops today and will recycle your antifreeze. Component chemicals can be re-added to boost its boiling and freezing point and adjust the pH of the cooling system back to specifications. The most accurate tool for measuring OAT and HOAT potency is a refractometer, which is an expensive piece of equipment, so you should have the coolant checked by a service station before deciding whether it should be replaced or refurbished. If you are low on fluid or have a leak, a general rule of thumb is, green IAT is always replaced by green IAT coolant. Dex-Cool or an OAT product with equivalent specifications is always necessary to replace orange or yellow organic-based antifreeze. For the rainbow of colors of HOAT, your only substitute is the yellow or amber global antifreeze. Global coolant will not change the color of the stuff that is already in there. If original red, blue or pink antifreeze is desired, you must get these from a Pentosin supplier or your car dealer. Can you run organic coolant in an earlier vehicle? Yes and no. OAT will work if your radiator is aluminum and you flush your entire cooling system with water and completely refill with OAT, but there are some issues with the interaction between organic coolants and lead solder, so using OAT in a copper radiator is not recommended. In short, antifreeze these days is a buyer beware deal. Check your owner's manual for the correct fluid, and read the label on your replacement coolant carefully to ensure it meets with the required specifications.
    AND...
    Red and Pink antifreeze Toyota makes two antifreeze colors.
    Red is called "long life" antifreeze that's the color of blood.
    pn# 00272-1LLAC-01
    Concentrate; dilute with distilled water, 50/50
    Pink antifreeze is called "extended life" that comes in most new model Toyota and the Scions.
    pn# 00272-5LLC2
    pre-diluted with distilled or maybe it's de-mineralized water. Use as it is out of the jug. No further dilution
    SR-71A, McDudesYota and Norton like this.
  5. Oct 10, 2012 at 7:49 PM
    MtnDon
    MtnDon Member
    06 TRD Off Road
  6. Oct 11, 2012 at 9:48 AM
    asus611
    asus611 Well-Known Member
    CA
    03 Double Cab Prerunner
    I still use Toyota Red, which is what came with car when it was new, and is what I have been using for the past 9 years. Thought about switching over to the pink super long life, but hey, why mess with something if it isn't broken
  7. Feb 16, 2016 at 8:10 AM
    kdwellssr
    kdwellssr Well-Known Member
    Kelly
    Arkansas
    99 Tacoma ext cab 4x4 v6 automatic
    30.5 tires, Nerf bars, Brush guard, Trailer tow kit
    I don't have a manual and need to know what Toyota recommends for the 99 tacoma coolant type or color?
  8. Feb 16, 2016 at 9:57 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    if you have a 1995-2003, use red and dilute 50/50. If you have a 2004, use pink (it is already diluted).
    Source: The dealer fluid guideline book
    JudoJohn likes this.
  9. Feb 16, 2016 at 3:54 PM
    kdwellssr
    Kelly
    Arkansas
    I have two . One is 99 and one is 04. Can I use the Red it both of them? Or must I get the pink?
  10. Feb 16, 2016 at 8:02 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    You don't HAVE to use pink in the 2004 if you don't want to, especially if it's going to make your life easier. But pink is what it came from the factory with.
  11. Feb 16, 2016 at 9:04 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
  12. Feb 16, 2016 at 9:20 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Owner's Manuals are available from the Toyota Owner's Web Site, kdwellssr.
    FWIW, page 324 of the Manual for my '04 says "'Toyota Super Long Life Coolant' is filled in your Toyota vehicle at factory fill. In order to avoid technical problems, only use 'Toyota Super Long Life Coolant' or similar high quality ethylene glycol based non-silicate, non-amine, non-nitrite, and non-borate coolant with long-life hybrid organic acid technology."
  13. Feb 17, 2016 at 7:59 AM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    Something like that is written the manual for my Civic. I had a hell of a time finding out what coolants actually fulfill those requirements.
    For my truck, I bought Pentofrost A1.
  14. Feb 17, 2016 at 8:10 AM
    Trapperr
    Trapperr Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    Funny story about buying coolant from the dealership this week..
    Me: I need some coolant. Which of these 2 (red or pink) does my vehicle take?
    Toyota Parts Counter Guy: For your 2002? I think that just takes the plain old green stuff.
    Me: There's red coolant in there now.
    Toyota Parts Counter Guy: Then yours takes red.
    I have little to no faith in the ability of the guy at the parts counter if it isn't right up there on the screen in front of them.
  15. Feb 17, 2016 at 8:18 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
  16. Feb 17, 2016 at 10:37 AM
    mwrohde
    Sugar Hill, GA
    That just further convinces me that I can't tell the difference between one and the other. I can read the words, but I don't know what they mean. I don't know what ingredients are meaningful and what aren't. I don't know what the ramifications are for the inclusion or exclusion of one or more of them.
  17. Feb 17, 2016 at 10:40 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    You have an '03. So use red. Which is called "long life". Not "super long life". And make sure to dilute it 50/50 with distilled water (not tap!). That is all you need to know.
  18. Feb 17, 2016 at 12:57 PM
    Trapperr
    Reno, NV
    Something else that crossed my mind. The 3.4l system says it takes 10.5qts of coolant. So a gallon of long life and a gallon of distilled water equals 8qts. Are you guys dropping another $40 at the dealer to make a perfect 50/50 mix??? Or will you be ok with just using water for the last 2.5qts? I'm talking about the undiluted coolant.
  19. Feb 17, 2016 at 3:01 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    You live in NV? You should be fine with a 60/40 mix then.
  20. Feb 17, 2016 at 8:52 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    I'm a solid believer in the old green stuff. I think the deal with all these new colored coolants is a gimmick dealerships use to get you to sucker up and spend more money buying their labeled "OEM" kool-aid. My truck currently has the red/pinkish coolant in it, but when it comes time for a radiator flush, it's getting refilled with the tried and true green stuff. It's been used in all types of cars for 70+ years already, don't see why switching back to it would harm anything.
