Any chance that diff drop may fix front vibration issue?
Discussion in 'Suspension' started by KRich, Nov 20, 2011.
  1. Nov 20, 2011 at 10:56 PM
    KRich
    KRich [OP] Well-Known Member
    BC, Canada
    07 Black DCSB TRD Sport 4x4
    Hi all,
    I know that there are countless threads about this topic and I have searched through most of them. There seems to be an almost 50/50 opinion about the usefulness of a diff drop kit.
    I recently installed Billys set at 2.5 in the front with a Toytec TSB AAL and spidertrax spacers. I had a pretty strong vibration around 60 km/hr before changing my stock size tires on the TRD 17" rims to 265/70/17 and getting an alignment done. Now the vibration is still there but not as noticeable. It does always go away when I put it in 4HI so I know that there is a good chance that it is a faulty diff/bearing. I just want to know if anyone has had any luck with the diff drop fixing the vibration or if it is just wishful thinking on my part and if I just need to suck it up and go to the dealership if it bothers me enough.
    cheers,
    Kyle
  2. Nov 21, 2011 at 9:19 PM
    KRich
    BC, Canada
    bump :)
  3. Nov 22, 2011 at 5:41 PM
    KRich
    BC, Canada
    Does the lack of response mean no one has had any luck with the diff drop fixing the vibration?
  4. Nov 23, 2011 at 1:44 PM
    KRich
    BC, Canada
    I know someone wants to help me possibly save time and money!
  5. Nov 24, 2011 at 6:55 PM
    KRich
    BC, Canada
    bump
  6. Nov 24, 2011 at 6:56 PM
    jandrews
    '09 FourDubDee TRD OR
    Highly unlikely. Your vibe probably has more to do with CV angle or the famous needle bearing problem.
  7. Nov 24, 2011 at 7:17 PM
    Nonfatwater7
    Nonfatwater7 Well-Known Member
    Missoula, MT
    06 DC LB 4x4 Indigo
    Map Light mod, 265/70/17 BFG AT's, 5100's front set at .85, Eibach coils, Hi-lift bed rail mount, CB radio, Sway bar removed, 886 reverse light mod, LED tail lights and blinkers, Wickedflows exhaust, $4 aux/ipod input mod
    Diff drop changes both dude...
    just install it and see, I am in the same boat and plan on throwing mine in. I actually have the same setup for the most part. I am working on a clunk at the moment because the vibes don't bother me. Here is your issue though, dropping the diff will allow things to hit it more easily. Not dropping it will cause more stress on your CV axles. That being said, I read somewhere that someone put like 60,000 on their lift with no diff drop so you are ok as long as the vibes don't bother you.
    1: Convince yourself its the tires
    2: Tell everyone its the tires
    3: Ladies like vibes
    jea4x4 likes this.
  8. Nov 24, 2011 at 8:14 PM
    KRich
    BC, Canada
    Yeah, I'm pretty tempted to try it even if it's a small chance. It seems like some guys have had the problem come back even after having their diff replaced by the dealership. Still seems strange to me that I could have absolutely no vibe at stock height with a bad diff bearing.
  9. Nov 24, 2011 at 8:35 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Diff drop really doesn't do a whole lot for the cv angles, and it won't make the vibe go away either. It may make it less noticeable for a little bit, but if the problem is there, it's not going away until it's fixed. The fix is replaceing the bearing yourself, cuz toyotas manufacturing process doesn't seem to be able to install them correctly. If you have rear vibe issues, then a CB drop or axle shims, or a combination of both will remedy that. But a faulty bearing in your front diff is going to stay faulty til it's replaced.
  10. Nov 25, 2011 at 10:00 AM
    KRich
    BC, Canada
    Did you replace the bearing yourself? Unfortunately I think that is well above and beyond my mechanical aptitude :). I think I will be stuck with whatever Toyota will do for me.
  11. Nov 26, 2011 at 9:57 PM
    Nonfatwater7
    Missoula, MT
    06 DC LB 4x4 Indigo
    or you could just drive it with vibes...
