Any First Gens with Subs ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2003blacktaco, Oct 19, 2017.
  1. Oct 19, 2017 at 11:05 AM
    2003blacktaco
    2003blacktaco [OP] Well-Known Member
    Bay Area
    03' Black Sand Pearl Tacoma SR5 Prerunner Stepside
    12" Sub with Pioneer DEH-X4800BT.
    Let me see your guy's subs in your first gens! I got a Rockville 12" sub ( not expensive but good) with a built in 1000 watt amp. It has a 38 Hz-500Hz Frequency response and I have it set to 60Hz I belive. The wiring kit came with a complete 8 guage kit, a gold plated fuse and a bass controller. My stereo is a Pioneer DEH-X4800BT(BT is for Bluetooth). The bungies are temporary until I find a bracket to hold it in better. I used a self gasket maker from osh to put behind the sub and the cab so it wouldnt rattle. This thing is poweful for my regular cab and shakes all the mirrors at half volume. Show me your setups, maybe I'll get some ideas for mine.
  2. Oct 19, 2017 at 11:18 AM
    US Marine
    US Marine Semper Fi
    Chuck
    SoCal High Desert
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Here's mine a custom built sub box with (2) Pioneer shallow mount 8" subs
    Stereo/ head unit is a Pioneer 4200
    Sub woofer volume control
    Pioneer 4200
    SwampYota and mechanicjon like this.
  3. Oct 19, 2017 at 11:27 AM
    2003blacktaco
    Bay Area
    I like the double din stereo, I was debating on it but kind of wanted the empty space on the bottom. Nice custom custom sub box it looks clean!
    US Marine likes this.
  4. Oct 19, 2017 at 11:30 AM
    US Marine
    US Marine Semper Fi
    Chuck
    SoCal High Desert
    I had a pioneer 3900BT single din with the storage pocket underneath but the screen was hard to view with the BT features such as incoming phone calls
  5. Oct 19, 2017 at 11:35 AM
    2003blacktaco
    Bay Area
    Yeah I get that too, I'll probably switch it out in the future since it will be easy!
  6. Oct 19, 2017 at 11:38 AM
    jbrandt
    jbrandt ......LOADING
    Justin
    Sacramento, CA
    '04 TRD Tacoma 4x4 DC
    It's been YEARS since I did anything with mine, but I did a custom box to fit a 10" behind the rear seats of my doublecab. There's, like, zero room back there so I had to remove the plastic cover off the rear of the seat and cut out the interior at the back wall to get anything to fit. It worked for a very long time, but its seems like recently my amp crapped out, and I've been to cheap to replace it. It's not a daily driver anymore so I'm not as concerned about it.
  7. Oct 19, 2017 at 11:42 AM
    2003blacktaco
    Bay Area
    Yeah having a sub makes daily driving alot better. Im afraid my amp will take a shit and ill have to pull it all apart. The amp is enclosed so it would suck. Mines a regular cab so the little space I had behind my bench seat is now no space
  8. Oct 19, 2017 at 3:09 PM
    jbrandt
    Justin
    Sacramento, CA
    I forget where I saw it, but there's apparently a self contained sub/amp that fit under the driver seat. I might consider that when/if I replace my current (non-functioning) setup. Then again, might as well just get a new amp, I'm sure they're smaller/less expensive now anyway...
  9. Oct 19, 2017 at 3:14 PM
    HSmith_11
    HSmith_11 Tacoma Enthusiast
    Hunter
    Madison, Va
    2001 Ext Cab SR5 4x4 MT
    5100/OME 881s 1.5" Progressive AAL 33x12.50X15 KO2s
    I’ll get a picture up soon if wanted, but I have 2-12” Sound Ordnance subs shoved in the back of my extended cab and an amp under my passenger seat. I’d say it’s pretty loud :D.14B15213-3538-4C5D-8997-6D8EDD702DCB.jpg
  10. Oct 19, 2017 at 3:18 PM
    Dogs
    Dogs Well-Known Member
    Nick
    Missouri
    02 tacoma TRD SR5
    Heres my setup. Built by me and a buddy. Has two down firing 12" kickers. Ported as well. Its pretty loud!
  11. Oct 19, 2017 at 3:19 PM
    jbrandt
    Justin
    Sacramento, CA
    jesus christ. I had a single 10" in my extracab and that was more than enough.
    But I'm probably considered an old fart by now, relative to most of you young punks... :)
  12. Oct 19, 2017 at 3:20 PM
    HSmith_11
    Hunter
    Madison, Va
    Dang I’ve finally found someone who has less room in the cab than me because of subwoofers. But it’s all worth it!!
  13. Oct 19, 2017 at 3:22 PM
    Dogs
    Nick
    Missouri
    02 tacoma TRD SR5
    It definitely is! Before this I just had the box the subs camein sitting on the back seats. It moved around if I hit a turn too fast or if i braked too hard! Definitely worth it to build it!
  14. Oct 19, 2017 at 3:27 PM
    HSmith_11
    Hunter
    Madison, Va
    I have some Velcro on the bottom of mine to keep it from moving around. I also have a single 12 inch in case I wanna swap em every now and then for more room.
  15. Oct 19, 2017 at 3:28 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    SAW 2.0 Coilovers Wheeler's 5 Leaf + 3 AAL Bilstein 5100s LCE long tube header Flowmaster Delta 50 Muffler FJ Trail Team Wheels 255/85/16 Cooper ST Maxx 4Runner overhead sunglass console 4Runner leather seats All LED lights Red/Clear Tail Light Tundra Brakes HID Projector Retrofits 4Runner Auto Up/Down Windows Bullet Liner Cargo tie down system E-locker axle swap w/4.56 Gears ARE MX Cap Prinsu Toprac Custom heated turn signal/puddle light mirrors Volant Intake Tube
    Designed in Rhino 3d:
    Constructed the box from 1/2" birch plywood:
    Found a rustoleum color that was pretty close to the factory oak:
    Installed:
    Please don't mention the broken door handle, it doesn't look like that anymore.
    SwampYota, Droner23, twp and 2 others like this.
  16. Oct 19, 2017 at 3:30 PM
    Dogs
    Nick
    Missouri
    02 tacoma TRD SR5
    Oh thats good! Before I got the box with two in it, I had a single 12 sitting in the middle facing forward, and then a 10 sitting on top of that facing up. Then the two boxes were screwed together. Super ugly, and it liked to fall over on turns.
  17. Oct 19, 2017 at 3:35 PM
    HSmith_11
    Hunter
    Madison, Va
    My subs have also come in handy a few times. For example, I had my windows down at a light and a group of obnoxious kids pulled up with their dad and were blaring music and hanging out the windows and pointing at other cars. I then proceeded to turn my sub level all the way up and blast a song with a lot of bass and cranked up the volume. They heard it and stopped for a little and I looked over and noticed that I was making their side and rear view mirror shake. Then I sped off and left them in the dust.(or as much as I could with a 4 banger and 33s.)
    2003blacktaco [OP] likes this.
  18. Oct 19, 2017 at 3:37 PM
    Dogs
    Nick
    Missouri
    02 tacoma TRD SR5
    Oh thats funny! Subs are definitely handy too have!
  19. Oct 19, 2017 at 3:42 PM
    2003blacktaco
    Bay Area
    Yeah I believe kicker snd pioneer makes some under seat subs but it restricts the amount of rebound for the sub. Would definitely be cool to have 2 under the driver and passenger id say go for it
  20. Oct 19, 2017 at 3:44 PM
    HSmith_11
    Hunter
    Madison, Va
    CF309085-9706-4BB9-801A-A4A67F7C7202.jpg Here’s the picture
