Any Chemistry people?
Discussion in 'Personal & Emotional Support' started by UNDEAD1153, Feb 29, 2012.
  1. Mar 19, 2012 at 5:23 PM
    #41
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    give me a min
  2. Mar 19, 2012 at 5:29 PM
    #42
    UNDEAD1153
    UNDEAD1153 [OP] Well-Known Member
    Weston
    Chattanooga Tennessee
    White 2011 TX Pro Double Cab
    Rough Country 6" lift, 17" XD Addicts, 315/70/17 Nitto Trail Grapplers, 6K HID's, Wet Okole's, Kenwood DD head unit, Custom Exhaust
    Thanks dude! I think what I'm confused on is how to set up this part "initial mass(g)*(number of mol of reactant/molar mass reactant(g))*( number of mol of product/number of mol of reactant)*(molar mass of product(g))= total mass of product(g)" just where and why you place each part where you do.
  3. Mar 19, 2012 at 5:50 PM
    #43
    Konaborne
    Cody
    Kealakekua, Hawaii
    shit, came out kind of hard to read
    but use this outline op
  4. Mar 19, 2012 at 5:51 PM
    #44
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    i made a picture haha. basically 1 mol= molar mass so those are basically a conversion factor. then the mol of product/mol of reactant are to convert between the compounds. it is like a proportion i guess. here is a picture
    you multiply across both top and bottom and then divide the top by the bottom. showed how they cancel out too color coated and all! haha
  5. Mar 19, 2012 at 5:57 PM
    #45
    Konaborne
    Cody
    Kealakekua, Hawaii
    basically, you put
    the weight/quantity given in the equation, in this case
    54.0g Al
    then multiply/divide that by the molar mass of the reactant, in this case
    54.0g Al 1mol Al / 27g
    then multiply/divide that by the number of mols of the reactant, compared to the number of mols of the product. Both can be found in the original equation, in this case
    54.0gAl 1mol Al/27g 3mol Cu/ 1mol Al
    work that through and you end up with 6 mols of Cu made
    do the same for CuSO4, and find which number is smaller.
    the one with the smaller number is the limiting reactant; that reactant will get used up before the other, and how much product is made depends on that limiting reactant.
    then once you have how many mols of the product is made with the limiting reactant, just multiply the mols made by the molar mass.
  6. Mar 19, 2012 at 6:20 PM
    #46
    UNDEAD1153
    Weston
    How did you get 6mols of Cu? I keep getting 0.666??
  7. Mar 20, 2012 at 6:09 AM
    #47
    Squisha
    Squisha Well-Known Member
    Westminster, CO
    99 Taco Reg Cab 4x4
    Ok let's break this down a little.
    First, you need to make sure you balance that equation!!
    Since your answer isn't affected for this first question, you'd get away with it, but I'd prefer you know how to use your tools.
    The equation (balanced) is
    2Al + 3CuSO4 ~~> Al2(SO4)3 + 3 Cu
    First, get your molecular/atomic weights together. My advice is, for the purpose of practice, to do them all, even if you don't need them. It helps alot both for your understanding and for your teacher to see that you understand it to show your work. Write it all out--they'll be able to follow your logic and you'll have an easier time pinpointing when you've made a mistake.
    Al = 26.981g/mol
    CuSO4 =
    Cu=63.546
    S=32.065
    O=15.999 (x4)
    CuSO4 = 63.546 + 32.065 + (15.999x4) = 159.607g/mol
    So now we can figure out how many moles we have to work with:
    1 mol Al x 54g Al = 2.001 mol Al
    26.981g Al
    1 mol CuSO4 x 319g CuSO4 = 1.9987 mol CuSO4
    159.607g CuSO4
    Written out this way you can be sure visually that the units cancel.
    We've got 1.9987 mol CuSO4. We want to know how many moles of Cu we can make with that.
    3 mol Cu x 1.9987 mol CuSO4 = 1.9987 mol Cu
    3 mol CuSO4
    The 3's cancel, as do the "mol CuSO4" leaving you with 1.9987 mol Cu.
    So now we simply convert the moles of Cu to grams using the atomic weight of Cu, which we've already written out (see again why it's good to write it all out?)
    63.546g Cu x 1.9987 mol Cu = 127.009g Cu
    mol Cu
  8. Mar 20, 2012 at 7:02 AM
    #48
    Squisha
    Westminster, CO
    99 Taco Reg Cab 4x4
    It's been awhile since I've done the gas stoichiometry thing, but after poking around a little, I've jogged my memory enough to remember that with Standard Temperature and Pressure, this is a very easy thing to figure out.
    First, make sure you have a balanced equation:
    2H2 + O2 ~~> 2H2O(g)
    (I've specified here that the product is supposed to be in gas form. If you were collecting the water as a liquid, the beginning would be the same, but you would end a little differently. I can do both just for giggles here.)
    First, convert to moles (moles moles moles!! It's all about the moles. If you can convert various reactants and products to moles, you're 90% of the way to understanding what you're doing!)
    For gases, you simply use the Ideal Gas Law (the complicated version is a calculation using PV=nRT ~~Pressure x Volume = moles of gas x gas constant x temperature (K)
    The shortened version (made SO easy with the statement "STP) is that at Standard Temperature and Pressure, 1 mole of gas = 22.4 Liters of gas. If you hated your life enough (I sure as hell don't, I own a Tacoma:D ) you could use the above equation and work it all out and get the same answer.
    So long story short here, back to converting to moles:
    H2:
    1 mol H2 x 8.6L H2 =0.384 mol H2
    22.4L H2
    O2:
    1 mol O2 x 4.3L O2 = 0.192 mol O2
    22.4L O2
    Interestingly, these come out exactly (they are in exact proportions, so you can use either reactant to find your product), since you need 2 moles of H2 for 1 mole O2 and 0.192 (mol O2) x 2 is 0.384 (mol H2)
    To get moles H2O:
    Testing above statement, I'll do it using each reactant.
    H2:
    2 mol H2O x 0.384mol H2 = 0.384 mol H2O
    2 mol H2
    O2:
    2 mol H2O x 0.192mol O2 = 0.384 mol H2O
    1 mol O2
    To convert moles H2O in gas form back to liters, we use the same conversion factor we used for the other gases:
    22.4L H2O x 0.384mol H2O = 8.6L H2O (g)
    1 mol H2O
    If you were to collect this as a liquid, you would use the molecular weight of the water instead (to produce the product in grams):
    18.0g H2O x 0.384mol H2O = 6.912g H2O (l)
    1 mol H2O
  9. Mar 20, 2012 at 7:25 AM
    #49
    SCGuyInACOMA90
    SCGuyInACOMA90 Well-Known Member
    Alex
    Statesboro, GA
    2007 Silver Streak Mica SR5 4x4
    Leveling Kit, Westin Sportsman Grille Guard, 6000 K HIDs, PA/CB Radio, and much more to come!
    im a chemistry major in my senior year. so i will check back on this ASAP. im actually being a wonderful studious individual right now and browsing TW while in my government class. but will get right back on here to see if i can help.
    GodSpeed
  10. Mar 20, 2012 at 7:27 AM
    #50
    friction
    friction Well-Known Member
    Charleston, SC
    '08 4X4 RC SR5
    This gives me nightmares. Studying in high school was a non-issue for me...except for chemistry! I think that was my only C and I was glad to have it. Best of luck.
  11. Mar 20, 2012 at 9:32 AM
    #51
    YellowDog01
    YellowDog01 Well-Known Member
    04 4x4
    Wanna help me with Ochem??
  12. Mar 20, 2012 at 10:06 AM
    #52
    UNDEAD1153
    Weston
    Thanks so much for helping! I took the test (sorta....) in my third period, only 2 people out of 19 finished, we all have to go back after school and finish. I'm still beyond confused and trying to learn by 3:00 EST.... Might be impossible....
    I'm not understanding why you put what you get where you do because there are so many different types of problems and no set equation to use. If there is an equation I can use for the different types I could memorize those but otherwise I don't know what to do, it's just not clicking....
  13. Mar 20, 2012 at 10:29 AM
    #53
    Squisha
    Westminster, CO
    99 Taco Reg Cab 4x4
    If you can convert your reactants/products to moles, you're 75% of the way there. Do you understand how to do that?
    If you can demonstrate that step 1 is to make sure the equation is balanced, and step 2 is to convert everything to moles, you're probably going to scrape enough partial credit (assuming your teacher isn't a hard-case) to pass.
    Is your teacher an old guy? I'm sorry, I guess I'm biased, from personal experience. Old guys don't seem able to relate to their students (regardless of age, really) well enough to be able to break things down and build them back up. Then they have unreasonable expectations at exam time.
    If 90% of the class was unable to finish in the time allotted, then clearly his expectations were unreasonable.
  14. Mar 20, 2012 at 10:54 AM
    #54
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    this is blowing my mind every way possible.
    good job on helping though, i tried to read and learn but idk what im even reading haha
  15. Mar 20, 2012 at 11:51 AM
    #55
    UNDEAD1153
    Weston
    Not exactly....is it just dividing the given by the amu? My teacher is probably in his late 40's.....his help for us is "if you don't know it, know it" so I have no idea what to do, I also missed a full week of the chapter due to pneumonia. But good news is I passed last 9 weeks with a C thanks to y'all! Bad thing is that I'm probably looking at a 20 on the test because I have no idea how to do the equations and that's all the test is....
  16. Mar 20, 2012 at 4:58 PM
    #56
    UNDEAD1153
    Weston
    Bump to save my grade!
  17. Mar 20, 2012 at 5:26 PM
    #57
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    when does this test happen? good luck kid. i wrestled with it, but i got it finally..
    i never used it again in the real world.
    kudos for asking for divine intervention on a chem exam..
  18. Mar 21, 2012 at 5:43 AM
    #58
    Squisha
    Westminster, CO
    99 Taco Reg Cab 4x4
  19. Jun 8, 2012 at 12:45 PM
    #59
    ink junky
    ink junky I love tacos too!!!
    TACO LOVER
    TEXAS
    2010 4x4 trd off road DC,
    Aero turbine 2525, Snorkel, AFE pro dry drop in filter, BFG 33s, spydertraxwheel spacers :/. Debadged, rebadged black, TW sticker :D, bed lights, rod holders, OEM roof rack, Complete OME lift, bed lined fenders. Armor Tech Off road wrap around HC rear bumper w/ tire carrier swing out. Relentless front aluminum bumper. Le Devil Horns (_)
    Ok guys, this one is phucking killing me,
    A person has a brain that weighed 1.20 kg and contained 1.35x10^10 cells. Assuming that each cell is completely filled with water (density of water= 1.00g/ml), calculate the length of one side of such a cell if it were a cube.
    In cm:
    If the cells were spread out into a single layer that was a single cell thick, what would the surface area be in square meters?
    I need help figuring out the problem, I don't want just the answer, if anyone can help it would fucking rock!!!!
  20. Oct 2, 2013 at 12:10 PM
    #60
    UNDEAD1153
    Weston
    Whooo!!!! UPDATE!!!!
    So I'm now in college chem and its kicking my ass! haha everything that we covered in a year of high school chem has been covered in a month. Im back to trying to figure out limiting reactants and percent yield. Exam is tomorrow at 8pm CST. Studying all day and tomorrow. Was curious to see if anyone had a good way of finding the limiting reactant and percent composition of elements in chemical formulas. Thanks in advance for any help! Ready to be done with Chemistry!
