Any high mileage 4 cylinders?
Discussion in '4 Cylinder' started by Samurai49, May 5, 2013.
  1. Jun 26, 2017 at 6:19 PM
    #201
    Cokid
    Cokid Well-Known Member
    Mel
    Cahone, Co.
    2017 trd off road/ 85 sr5 extcab
    Truck is still in great shape. Very little rust. Engine is using a little oil.
  2. Dec 26, 2017 at 9:48 PM
    #202
    jcornwell
    jcornwell Member
    john
    17 tacoma 4x4 2.7L 6 speed auto
    none
    Traded in my 07 2wd 5 speed Tacoma in April. Had 241,XXX miles on it.
  3. Jan 16, 2018 at 11:47 AM
    #203
    Tbryant
    Tbryant New Member
    Tyler
    1998 Tacoma SR5 2wd 2.4l M/T
    I got 360k on my 98 Tacoma.
  4. Jan 19, 2018 at 9:34 AM
    #204
    TheManInDboX
    TheManInDboX Well-Known Member
    Columbus Ohio
    See my signature.. I have had a lot of high mileage toyota's but this is my first taco.. i am curious if it will make the million mile club.. or if i will die of old age first..
  5. Jan 19, 2018 at 6:55 PM
    #205
    Old n' slow
    Old n' slow Well-Known Member
    Oak Island, N.C.
    2000 Tacoma 2.4 5 speed flare side
    2000 Tacoma 2.4L 5 speed, 2x4 Flareside.......123k everything original.
    I go 3k miles towing my 1800 lb. trailer, average 22-23 mpg and don't use a drop of oil.
    I love this little truck.
    tommyboyskrrt likes this.
  6. Jan 19, 2018 at 7:26 PM
    #206
    Jp Sturm
    Jp Sturm Well-Known Member
    Jp
    Horseshoe Bend Idaho
    95 Sx 5 speed
    My 95, it currently sits at 170,314. Almost all is original minus the radio and alternator.image.jpg image.jpg
  7. Jan 19, 2018 at 11:32 PM
    #207
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I've posted before in other threads. My 2.7 RC 4X4 has almost 169,000 miles on it. So far it has had 4 batteries. The first 3 were all Toyota batteries with the first one replaced under warranty. This last one is an Interstate Megatron. The water pump was replaced at around 60,000 miles under warranty. It's had one brake job at 60,000 miles and at 168,000+ the brakes are still good.
    I replaced both outer tie-rod ends back around 150,000 miles. Only one had a VERY small amount of play but I replaced both. I've replaced all the suspension which ran me just over $2000 and replaced the steering gear bushings with urethane from Energy suspension. The suspension is a known problem with Tacos so that doesn't really count since it sucks from the factory and anyone that does their research knows that before they even buy a Taco with stock suspension. The difference between stock suspension, especially at 154,000 miles and an aftermarket suspension is huge. I did use Deaver J59 leaf springs but the rest is all OME and the OME I installed is really something to write home about compared to the factory stuff. I can see Kings or ICON's in the future the next time around though. The OME is harsh but it's a truck so I can't really complain. OME is designed for carrying heavy loads off road which I never do and I knew that before I bought it. So far? I have no complaints with the OME and I've got about 15,000 miles on it.
    I don't know about the newer Taco's but my 2004 is about as maintenance free as any vehicle on the planet. I actually have to dream up things to do on it. However, this next summer I will begin stockpiling parts such as an alternator, starter, water pump, and will be replacing rubber hoses as well as vacuum lines just to keep it as reliable as it already is and also to know I have parts "on hand" rather than waiting for them since this is my only ride at this point in time. The local Toyota dealer talked me out of buying parts in the past because they said, "that part is good for the life of the vehicle". So far, they have been right. Well, what is "the life of the vehicle"? Rubber ages. It's that simple so rubber parts replaced by urethane parts if they are available are on the menu for the future when I need them.
    I bought my Taco used from my dad at 119,000 miles so I have a pile of maintenance receipts for this Taco. I know exactly what maintenance has been done on it and it was always done by the book since new. Yeah, I got a deal for $5000. That being said, these Tacoma's are ultra reliable and, from what I have read, they still are to this day. I worked with a guy who had 385,000 miles on his Tundra and bought another Tundra because he was going to give the last one to his kid.
  8. Feb 2, 2018 at 12:06 PM
    #208
    Snowman94
    Snowman94 Member
    Charlotte, NC
    2000 Prerunner 282K (sold) 2001 Limited DC TRD-OR V6
    237K on my 2000 2.7 AT. Pretty much everything is factory, except the plugs/wires, front brake pads/rotors, some belts, hoses, and fluids. Replaced the valve cover gasket awhile back.
    Best vehicle I have ever owned. Wish they still made them this small.
    ABA180 and BillsSR5 like this.
  9. Feb 2, 2018 at 12:16 PM
    #209
    En56
    En56 @daydreamz_of_a_deskjockey
    OC
    2000 SR5 4wd
    I've got 221k on a 2000 2.7L 4x4 MT . It has 1 cylinder with compression below spec, but it drives the same as the day I got it. I never would have known if I didn't test it out of curiosity. It almost makes me more confident in the truck. It sees a good amount of off road and has had all the suspension replaced with OME front and rear plus new tire rods, bushings, etc
    Jimtacosport19 and TacoS805 like this.
  10. Feb 6, 2018 at 8:51 AM
    #210
    TacoS805
    TacoS805 Well-Known Member
    So Cal
    2004 White 2.7L 4x4 5 speed Xtra Cab
    Nice little setup
    Forgive my naivete, by "tire rods" do you mean tie rods? I ask not to be a smart ass, but I'm pretty newb in all honesty and am going to be replacing most front end stuff on mine. Just want to make sure I'm not missing another component.
  11. Feb 8, 2018 at 11:01 AM
    #211
    En56
    OC
    2000 SR5 4wd
    Yes exactly. Once of those situations where a typo creates a different work entirely. I meant Tie Rods
    TacoS805[QUOTED] likes this.
  12. Feb 8, 2018 at 11:30 AM
    #212
    TacoS805
    So Cal
    Thought so, just wanted to be sure, didn't want to assume anything.
    Thanks!
  13. Feb 13, 2018 at 1:12 PM
    #213
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    I can't believe I haven't posted here before. Some of you might recognize my some some of you won't. My 09 2.7 4x4 5spd access cab is currently sitting around 260k km or 161.5k miles. This is by far and I mean far the best vehicle I have ever owned. The only real issues this truck has had were ones ive created. I know the truck had it's front wheel bearings and brakes replaced at the dealership before I bought it. I bought it used with 93000 miles on it. I've since done the fronts once more last year, the clutch is factory as far as I know. Recently I replaced the blower motor resistor. It's had the clock spring recall done and that's it. I've replaced the suspension twice but that was my doing and I rebuilt the front end last year again my doing. Nothing else has gone bad.
  14. Feb 17, 2018 at 1:17 PM
    #214
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Pretty amazing where she’s been!!
    160 k on my 08 2.7 5mt
  15. Feb 17, 2018 at 1:42 PM
    #215
    TYetti
    Mat
    Gotta use it before it rusts to pieces lol
    Jeffch likes this.
  16. Feb 22, 2018 at 4:46 PM
    #216
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Lol!
    I’d say or until the waarntee runs out but I do believe you have voided yours?
  17. Feb 22, 2018 at 5:53 PM
    #217
    TYetti
    Mat
    It never had one. I did buy a 3 year drivetrain one from the dealer but it was a condition of sale.
  18. Feb 24, 2018 at 1:24 AM
    #218
    bsp_taco
    bsp_taco Well-Known Member
    Nick
    Oregon
    ACLB 2008 2.7L M/T SR5 4x4
    Dirt King 3.5" LT, King 2.5 RRs, Duratrac 35s, 4.88s, arb air locker front & trutrac rear
    137xxx miles on it and no major problems, 2.7L 5spd manual and I had to replace the clutch once. IMG_6541.jpg
  19. Feb 24, 2018 at 11:56 AM
    #219
    ecady75
    ecady75 New Member
    Eric
    06 Tacoma
    2006 4 cyl 251,000. Routine maintenance..nothing crazy. Runs amazing.
    DGXR and Jeffch like this.
  20. Feb 24, 2018 at 12:28 PM
    #220
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Gotta love it!!
    Welcome to TW also.
    Congrats on your ride, some pics would be cool.
