Any DIY Instruction on how to fix a door?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kevinztaco, Jul 18, 2016.
  1. Jul 18, 2016 at 12:46 PM
    Kevinztaco
    Kevinztaco [OP] Well-Known Member
    none yet
    Hello all you Tacoma Gurus,
    My passenger side door was pushed forward further than it was intended my accident and now it makes loud mumbling noises when I close it. It sounds like the metal hinge was bent out of shape. Any cheap and easy fix for this without drying my wallet? Thanks.
  2. Jul 18, 2016 at 3:23 PM
    TacomaZL
    TacomaZL Well-Known Member
    Illinois
    2013 Toyota Tacoma 2.7L
    WeatherTech Floor Mats; 15" Cragar Black "D" Window Wheels; Custom Center Caps; 235/75/R15 Goodyear Radial Wranglers; "TOYOTA" Tailgate Decal; Magnetic Tool Storage (in Cabin); Stant Locking Gas Cap; Salex Glove box Organizer Debadged; BHLM; Aftermarket Fog lights; FlashWolves 1000 Lumen Reverse lights; DEPO Black LED Tail lights; Differential Extended Breather Mod; FalconZero F170HD+ Dashcam; Scosche MagicMount; Tyger Auto Tri-Fold Pickup Tonneau Cover;
    Pictures might help you get a better (or more timely) response
  3. Jul 18, 2016 at 8:58 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  4. Jul 23, 2016 at 6:33 PM
    Kevinztaco
    none yet
    Thanks, Jimmy. You are right that the "door check" is what I will need to replace. Taking my door apart to get to it makes me a little nervous since I have never done this before.
    I will order the part and follow this guy's instruction to get to it.
    https://www.youtube.com/watch?v=h9pHl9Co_38
    Kevin
  5. Jul 23, 2016 at 8:03 PM
    Pigpen
    Dan
    Northwest Montana
    If you can find a second gen in a junk yard, you could get it really cheap.
