Antifreeze?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blackonwhite, Dec 17, 2009.
  1. Dec 17, 2009 at 2:01 PM
    blackonwhite
    blackonwhite [OP] Well-Known Member
    06 white tacoma black 17' ssr wheels
    So a long time ago I drained the antifreeze ( the pink stuff). out of my truck. It was Probably around 20 k when i did it ( why i did this i do not even remember and looking back on it wtf was i thinking)..but anyways... i drained it all out and flushed it and everything, and put new antifreeze in it that wasnt toyota coolant. it was made for all engines anyways i think it was prestone green crap.. is this gonna kill my motor eventually and should i change it back to the toyota stuff. i didnt mix the two colors so i dont kno
  2. Dec 17, 2009 at 2:11 PM
    stang88
    stang88 Well-Known Member
    no its not gonna kill ur motor... ur motor isnt made any differently then others.... while toyota coolant is preferred.. its not a must.
  3. Dec 17, 2009 at 2:15 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    I THINK, the toyota specific coolant doesnt NEED to be the end all replacement, I actually used a Prestone product that was intended for GM, FOrd and Chrysler, it was pink but the main issue was a corrosion inhibitor for cars that have cast iron blocks and aluminum radiators. We have iron blocks and aluminum heads. It needs to be flushed every 5 years or 150 K miles. I have 106K on my 1999 now and have flushed it twice. I think the key is change it every 4-5 years to help water passages free of corrosion, which can happen when two dissimilar metals are used(aluminum head on a steel block.)
  4. Dec 17, 2009 at 2:40 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    If you end up with a cooling problem or leak change it back to pink
  5. Feb 9, 2010 at 9:42 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    Do you have to mix the Toyota's coolant w/ water (50/50) or can you just pour straight from the bottle into the resvior?
  6. Feb 9, 2010 at 10:14 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    You should mix to whatever temperature you get. 50/50 is default but if you are in Texas you may want to do less coolant more water in order to provide more cooling.
  7. Feb 9, 2010 at 10:16 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    Was it a 50/50 mixture of water and ethelyne glycol? If so, you should be good!
  8. Feb 9, 2010 at 10:29 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    When I was a kid (17) I flushed the anti freeze in my Jeep... With advice from a friend who said if 50% anti freeze with water is good, then 100% has got to be better! Sounded logical!
    WRONG! LOL I over-heated, ruined a water pump, and learned to trust factory recommendations!
  9. Feb 9, 2010 at 10:33 AM
    ShadowFalken
    ShadowFalken Well-Known Member
    Jim
    Maryland
    10 Off Road
    Raptor stainless bars, Wet Okole covers, RollBak bed cover, PopNLock, Redline hood struts, XM radio factory kit
    If your truck specifies Toyota SLLC (Super Long Life Coolant) it is only sold by Toyota as a pre-mix. It is an HOAT (Hybrid Organic Acid Technology) and mixing with tap water can cause problems.
    The old toyota LLC (Long Life) was a high quality standard anti-freeze (ethylene-glycol).
    Do not mix Dex-Cool (GM Product) with Toyota SLLC it is not the same product.
    I do not care for one size fits all coolants. Metals are not the only thing in cooling systems. There are rubbers and plastics too, and these can be negatively impacted by the wrong chemistry being used. Problems do not show up immediately so the connections to incorrect fluids are rarely made.
  10. Feb 9, 2010 at 10:55 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    I don't like the new coolants. They probably have them correct now but I remember when the orange stuff (Dex-Cool) came out, it caused all kinds of problems and gunked up the coolant sytems. Good old GREEN is the way to go. There was never any issues and works great. The new versions seem like gimicks to me.
  11. Feb 9, 2010 at 11:06 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Firestone Destination LE2 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    +1
  12. Feb 9, 2010 at 11:19 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Haha funny how its supposed to have a corrosion inhibitor...My buddy has been borrowing his mom's spare vehicle, a PT cruiser while his car is out of commission and had a METAL coolant line burst on him about 2-3 weeks ago. The car has 65k miles, the fluid has never been changed in it, still factory fluid since they bought the car new from the dealer. I can understand a rubber hose failing but a metal coolant line..thats ridiculous. When I pulled the radiator cap and we drained the system it was full of corrosion. The thermostat was a block of rust, the coolant line got a hole in it about the size of the of a pen because it corroded from the inside out. The outside of the line still looked brand new.
    let me re-iterate again, this pt cruiser has 65k miles, bought new from the dealer, still had the factory coolant, we live in GA so the car has zero exterior corrosion on any of the parts.
    Chryslers are junk...END RANT
    As for the question about your taco. You should be fine. I put almost 100k miles on my old honda with prestone green 50/50 mixed with about 80% tap water and a bottle of redline water-wetter mixed and the day I sold the car the coolant was still as "clear" as it was when I originally changed it.
