Any good impact for under $100?
Discussion in 'Garage / Workshop' started by poynter, Jan 5, 2012.
  1. Jan 5, 2012 at 5:32 AM
    poynter
    poynter [OP] Well-Known Member
    Tony
    Somerset, KY
    05 Taco 4x4 SR5 TRD AC
    I started to install new struts on the front of my truck last night and my impact died on the first bolt. Ive had it a couple years and thats way longer than I expected it to last.
    What do you guys recommend for under $100?
    I have a lowes locally and thought of trying a kobalt so I could return it if not happy. we also have autozone, advance, oreillys, napa and walmart if any of those might have something.
  2. Jan 5, 2012 at 6:01 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Do you have a Harbor Freight around you? Their tools aren't bad for the price. If it's not under every day use, they'll last a while.
  3. Jan 5, 2012 at 6:06 AM
    poynter
    Tony
    Somerset, KY
    unfortunately no. Its about an hour away. I always end up buying stuff I dont even need when I go there just cause its so cheap.
  4. Jan 5, 2012 at 6:07 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    If your gunna spend money on tools get something reliable like most of the good name brands
  5. Jan 5, 2012 at 6:24 AM
    Pugga
    Massachusetts
    Most of the time I'd agree with you but for the common home owner or DIY mechanic who will only use the tool a few times a year or may install a lift and not touch the tool again for years, it's not worth spending 3 or 4 times the money on a well known, reliable name brand vs. Harbor Freight or the Lowes/Home Depot brands. For most people, the off brands hold up perfectly well for light/moderate use. Hell, I've had a Ryobi 18v set for years and even did a fairly substantial home renovation using them and they've held up surprisingly well.
  6. Jan 5, 2012 at 6:32 AM
    Gregero
    Gregero TRD: Trail Ready Development
    Greg
    Carson City, NV
    Blue '06 Prerunner TRD Sport
    Debadged Tailgate, TOYOTA logo on Tailgate, Uniden Radio w/ 4' Ant., Removed Sway-Bar, Rear Icon Extended Travel Shocks, 8" King Offroad Shocks, Debadged Doors, 1.25" Rear AllPro Wheel Spacers, 315/70R17 Mickey Thompson Baja MTZs, AllPro Skid Plate, New Car Smell Air Freshener, OMD Ford&Chevy Leaf Pack with Original Main leaf, Engage LT UCAs and LCAs, Engage HD Tie Rod Ends, Kar-Tek Limit Straps, Camber Eliminator Kit, Removed Rear Flares, Blue LED Dome and Map lights, LED License plate lights, Black TRD Sport Rims, 20W PA Speaker, 2 Meter Radio, Demello-like Bed Bar, Harbor Freight Dust Lights, Blacked-out Hood Scoop, Custom Pre-Runner Bumper, JBA Long Tube Headers, MBRP Catback Exhaust, AFE Stage2 CAI, URD MAF Sensor Calibrator
    I'm kinda looking around as well. I was hoping to get an air impact, but what kind of air compressor would I need to run it? Would I be looking for a high volume tank or one with a high PSI or both? Any help would be great.
  7. Jan 5, 2012 at 6:37 AM
    poynter
    Tony
    Somerset, KY
    Ive got a craftsman compressor. 33 gallon upright tank. 150psi.
    It was a little under $300 and the impact that just died was a freebie deal they had with the compressor so I definitely got my moneys worth.
  8. Jan 5, 2012 at 6:40 AM
    Gregero
    Greg
    Carson City, NV
    crap.. lol n here I was researching the little 3-6 gallons with 150-200 PSI... with such a low volume, I'd be waiting for it to refill quite a bit I imagine??
  9. Jan 5, 2012 at 6:42 AM
    MQQSE
    MQQSE Bannable Galloot
    Rob III
    Palmer, Alaska
    "Stitch" Still Stock Concept Truck
    Shtuff
    I agree ... picked up my air tools (Impact/ratchet/nailer) at a yard sale about 3 or 4 years ago. I think they are Husky brand. For the 3 or 4 times I use them a year, they serve their purpose and have held up. FWIW ;)
  10. Jan 5, 2012 at 6:47 AM
    wcp0611
    wcp0611 Well-Known Member
    Cliff
    Rockvale, TN
    wcp0611@gmail.com
    Grey wire and keyless entry. I like stock.
    If you're running it for a while, then a big tank is a must, unless you are using a gas engine compressor. Gas ones fill faster, but it wont' help your waiting if you tap that tank out quickly. I have a 5 gallon, twin tank electric compressor and it does just fine for turning lugs or long bolts. I just bought a Harbor Freight, no-name air impact and it works great.
  11. Jan 5, 2012 at 6:49 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Check your local pawn shops.
  12. Jan 5, 2012 at 6:57 AM
    Pugga
    Massachusetts
    For a tank (for household or lighter duty use), I'd look for a higher cycle rate on the compressor or a large volume tank. If you run a shop, you want both. I have a small Bostich compressor that's got a decent duty cycle but it's a pancake tank so it's not overly large.
    Some compressors are 100% duty cycle meaning you can hook the gun right up to the compressor, no tank needed. All the tank does is create a reserve so the compressor doesn't have to run 100% of the time. You have to determine your use and decide what trade offs you're willing to live with (big tank, takes a while to drain down but a long time to refill or small tank but a more expensive, high duty cycle compressor).
  13. Jan 5, 2012 at 6:59 AM
    Freelance
    Freelance Well-Known Member
    Curtis
    Las Vegas, NV
    07 DC PreRunner SR5
    I love me some Harbor Freight. I can fill up a tool box for $25, and most of their 'solid' tools hold up great (open end stubbies ftw!).
    Like others said, if it's a tool you will use one or twice a year, you don't need a $450 impact. Hell, they are technically only to *remove* bolts/nuts anyway. I work on CVT engines daily, and the Harbor Freight impact that I had just couldn't hang. I worked well out of the box, but would lose it's balls, or sometimes just lock up after a few weeks of very hard use. Sure, I could replace it for cheap under the HF warranty (which are awesome), but it was a hassle back and forth after the second time. I've had a Craftsman now for awhile and it's held up okay.
  14. Jan 5, 2012 at 7:01 AM
    PSUnick
    PSUnick Lets Go State!
    MA
    2007 AC 4x4 Sport
    I worked in Auto Body for six years. The master body and frame technician recommended to me the Ingersol Rand IR-231 impact gun. In his view it was the best entry level impact gun available. It has been around for ages and you can even get rebuild kits for it when the seals eventually wear out.
    Amazon has it for $122 shipped.
    http://www.amazon.com/Ingersoll-Ran...RM3I/ref=sr_1_1?ie=UTF8&qid=1325775386&sr=8-1
  15. Jan 5, 2012 at 7:02 AM
    triumphx
    triumphx Well-Known Member
    Austin, TX
    X-runner/cummins
    ^This is your best route, i manage a pawn shop and we have cornwell, mac and sometimes snap-on impacts around 100 bucks. Right now i have a cornwell for 49 bucks. Pawn shop FTW
  16. Jan 5, 2012 at 7:02 AM
    NicNac22
    NicNac22 D.I.L.L.I.G.A.F
    Nic
    Wild and Wonderful
    95 V6 4x4 ex cab SR5 5sp PICKUP!!!
    fun stuff coming soon! New battery, radiator and CV joints and axles. Added some Rancho RS5000 shocks.
    mmmm power tools :popcorn: i might want to invest in some :D
  17. Jan 5, 2012 at 7:03 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    My dad has the HF electric impact and its ran great for years. Ive used it many times on my truck. get one of the 20% off coupons and go get one!
  18. Jan 5, 2012 at 7:06 AM
    NicNac22
    Nic
    Wild and Wonderful
    sorry dont mean to hijack or anything, it just hooks up to an air compressor right?
  19. Jan 5, 2012 at 7:09 AM
    Freelance
    Curtis
    Las Vegas, NV
    07 DC PreRunner SR5
    We also got an electric one from HF as well (for back-up, or emergency use on the road). Hooked into a cigarette lighter, or to the +/- battery terminals. GREAT for removing stuck nuts/bolts. That thing still breaks loose anything, and I mean anything, that my Craftsman can't.
    Oh, and total win on the pawn shops, and yard sale suggestions! Found my best (used) tools at them.
  20. Jan 5, 2012 at 7:09 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    22 JLUR 6MT
    you can get air powered, electric, or battery operated.
