Antifreeze question?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PFD FIRE, Dec 12, 2015.
  1. Dec 12, 2015 at 6:46 AM
    PFD FIRE
    PFD FIRE [OP] Well-Known Member
    David
    San Diego
    2011 Toyota Tacoma TRD Sport
    265/75/16 Goodyear Duratrac Tires, Total Chaos UCA, Bilstein 6112 Coilovers (front) Bilstein 5100 (rear), TRD CAI, TRD Cat Back Exhaust, Rough Country/Lamphus LED lights, rear ARB locker, Baja Rack
    Hi Everyone,
    Im about to (DIY) flush my radiator for the first time on my truck. "Don't worry I won't burn myself...lol". My question is what antifreeze is best for my 2011 toyota tacoma? I figured I'd get the premixed 50/50 antifreeze that will make easy to pour and skip the mixing of water and antifreeze all together. Any advise would be greatly appreciated :)
  2. Dec 12, 2015 at 9:40 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I use this
    http://www.amazon.com/Zerex-675130-...d=1449941541&sr=1-1&keywords=asian+antifreeze
    a lot cheaper and the same color and spec's. I got it a Car Quest for $14
    You should get this too - probably cheaper some where else - I don't remember where I got mine.
    http://www.amazon.com/Lisle-24610-S...F8&qid=1449941754&sr=1-1&keywords=lyle+funnel
    I don't flush - just drain radiator and fill it every 30k - since they recommend 100k I figure 30k is fine.
  3. Dec 12, 2015 at 10:16 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Toyo super duper dopeass eternal life pink 50/50 shit.
    Torspd likes this.
  4. Dec 12, 2015 at 10:20 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Zerex Asain. Did it at 50K for good measure.
  5. Dec 12, 2015 at 10:27 AM
    george3
    New Jersey
    2 vote 4 Zerex Asain
  6. Dec 13, 2015 at 12:58 PM
    lunchbox421
    lunchbox421 Member
    California
    2015 Doublecab 4x4 SR5 Silver Sky
    Make sure you flush the cooling system several times to get out all the old coolant. If you had green coolant and going to use red or vise versa you need to get all the previous coolant out because the chemicals are incompatible and could cause problems for your engine in the future, or so I have been told.
    I usually do initial flush with garden hose and one or two more with "distilled" water (glacier water machine in front of supermarkets). Also use pure water when mixing coolant to minimize mineral build up in cooling system.
    DrFunker likes this.
  7. Dec 13, 2015 at 2:30 PM
    PFD FIRE
    David
    San Diego
    Cool thanks everybody for all the advice :)
  8. Dec 13, 2015 at 3:00 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Premixed antifreeze is a waste of money. Why pay for half a gallon of tap water?
    Lester Lugnut and CurtB like this.
  9. Dec 13, 2015 at 3:05 PM
    DrFunker
    DrFunker Well-Known Member
    Crom, Did you do a whole flush out first or just drain and add?
  10. Dec 13, 2015 at 3:30 PM
    Crom
    Nick
    San Diego, CA
    Millions
    I drained the radiator, and block drains on both sides of engine. There is a writeup posted somewhere. Pretty easy to do. Getting rid of the used coolant was the hardest part. And block drain bolts were tightened by Hercules himself at the Toyota factory.
    DrFunker[QUOTED] likes this.
  11. Dec 13, 2015 at 4:08 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Once a year, open the radiator drain cock and let it drain. Close cock and refill with 50-50 mix. Repeat next year, and next year, and the next... pretty simple ain't it?
  12. Dec 13, 2015 at 5:29 PM
    Capt Jrod
    Capt Jrod Well-Known Member
    Jarrod
    Northern Ohio
    15 WHITE DCSB 4x4 TRD SPORT
    As an hvac guy I can tell you to spend the whole $1.50/ gallon and buy distilled water. The hardness, chlorine, and minerals in tap water is not cool. It keeps me in business with boilers, valves and pumps. I use Toyota Oem antifreeze and drop and fill the radiator every 50k. The cost is higher, but it is a peace of mind thing
  13. Dec 13, 2015 at 5:52 PM
    vlodpg
    vlodpg Well-Known Member
    Connecticut
    15 Tacoma TRD Off Road 6sp Supercharged
    TRD Supercharger/URD Stage II Clutch
    Go to Walmart & you can get distilled water for $0.88, along with a gal of straight AF & you are good to go!
  14. Dec 13, 2015 at 6:21 PM
    DrFunker
    Is this the one?
  15. Dec 13, 2015 at 6:44 PM
    Crom
    Nick
    San Diego, CA
    Millions
  16. Dec 13, 2015 at 8:31 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I'm inclined to agree. I have used the Zerex equivalent of Toyota SLLC because it's $7-$8 a gallon cheaper than the latter and a 1/2 mi. away at a local McParts store. Recently I saw the 50K Toyota Red coolant at a dealership. Full strength. Makes 2 gals. of coolant. Toyota's SLLC is supposedly good for 100K, but I'm not one who would ever push coolant or any other fluid that long.
    Use what works for you.
  17. Dec 13, 2015 at 8:35 PM
    Thomas Jefferson
    Thomas Jefferson Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
    It's not a bad idea depending on where you're located and whats in your tap water. For example where I love has super "hard water" where it leaves calcium deposits on pool tile and drinking glasses develop a cloudy substance on them too if used for a while. I wouldn't want to put that in my engine. The premixed stuff is a safer bet.
  18. Dec 13, 2015 at 8:44 PM
    Lester Lugnut
    The solution to hard water is a gallon of distilled water for about a buck at your local grocery store.
    steelhd likes this.
  19. Dec 13, 2015 at 9:04 PM
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    This.
