any help or tips
Discussion in 'Technical Chat' started by victor in the desert, Jun 8, 2015.
  1. Jun 8, 2015 at 4:15 PM
    victor in the desert [OP] Well-Known Member
    victor
    2011 tacoma prerunner
    hi Liam new to this TacomaWorld site but iam in need of a little help or advice MY CHECK ENGINE LIGHT WITH TRACTION CONTROL LIGHT CAME ON AT THE SAME TIME WAS WONDERING WHAT IT COULD MEAN ANY HELP AOR ADVICE TIPS . THANKS
  2. Jun 8, 2015 at 4:23 PM
    doyouevenprerun
    doyouevenprerun Well-Known Member
    Jake from state farm
    Gilbert, AZ
    02 TuRD
    just got a simple lift on her
    go to your local auto zone and ask them to run the codes for your check engine light and see what code you get, then search the code and see what it means. :)
  3. Jun 8, 2015 at 4:48 PM
    victor
    thanks i think i will go the auto zone its around the corner anyway. hope its nothing bad or big but i did put a K&N Airfilter in recently hope its not that thankfully i have the stock one ..
  4. Jun 8, 2015 at 5:05 PM
    victor
    thanks similar issue with my Nissan too years back.. if i replace it with paper with the CHECK ENGINE LIGHT AND TRACTION CONROL LIGHT RESET?
  5. Jun 8, 2015 at 5:20 PM
    doyouevenprerun
    Gilbert, AZ
    02 TuRD
    disconnect the battery for 10 minutes after you put the stock filter and clean the maf sensor, and that will reset your code. if it comes back you have a different issue.
  6. Jun 12, 2015 at 3:59 PM
    victor
    Hi it's me again I had the problem with the check engine light and traction control light ,,, check this out I let it sit for about half a day I drove it to work about 40 miles just cursing and by the time I got to work the light disappeared and has been off since go figure . Good news.
